Question about HP PSC 1210 All-In-One InkJet Printer
Scans very very slowly. Thought it wouldn't scan at all. Left it. Just see half a page scanned. One cm at a time or so..
    Brigadier General:
  • 10,406 Answers
I presume that you mean "photocopies slowly".
Check the "resolution" of the scan, i.e., 300-by-300 or 2400-by-2400 or something else. Bigger numbers mean slower (but better) scanning.
Posted on Oct 09, 2009
Tip
How to speed up your PC? PC slow is caused by problems in the registry that...
How to speed up your PC? PC slow is caused by problems in the registry that accrue over time. Installing and uninstalling programs leave behind fragments — stray files, orphaned startup tasks, corrupted drivers. Over time the registry starts to get bogged down and conflicts emerge. Left unchecked, your system will become increasingly unstable, run more slowly and crash more frequently.
The Solution
RegTool is the easy answer to registry problems. It conducts deep scans of your registry to check for errors and conflicts, then repairs and optimizes the registry to peak performance and stability. Periodic scans will keep your registry "clean" and will greatly enhance your system's performance and stability. You'll see immediate increases in speed and decreases in system conflicts. Do a free scan and speepup your PC now!
on Feb 21, 2010 | Office Equipment & Supplies
SCANS BUT WILL NOT ICK ANY CHANNELS AND HAS NO
Turn the scanner on and volume up all the way, turn the squelch until you hear static, then turn the squelch down slowly until its silent, press scan, has it ever been programed? Just a thought. hope this helps..
Mar 25, 2010 | Radio Shack Pro-94 Scanner
Line on printout from scans and copies
Clean the glass AGAIN. I had this issue for weeks. Drove me NUTTTTS! Because I to cleaned the glass. But guess what... not well enough. On your glass there is a tiny .. maybe the tiniest of tiny.....speck somewhere. that causes this line. Trust me I did everything you did and I just knew it was the drum or something. But it wasn't. Sure fire test. Have someone fax you something directly to the machine. (you need something that doesn't pass over the glass) If it prints out fine .. no line... there is a speck on your glass!!! And anything copied, faxed or scanned from your unit will have that line. Ofcourse you have already done half the test yourself if you print something from your computer and dont see the line. Because a print would not pass over the glass either.
Oct 02, 2009 | Brother MFC-7820N Printer
The scanner only scan one side fully
If the bottom is vertically split, then there could be some problem in the hardware (bottom scanning module) Check for loose contacts. If it is cut horizontally, it must be definitely loose contat problem.
S. Mohan, India
Aug 16, 2009 | Canon DR-3080CII Path-Through Flatbed...
If I put a large amount of paper in my canon dr-9080cscanner, it only part of the page until ti gets to a specific part. For example I put in 100 pages and it scans the middle inch and a half until it gets...
I could not understand your problem clearly.
If I am right, you are saying that if you scan 100 pages, about 80 pages are scanned properly and the there is problem with the balance 20. Clean the rollers throughly with a damp cloth and also the ****** rollers. Please swithc of the scanner when you are cleaning the ****** rollers as they are in a 'locked' position in power on position.
If your problem is different, please explain it clearly.
S. Mohan, India
Jul 08, 2009 | Canon DR-9080C Path-Through Scanner
HP Laserjet3030 steaks/lines in flatbed photo scans.
Are printed pages clean?
If so, clean the narrow strip of glass on the left side of the main scan glass.
If printed pages are dirty as well, then probably a defective toner cartridge -replace
*please rate me:)
Mar 24, 2009 | HP LaserJet 3030 All-In-One Printer
Not scanning full page Canon DR-3080II/CapturePerfect
U should select 'Scanners maximum'  and try this. I have found this does not work midway, after some scans. So close and exit out of captureperfect, re-enter and try. This should work.
S. Mohan
Nov 19, 2008 | Canon DR-9080C Path-Through Scanner
Won't scan full page
In the control panel for the scanner, on the bottom left is a button labeled "Specify," where you can adjust how much of the page it scans. Sometimes it is "auto-detect," sometimes it is the size of a small photo, sometimes it is full page. You just have to set it to what you want. Usually auto-detect works, but sometimes it misses and only scans part of a full page, so you have to set it manually to full page.
Apr 15, 2008 | Canon Pixma MP500 All-In-One InkJet...
Photocopying a book
yes, there is a button for book form.
it will either be in additional functions or duplex mode.
when copying leave book open on glass it will scan the first page then scan the other page. you can have it on two different sheets or one double sided sheet.
Good luck.
p.s.: it should be in the user manual also if you have it.
Nov 15, 2007 | Canon imageRUNNER 5000 Copier
HP PSC 1210 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
