Question about KitchenAid Cooktops
Kitchenaid KGRT507FWHO gas range not firing or not getting hot
I have Kitchenaid KGRT507FWHO gas range. When trying to start the oven, I smell gas. Sometimes it fires, sometimes it does not. Even when fired, very slow to heat up and never reaches the target temperature. thank you
    President:
  • 1,304 Answers
Your ignitor is either cracked or bad
gotto sears type in your modle numbber and look for ignitor in parts search reletivley easy repair
Posted on Oct 08, 2009
My Kenmore propane fueled gas oven gives off a powerful strong smell every time it is started. The burners on top do not. Is there any way I can correct this?
this is because the gas is on full before the oven lights
IT is an explosive situation and should be quickly corrected by an accredited gas fitter
the soot indicates an incorrect burn ratio and that will be the major part of the problem
Jan 08, 2016 | Kenmore Elite 30" Stainless Steel...
Propane oven won't light
Can you post more details like: Does the oven ignitor come on (glow orange)? Can you hear the oven gas valve click open and/or smell gas? Do all the stovetop burners work fine? Have you checked your propane tank to be sure you are not out of gas?
Mar 13, 2014 | Amana AGR4433XD 30" Freestanding Gas Range...
Burning smell from underneath the bottom oven plate
Something spilled into the area where the flame is Those big gaps in the bottom plate is how the heat gets into the oven from the burner . Try letting the oven burn off whatever spilled in it
Jan 04, 2014 | Samsung FX510BGS Gas Ranges
Maytag Range won't heat up oven or cook top
you have melted internal wiring, probably some mice ate it. call an electrician and DO NOT USE IT!! turn off at the wall/fusebox
Nov 20, 2013 | Maytag MER8770WS 30" Freestanding Electric...
Kgst307gbs glass control panel replacement
KitchenAid is the most likely source of a replacement
Mar 23, 2013 | KitchenAid KGSS907SSS - Slide-In Gas Range...
Oven will not ignite; takes several minutes when it does; gas is available (can smell it)
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jul 06, 2011 | Wolf Range 30 in. SCB30C Gas Cooktop
We have a Five Star gas oven and attempted to use the self cleaning process to clean the oven. We started yesterday and it appeared to complete the cleaning cycle. This morning, however, the locking...
There are two reasons for the lock to remain locked. One: the thermostat/wiring failed. This results in the oven's control still believing that the oven is too hot (over 450 degrees) and thus will not unlock. The other possible problem is that the unlock mechanism failed.
You can try to unlock the oven manually. (For some ranges, you can do this from the back of the range.) Please add a comment with the model of the oven/range for more assistance.
I hope this gets you started on solving the problem.
Jul 06, 2017 | Five Star 48 in. TTN045 Gas Cooktop
High-pitched squeal/whistle noise from range
Noise went away by itself. No root cause found. Please remove this posting, thanks.
Dec 04, 2009 | Maytag MGC6430 Gas Cooktop
Spark igniters on the burners fire continuously
When cleaning, if the control switches get damp, they will react as you describe.
Unplug the appliance, use a hair dryer and attempt to dry the switches.
Leave it unplugged overnight and try them again tomorrow.
They will eventually dry and be OK.
Feb 24, 2009 | KitchenAid 31 in. KGCC505 Gas Cooktop
Thermador Gas Range - Griddle ignition will not spark
I have a Thermador Gas Range PG364GDBS - Oven, 4 burners, and center griddle. All are gas. The four burners and gas oven work fine. The griddle just stopped working, no spark. Turning on the griddle control, the gas valve opens(hear it), gas flows (smell it), but the ignitor will not spark (no loud or faint spark that I can hear). I got a replacement ignition device (mount at the burner) thinking it might be the problem, but still no spark. I checked the AC voltage at the terminal and measured 39 VAC between the terminal and ground. Not sure if that is the correct voltage. Any insights or advice would be great.
Dec 07, 2008 | Thermador SGS36GS Gas Cooktop
Cooktops Logo
209 people viewed this question
Top KitchenAid Cooktops Experts
vince
davenpdx
Are you a KitchenAid Cooktop Expert? Answer questions, earn points and help others
