Question about Sewing Machines
Water leaking from Gaggia Syncrony Compact - Sewing Machines
  • spollok Oct 07, 2009
    Thnaks for your response. No the reservoir does not leak when removed and placed on its own. What is the "O" ring. Is it possible to buy this as a replacement part?
    President:
  • Sewing Machines Master
  • 1,714 Answers
Water solenoid is not closing all the way. Could be lime scale build up in the solenoid. Try cycling the machine a few times so the water solenoid activates on and off...
Posted on Oct 08, 2009
  • 3,741 Answers
If you remove the tank, does it leak? If yes then check the spring loaded valve under the tank carefully Also check the O-ring for damage,as in most of the leakage cases its because of the damaged O-ring
thanks,keep updated and please rate the solution positively.
Posted on Oct 07, 2009
Janome 300E Memory Craft reading .sew and .jef
Hi what you need to do is change the format as it is only able to process the one format.
What you can do is search online for software that converts the formay for you most of these sites are free so have a look you whould find plenty.
Alot of people have this problem but changing the format get round this ok let me know if you need further assistance ok
Feb 10, 2008 | Janome Memory Craft 3000
How do I purchase a manual for a sewing machine
sorry but we need make and model to even think about searching for a manual the word compact does nothing .
Mar 02, 2015 | Sewing Machines
Type of needle for janome mini compact
Hi
Ask Jan on the Janome website.
http://www.janome.com/index.cfm/LearningCenter/AskJan
Or try on the forums there.
http://www.janome.com/fusetalk/forum/
I would imagine that Janome universal needles would be fine for this machine.
Thicker needles are required for sewing thicker fabrics.
Sep 19, 2010 | Janome Mini Compact
I bought a 2 gb compact flash card. Are these not
It appears that the 9700 works with Type II CFD's.
I think that the 2 Gb cards are ULTRA II's which likely will not work with your 9700. The 512's are getting harder to find as well...
Nov 10, 2009 | Janome Memory Craft 9000 Computerized...
I have two bunn's and two different problems. First one is a GR10-b and Date code is 04-1402 and it has been repaired once. The main element is out because it don't heat up and the front panel doesn't...
The first one is probably lost power from a blown fuse or bad switch or something. I can't give you a 'generic fix' for it. Can you open things up and troubleshoot a bit? Same thing with the other one that is leaking water, this is going to have to be opened up and the leak will be obvious from some fitting or something and will need to be tightened up. I can help you with testing procedures if you can troubleshoot a little electrical for the first one. You may be able to see the obvious leak on the other one when you get things open.
Oct 10, 2009 | Sewing Machines
Using bigger than 64 MB compact Flash Cards
I have the same machine and if you watch the dvd included with the machine it says to use a MC no bigger than 1 gb. I use a 512mb and it works fine. Your computer may not have a MC port so you will have to purchase a memory card reader which you can purchase on ebay or at Fry's for around 10 dollars. All the files need to be saved on the MC card as a SEW or JEF file. When you go to your machine touch the emb. key then the disc key and you should see your files. You may also need to turn the page; sometimes it save it on different pages.
Apr 12, 2009 | Janome Memory Craft 9000 Computerized...
Downloading embroidary designs for the Janome MC 350E
Firstly, format your compact flash card on your embroidery machine. This is presuming you have embroidery files in your jef format your machine reads on your computer. Place your compact flash in the compact flash card reader writer connected to your computer, open the compact flash card in your computer, open the file emb5. Now you can simply copy and paste a design from your computer to your flash card. It works for me. Goodluck.
Sep 20, 2008 | Janome Memory Craft 9000 Computerized...
Sewing Machines Logo
16 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
