Question about Oreck TS100 Iron
Bush IN632 steam generator iron not steaming
When I unpacked my Bush IN632 steam generator iron it had little packs of silicon in the box that had burst open and were everywhere (including I've since found out, inside the iron. Having used the iron only a few times times it is now not working, there is power there, it gets hot but it just doesn't steam. I have been on to Bush who told me to replace the filter which I did and it made no difference. They then suggested that I return it by post but it will cost me a small fortune because it is so heavy and I am on a tight pension. Does anyone know what could be wrong.
  • karens41 May 11, 2010
    my iron does the same thing it wont steam at all it heats up got water in it but no steam
Check seller........ spares2go on ebay u.k they may have a spare for you
Good luck
Posted on Dec 27, 2011
3 Suggested Answers
  • 19 Answers
SOURCE: no steam when ironing and no burst steam
bad connection to heating coil. Not worth fixing.
Posted on Feb 22, 2008
  • 4 Answers
SOURCE: I have a Bush IN632 steam iron which is not
took mine apart found that the base unit had limescale build up to such a level that the whole water chamber was full of limescale. Need a special security screwdriver
Posted on Apr 10, 2011
Tefal iron steam generator
Steam irons can become clogged with mineral deposits. Use distilled water in the iron to minimize these deposits.
To clean the iron , use 1/2 white vinegar and 1/2 water. pour in iron and place iron on steam. The iron may require a few cleanings.
May 11, 2014 | Tefal Irons
Filter light flashing what do I need to do no manual available
Breville VIN170 Extreme Steam Digital Steam Generator Iron
unplug the iron from the mains , keep both the power and keep the steam release button on the iron depressed and then plug in and switch on
Aug 07, 2013 | Breville Vin170 Extreme Steam Digital...
My iron is getting hot but giving no steam can anyone advise
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below).
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat .
If the iron does not spray properly, inspect and clean the nozzle (see below).
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
Jan 31, 2013 | Breville Vin227 Extreme Steam Steam...
Swan steam generator iron not steaming
The steam vents may be blocked. Add some vinegar into your iron box and try to steam for a few time. then clean the steam vent gently with a tooth pick. Drain out the added vinegar and start using your steamer as usual.
Oct 29, 2012 | Tefal Ultraglide 1549 Iron
Can't get my Morphy Richards steam generator off of standby
do this and use the common sense. God bless you
f the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below). If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat (see the Appliance Controls Fix-It Guide).
Sep 24, 2012 | Irons
MORPHY RICHARDS 42256 JET STREAM STEAM GENERATOR IRON does not provide steam
My MORPHY RICHARDS 42256 JET STREAM STEAM GENERATOR IRON has stop producing steam. I have changed the filter and although it heats up, it does not produce any steam.
Feb 29, 2012 | Irons
I have a Bush IN632 steam iron which is not generating steam. Can anyone point me in the correct direction as to what the fault may be?
Jan 30, 2011 | Oreck TS100 Iron
My Tefal Steam Generater Iron will not steam
check the little tube that regulates the water to the holes it needs to be changed.good luck.
Nov 08, 2006 | Tefal Ultraglide 1549 Iron
Oreck TS100 Iron Logo
412 people viewed this question
Top Oreck Irons Experts
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you an Oreck Iron Expert? Answer questions, earn points and help others
