Question about Refrigerators
Freezer Frosts up at top of heat exchanger and blocks air flow
I have a Kenmore side-by-side refrigerator model 57542. I am having trouble determining what part went bad. My son left the door on the refrigerator open before leaving for school. Ten hours later it was closed, but it was too late, the heat exchanger frosted up and stopped the refrigeration. I pulled the cover off the heat exchanger and defrosted it. It wasn't the first time! I put the cover back on and plugged it back in. However, this time the refrigerator did not resume working, it frosted back up at the top of the heat exchanger. Repeated attempts to defrost the heat exchanger result with it frosting up at the top when returned to service.
I checked the Defrost timer, it turned off the compressor when tested.
The evaporative heater had 29 ohm across the leads
The Temp sensor TSTAT had 1.0 M ohm across the leads at room temp
The evaporative fan had 32 ohms across the positive and negative leads.
I suspect the problem is the fan because I have not seen it running through all this troubleshooting. But I am not up on when the fan should be running and when it should be stopped.
Any thoughts? I would like to replace the problem part the first time THX
  • togjab Jan 07, 2009
    I have the same problem I think but the model has two fans, the main fan in the back over the condensor and the other one is in the freezer section called the evaporator fan.
    I believe the suspect is the evaporator fan, part number 10513803.
    Scholar:
  • 146 Answers
Sometimes the fan only runs when the door is closed. Try closing the door first if you don't hear it running then more than likely it's the fan. The fan comes on when the temp in the refer falls above 36 to 38 degrees. After the refer reaches temp then it cycles off. It should be running every time the compressor comes on.
Posted on Dec 24, 2007
ON MY KENMORE SIDE BY SIDE REFRIGERATOR THE FRIDGE ISNT GETTING COLD BUT MY FREEZER IS FINE
Check to see if the air flow vents are not being blocked. The refrigerator side sucks air from the freezer side and blows it through vents on the side top and is controled by a thermostat marked, usually Refrigerator Cooling. If your thermostat is off, then no air, if the thermostat is kaput, then no air.
Dec 12, 2010 | Kenmore Refrigerators
I have an amana br22 the botom freezer gets an ice block on the radiator coils then air flow slows down to top section i have to hot air gun the freezer to get the air to start moving
The ice block is due to a defrost circuit failure. Typical problems are due to the defrost heater, defrost timer if used on this model and defrost thermostat. Since you are using a heat gun to melt the ice, check the the defrost heater with a meter to determine whether it needs to be replaced.
Aug 23, 2010 | Amana Easy Reach AFD2535DE Bottom Freezer...
Bottom freezer frosts up in a week or two and then refrigerator won't cool? What do I do?
Two possibilities:
- Defrost timer has failed allowing the buildup of ice that eventually blocks air flow. - Circulation fan has failed; check this by holding a couple of wet fingers near the vent inside the refrigerator compartment (typically in the back of the cabinet) while you hear the compressor running. If you can't feel any air flow, the fan is not turning.
Go to the Sears website linked below and enter your model number to see if they have your unit shown in a line-drawing that will enable you to see the location of the various assemblies and also provide name and part number for them.
Sears PartsDirect
This will also give you a chance to see how accessible things are if you want to DIY.
Aug 07, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Freezer stopped making ice and now coils in bottom of freezer r freezing up..this is a side by side refrigerator
shut off motors .....let it completely defrost,,,restart the fridge and STOP PACKING IT SO FULL allowing air to flow . if air can't flow freely, the ice maker stops and the freezer frosts up ,...causing the refrigerator side to not cool as well as it should.
the freezer side only works within certain parameters.
HTH !
Mar 29, 2010 | Frigidaire FRS26R4A Side by Side...
Frosts up wont get cold MCBR1000S
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 17, 2009 | Magic Chef CTB1821AR Top Freezer...
Kenmore won't cool down.
I you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
Aug 15, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Kenmore model 57029 side-by-side refrigerator not working
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, ie defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
Aug 12, 2009 | Kenmore 57029 Side by Side Refrigerator
Ice Maker problem
check if it has one the filter, hollow ice = lack of water flow into the icemaker
Apr 26, 2008 | Refrigerators
Freezer works frige dont
check for frost in freezer section. If frosted up your air flow is being blocked. Must thaw and determine why it is not defrosting
Jan 05, 2008 | Kenmore 56539 / 56532 / 5653 / 656534 Side...
The bottom drawer freezer frosts up over a few days.
There's warm moist air entering the unit from the back somewhere. Pull the unit away from the wall and check behind there. Look closely at where the Ice Maker fill tube enters through the back. If you find the air leak, use "perma-gum" (google it) to seal it.... not silicone.
Jul 26, 2007 | Jenn-Air JFC2087HRP Side by Side...
Refrigerators Logo
147 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
