Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
Replaced ink and still does not show any ink - Kodak EASYSHARE 5500 All-In-One InkJet Printer
    Problem Solver:
  • 9 Answers
Go to kodak.com , tech support, pick your model of printer out and follow the the instructions by answering a few questions. It sounds like a print head problem , which is an easy fix , but they will decide what you need , if it's just the print head they will send you one and you can switch it out in a few seconds, and be back to printing again. Oh! don't forget to run the clean printhead option under main menu on the printer first.
Lola
Posted on Oct 10, 2009
How to read ink levels in an epson nx110
All Epson printers (well, the ink ones) have a small utility built-in called the STATUS MONITOR. If you click on the MAINTENANCE tabbed page in the Properties, you can start this just by clicking on the item. It will show the ink levels. Normally, this status monitor should start up whenever you print - with an option to show the ink levels, as they do not auto appear when printing, compared to the option shown above. Note that the monitor does NOT actually shown the real ink levels as the chips on the cartridges and the internal electronics within the printer simply work on the number of prints made - so often when showing empty - there will in fact be ink left unused inside the cartridges. For this reason alone, worth your while getting some refillable cartridges and bulk ink (normally in 100ml bottles - so you would get equivalent about 10+ refills and save lots of hard earned dosh!) but you would also need an inexpensive chip resetter. My advice is get the refillables with ink (most compatible inks are as good as - some better - than Epson's own expensive original cartridge inks) and when one cartridge shows requires replacing, you remove all the cartridges, fill them all, reset the chips and replace - that way you show all as full and on ly have one cleaning cycle - thus also saving lots of ink normally wasted when replacing one cartridge - each requiring a cleaning cycle and loss of other inks. I have no idea where in the World you live so cannot recommend a supplier - just use ebay.com or amazon.com to find suitable suppliers convenient to yourself.
May 29, 2014 | Epson Stylus Multifunction Inkjet Printer/...
#324 chak printer alram cameing
when you power on your fax machine and display show DATA ERROR its mean that 3 volts battery on the main board expired and lose all data fax number, logo and related with cartridge ink data so first of all you replace the battery. (this is a pure technical job and if your are not a technician you must take help of a technician)
After replacement of battery you power on fax machine and press
function key display show DATA REGISTRATION
press # display show #1SSSW
press left arrow key one time display show TEST MODE
press start/copy key display show TEST MODE [1]-[8]
press # display show AMI MODE
Press 7 display show FACULTY 1-6
press 5 display show INK CHECK 1-2
press 2 and start key
display show INK=YES and INS (ink level any one within 100 for example 42/205 you just remember first two digit of lest side)
press stop display show FACULTY 1-6
press 6 display show LOST INK CHECK
press start/copy key display show LOST INK CHECK [1]-[2]
press 2 display show SET LOST CNT
press start/copy key display show LOST INK= (here you enter the last left side two digit which you remember for example 42)
press stop two times
and unplug fax and plug again now your fax machine is okkkkk
NOTE:- If you can't get the success first time you must try until you get the success because this is the only way to get success
Jun 11, 2012 | Canon FAX-L250
MY EPSOM CX 5500 WILL NOT PRINT. i HAVE A RED LIGHT PERM ON BY THE INK ICON. i HAVE TAKEN OUT THE CARTRIDGES SEVERAL TIMES AND RESTARTED BUT NOTHING HAPPENS. tHE CARTRIDGES HAVE INK AS FAR AS i...
Hello, This happens with epson as it has a chip on the cartridge, which sometimes shows the cartridge empty even if there is some ink left on it. You can try this steps:- 1. With the printer turned on press the ink replace button, which will bring the print head to ink replacement position, pull out the cartridges one by one and cover the tip of the cartridge with some tape and shake the cartridges and reinsert it on the printer and press the ink replacement button once again, the printer will check the inks cartridges, if the inks is empty it will show the red light again, pressing the button once will bring the printer to ink replacement position with the cartridge to be replaced on the replacement position. you can also check on the printer software on the pc that which ink cartridge is emptied.
Hope this helps.
May 14, 2011 | Epson CX4400/CX5600
No Cartridges. Open Scanner cover, then reinstall ink cartridge. All Cartridges are full
No Cartridge will show on the display if the machine cannot recognize one of the cartridge or one of the ink is empty.
To make sure about the real issue unplug the mach from the power outlet then plug it back in after 10 seconds.
If the display show: "ink empty C" it means the cyan/blue needs to be replace. "ink empty M" it means the magenta/pink needs to be replace. "ink empty BK" it means that the black needs to replace. If the display shows "ink empty Y" it means that yellow needs to be replace.
Even if it looks like the cartridge is full, it really needs to be replace so that the machine will work again.
Hope this helps. Rate if it works. Thanks
May 05, 2011 | Brother MFC 210C All-In-One InkJet Printer
How to reset ink level canon iP 2772??
Download and run the ipTool to reset your ink level :
http://www.mediafire.com/?nmj5nnzzjaw
Features IP Tool software:
  • Showing all info on the printer such as ink level, ink counter number of cleaning, cartridge replacement and more.
  • Print test feature to test nozzle on the cartridge.
  • Cleaning and deep cleaning feature to clean head cartridge and cleaning the rollers.
  • Changing the delay value for drying.
  • Set the printer model manually.
  • Reading and reset EEPROM printer.
  • Reset counter and reset ink level on the color and black cartridges.
Ink Level - shows the level ink:
  • BK - black cartridge.
  • CY - Cyan cartridge.
  • MG - Magenta cartridge.
  • YL - Yellow cartridge.
  • WM - Waste ink counter status.
  • WP - "additional" waste ink counter status.
Port Name - displays the port where the printer installed.
Port S / N - shows the serial number of the printer port.
Power - shows the number of:
  • ON - inclusions printer.
  • OFF - to turn off the printer.
Cartridge Info - Displays information status of:
  • CL - colored cartridge.
Head Parking - displays the number of parking.
Head Cleaning - shows the number how many time the cartridge cleaned.
Head Deep Cleaning - displays the number of deep cleaning Printer cartridge.
Cartridge Replacement - shows the number of cartridge replacements:
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 20, 2010 | Office Equipment & Supplies
Shows black ink full but not printing
Call kodak @ 1800 421 6699 and they will replace the entire printer for you free of cost. Have a happy experience.
May 01, 2009 | Kodak ESP 5 Printer
Out of ink
In case you have not already found a solution....
Go to:
MP620 Support
Select the "Support & Service" tab if it is not already showing.
Type insert ink tank in the space to "Please enter your question" block.
"How do I replace or insert an ink tank?" should be the first result showing.
Click on that link and it will open up detailed instructions with pictures on replacing the ink.
Thanks for using Fixya.
Apr 27, 2009 | Canon PIXMA MP620 All-In-One InkJet...
Problem with replacing color ink cart. #5
Is it the right Cartridge you are trying to install please check and then check if the sensors are working.
Mar 31, 2009 | Lexmark X2600 InkJet Printer
Newly replaced black ink cartridge still shows up ink supply empt
have you used the printer properties menu to recharge the ink? Just right click on the printer icon, choose properties, click on the Maintenance tab and click on the ink cartridge replacement. You have already replaced the cartridge so just click through to the end. The last thing it does is recharge it. I think this must be where it decides it has been replaced and is full.
Dec 29, 2008 | Epson Stylus C86 InkJet Printer
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
43 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
