Question about Music
How do i fix my expression pedal on my digitech rp80?does it need a spring underneath it??? or is it read by sensor????
    Scholar:
  • 109 Answers
I think it is controlled via a LDR instead of a pot. If you see a pot under the pedal then it may need a new pot but I believe they have a LDR, which is an LED/light controlled resistor system. Either of these can be fixed by an experience repairman.
LDR parts are available at SmallBearElec.com. It will require some soldering experience. Be sure to test the pedal's control circuity with a digital multimeter to be sure the problem lies within this area and not somewhere else.
Posted on Oct 09, 2009
Digitech rp3 fx pedal too much voltage wont turn on
Usually the manuf. have diodes used as protection against over voltage or adapter polarity issues. Try the correct adapter (sleeve and tip have specific voltage polarity...check for drawing denoting each) and if it fails to power the unit up, it's probably time for Digitech authorized repair.
Oct 29, 2012 | DIGITECH Music
My rp90 reads out pd when i plug it in and is stuck in this pd mode and doesnt let me play anything how do i unstuck it from this pd mode
Try a factory reset. This is the procedure
1. Press and hold the Store button while powering up the RP90.
2. When the display prompts you with FR, release the Store button.
3. Press and hold the Store button for 3 seconds until RS appears in the display and release. The Factory Reset procedure takes approximately 10 seconds.
4. Once the factory reset has finished you will need to calibrate the Expression Pedal.
May 14, 2011 | Music
I'm trying to add a Digitech X Series EX-7
You CANNOT use the Voodoo as it outputs DC voltage and the EX-7 requires an AC voltage and of 9 VAC and also 1.3 amps at that.
May 07, 2011 | Digi-Tech Digitech X-Series Synth Wah...
The foot pedal (not the switches) on my "DigiTech RP90 Modeling Guitar Processor does not work...it will move but it changes nothing.
All DigiTech expression pedals use an optical system instead of potentiometers.
Either the light is broke, or the filter.
The filter protrudes from the bottom of the pedal, and is darker at the top and gradually fades to clear at the bottom. If this breaks off, then there's nothing to limit the amount of light to the optical system.
If it is the light, then you'll have to have it serviced by someone qualified to work on it. Your local music shop should be able to help you out.
Hope that helps!
Jan 13, 2011 | Music
I need to know how to restore factory settings on digitech RP RP-90
Here is the link to your manual if you don't have one:ftp://ftp.digitech.com/pub/PDFs/Manuals/RP90/RP90Manual18_0490_A.pdf Page 34 tells you how and don't forget to calibrate the expression pedal. Page 35 tells you how. Hope this helped.
Nov 09, 2010 | Music
When i press the harmony effect i have to hold it
Well i hope the latching mechanism isn't busted!
Check/review your parameter settings for your programs. Especially in the Expression Pedal Control areas.
From their site:
--Harmony Footswitch
This footswitch turns the harmonies on or off. While multiple harmonies can be selected within a preset, the HARMONY footswitch activates or deactivates any selected harmonies simultaneously.
When the LED above the HARMONY footswitch is illuminated, the harmonies are on. When the LED is turned off, the harmonies are turned off.
--Note: The settings for FX Footswitch Control, Harmony Footswitch Control and Guitar Sensitivity apply to ALL presets. The setting for the Expression Pedal Control applies to the current preset only. If you modify the Expression Pedal setting and wish to store it you must Store the preset (see page 11 ). When you load another preset, its setting for Expression Pedal Control will take effect.
--To perform a Factory Reset procedure
If you are editing a preset, press the Up or Down footswitch to exit edit mode.
Press and hold the Major/Minor button and then press and release the Store button. The display will read FAC RESET- WILL ERASE ALL YOUR PRESETS... , then STORE=RST.
Press the Store button again to continue with the factory reset. If you don’t want to do the factory reset, just wait 5 seconds, or press almost any other button, to cancel.
Mar 27, 2010 | Digi-Tech Digitech Vocalist Live 4...
Expression pedal wont work
Here is a link with a source for the manual on the right of the page:http://www.digitech.com/products/Bass/bp200.php Further information can be found at support at the top of the page.
Mar 20, 2010 | Music
My DigiTech RP90 expression pedal isn't working at all
If you are getting no display after you try powering up properly check the plug end of the power supply with the supply plugged in with a volt/ohm meter. You should get a reading of 9volts. If you don't ,your power supply is not working. Sometimes the wire breaks where it goes into the supply and sometimes where it goes into the plug. Your power supply jack may be broken where it is soldered to the circuit board. If the unit has power you can do a factory reset. The procedure is on page 34 and 35 of the owners manual that you can download for free here:ftp://ftp.digitech.com/pub/PDFs/Manuals/RP90/RP90Manual18_0490_A.pdf Let me know if this helps.
Nov 26, 2009 | Music
Digitech rp6
Try contacting their service center rep at (801)566-8800. They might send you a schematic for the pedal if you explain your situation. They do recommend using the original power supply PS0912 which should still be available. Hope this helps.
May 25, 2009 | DIGITECH VOCALIST LIVE 2
Digitech RP90 Expression Pedal
Same thing happened to me but i didn't drop the pedal.Try to recalibrate the pedal cause mine worked after that.Look in the Owner's Manual at the recalibration section.Hope this will work for you.Good luck with it!
Mar 29, 2009 | Music
Music Logo
874 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
