You need to replace your lamp. Also check power supply and ballast board. Most of the time if you replace the lamp it will come back up. After replacing the lamp you will need original remote to reset lamp hours.
You very well could have problem with the Ballast board that powers Lamp or your Lamp Fan maybe defective and if you need orinagnal hand unit for set Call Encompass Parts Distrubtion or Go to their website type in Model number they will list Parts /Prices for your model.
1-800-638-3328 Mats Electronics also sells handunits .To reset timer
Hold VOL- on front of TV and Menu on hand unit at same time for 5secs
if this does not work try it in reverse Hold Menu down on TV and Vol- on hand unit. Check your Lamp Fan see if it quits running while turning set on,if it starts and stops it is defective, other wise Follow wires that Lamp plugs into it will connect to Ballast board that powers Lamp CK it Problem M/B Ballast Board.
Reset the lamp timer.
1,Connect the power cord.
2,While simultaneously holding down "menu","enter" and "down" on the projector, press "standby/On" on the projector and keep all four buttons pressed down until the lamp indicator starts blinking green.
"LAMP 0000H" is displayed, indicating that the lamp timer is reset.
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Have you checked that the lamp is working? If the lamp hours are too high, then the television will no longer function until the lamp is replaced and the counter reset.
When you have replaced the lamp, do this process to reset the timer:
1) Press the Menu button 2) Scroll down to the LAMP TIMER RESET option, scroll right to enter 3) Confirm that it is OK to reset the lamp timer by hitting the OK button. 4) The on-screen menu should confirm the lamp was reset correctly.
Is this the first lamp you have placed into your Infocus pj? If not, did you reset the hours when you did it last time? Otherwise that can also confuse the projectors internal system thinking there is NOT a new lamp in there and there for make it stop working once the clock hours are expired and over the 3000-6000 suggested hour life.
Let me know so I can help trouble shoot other possible problems.
