Question about KWorld PC to TV (0872880887527) Video Capture
When I hook it up according to your #3Hardware connection diagram I only get color strips, no audio no video
  • 7 more comments
  • sv_moxie Oct 07, 2009
    Did you see the picture of your product? It is a PC to TV converter. I hooked it up according to the instructions and the tv shows a group of colored lines and that is all, no audio no video.
    Please answer me I need your help The product is PC to TV. What do I do to make it work?? Thanks
    I have your PC to TV unit. I hooked it up to s-video, usb, 9 pin data cable and put it on CBVS. The remote works but the tv shows color stripes only no video or audio
    There are very few instructions. I hooked it up the way it said the data cable from comp to converter box, usb cable from comp to converter box, svideo cable from box to tv. There is no driver and the booklet boosts there is no drivers??
    That link does not come up there is a lot of other junk out there. I cannot find your download....
    I have been advised to download drivers. your info on the box says no drivers needed???? I cannot access the address you gave for the download. what is the answer.
    Alright Gents,
    Please help me figure this out. We purchased a brand new Majestic brand TV. It does not have a direct data cable hook up for the computer. We purchased the Kworld PC to TV converter and the best I can get is vertical colored lines.
    The directions that accompany this unit are pathetically lacking.
    Can you please tell me the proper installation of this Kworld unit.
    Thank you.
    Dale
    Greenspan,
    The email address you supplied ( http://www.kworld.com.tw/en/download.htm... ) does not work. Any other ideas young man.
  • sv_moxie Oct 11, 2009
    No I have to return the product it will not work for me. How do I cancel my account with you?
  • 3,741 Answers
See the installation is quite tricky and it requires to install drivers on some units which are non-compatible with the tuner.:
here the procedure: http://www.blaize.net/cms/index.php?option=com_content&task=view&id=492
click the link directly.it will tell you how to download the exact drivers and then how to install them and how to properly hook it up to successfully view tv.
thanks,keep updated and please do rate the solution positively.
Posted on Oct 07, 2009
  • 3 Answers
I had the same exact problem with my PC to TV only showing colored bars. I watched a lot of videos/read many forums to try to figure this out.
The solution was very simple.
I did two things wrong: 1) I was using a different VGA cable then the one that came with the unit. 2) My PC resolution was not set to 1024x768 so my tv couldnt read it.
MAKE SURE you use the VGA y-cable provided with the unit and MAKE SURE you plug the one labeled "PC" into your PC (as opposed to the other blue one labeled "monitor," which i dont use. it DOES make a difference)
Then i press fn+F7 (my particular hot key for external monitor display. every comp is different, so check yours online/in the manual) on my laptop. I had to enable the "XGA 1024x768" option under the "fn+F7 settings." (all i did was check off a box for this option and click OK. then i was able to use that option)
Once i did this, POOF!!!! Away went the annoying colored bars and up came my computer!! HOORAY!!!
So lets recap:
1) use the provided y-cable to connect PC to TVtoPC and plug them in according to its label.
2) make sure your hot key settings has the option for "Presentation on Projector and Notebok : XGA 1024x768" and enable it. (i assume xga=vga???)
3) once you click that resolution option, your picture should come up! (if not, then just reset the pc to tv and it should work!
4) just for reference, im using the S-video cable to connect my unit to the TV. but the choice is yours.
I hope this helps you with your problem!!
PS: I read that the computer needs to have a screen refresh rate of 60 hz. This is accessable thru right click->preferences->display settings->advanced settings->monitor->refresh rate. I didnt need to mess with this cuz my PC already had that setting. the resolution was the actual problem.
PS #2: I saw many videos on youtube saying that you needed to switch to monitor 2 under the display settings. this is contrary to my setup. I am still using monitor 1. just with the 1024x768 res. instead of my normal 1400x1050 resolution.
Sorry if this is really wordy! Hope it helps you solve your problem and keep you from throwing your PC to TV out the window!!
KG
Posted on Dec 27, 2009
    President:
  • 1,734 Answers
You will need to install the correct drivers.
Find them here:
http://www.kworld.com.tw/en/download.html
    Brigadier General:
  • 3,614 Answers
What is model please... What problem have you encountered out there?
  • micromaster
    micromaster Oct 07, 2009
    this could be a incorrect cable connection, check the connection from comp to tv, make sure driver was installed, and adjust the pc screen resulotion into lower range
  • micromaster
    try to change the Svideo cable, it seems that your problem is only in there..
Connect a Wii to VCR
Hello
Take the Wii's audio/video cable and the power cord and hook them up in the back of the Wii.
Take the Wii's audio/video cable and plug it into the 'audio-in and video-in sockets on your VCR.Make sure you match the cable colors with the input colors.i.e white goes with white,yellow with yellow and red with red.
Take the RCA cable which looks like the picture below,
and plug one end of this audio/video cable into the 'audio out' and 'video out' ports on the VCR.Make sure the cable and ports colors match.
Now take the other end of the RCA cable and plug into the 'audio in' and 'video in' ports on your TV.Again make sure you match the color connections.
Hope it helps.
Ken
Jan 22, 2012 | Nintendo Wii Console
Tip
How to Wire a Flat Panel Television with no wires showing
  1. Place all the components, TV, speakers, etc. where you want them. Don't worry yet about how to wire them.
  2. You may want to turn all equipment sideways on the shelves so you can get to the connections in the back.
  3. Plug in all the power cords into a power strip, but don't turn on the strip until you are all done.
  4. Learn to differentiate audio and video. Video connections are often yellow, audio connections are often Red and White, but newer systems can have more varieties. You'll need to make sure the color you are plugging in is the same for both ends of the cable.
  5. Start wiring all the cables. You can see that all the cables and connections are clearly labeled and color-coded.
  6. Use the concept of 'signal path' to connect the necessary OUT's to IN's. Cables are needed to give the signal a path to travel from one piece of equipment to another. OUT of the antenna, IN to the VCR. OUTof the DVD player, IN to the TV. OUT of the receiver, IN to the speakers etc.
  7. Follow this guideline when hooking up equipment:
    1. The wall (cable/antennae/satelite)
    2. Things that send out signals (TiVo/cable box/set-top box)
    3. Things that record (VCR/DVD Recorder/Computer)
    4. Things that play only (VCR/DVD/Receiver)
    5. Things that display (TV/Monitor)
  8. Turn everything on. If necessary, switch channels and settings to match the labels on the connections you've just made. Enjoy!
on Dec 03, 2009 | Televison & Video
Comcast is useless. Got a Motorola 6200 from comcast office. Diagram was for 3 hookups. Physical cable they gave me has 5. Colors don't match. What do I hook up to what? How do I activate? Their phone...
if you are using HD. the colors do not really make a difference so to speak. just make sure whatever you hook to the red video goes to red video of tv and same with blue and green. then the same with red and white audio (some cables come with 3 thicker and two thiner to help with which should be audio and video) try 1800comcast
Jul 13, 2010 | Arris DCT6200 DTV Receiver
Tried to hook up hd cables and seems good but no audio tried to hook up but can't get to work
You cannot get AUDIO from Component Video, as it is only VIDEO, you must get another set of Cables RED & WHITE, and connect them from the AV, AUDIO Jacks, OUT on the "Sender" The DVD, Receiver etc, to the AV AUDIO IN on the TV. So you will have 5 Cables connecting BOTH Video & Audio. The Component Video, uses Blue, Green, & Red, these go color to color on the RCA Jacks at BOTH ends PLUS the Red & White Audio, color to color at BOTH ends. .Hope that clears things up.
Feb 14, 2010 | Hitachi 46W500 46 in. TV/DVD Combo
I have an old DVD player from 2002 & I'm trying to hook it up to my TV (old TV too). Do you have a graphic of the hook up? The TV has a spot to hook up my cable for my basic cable channels. The DVD...
You connect up a DVD to a TV via the Audio Visual leads, they go into the Red White, the Audio, & Yellow, the composite Video. In & Out. They wire color to color. Then you select AV on the TV. & press Play on DVD.
Feb 07, 2010 | Toshiba SD-2800 DVD Player
I need to know where to plug in my connectors for my cable box. I have two red ones and one blue one I can't find the right holes to plug them in. I have a green one and white one fixed so I have a black...
This would be 5 pins, red-white is for audio and rest of 3 pins red-green-blue for video signal, it calls component video.
Find out red-green-blue jacks at back of TV that would be label as Y, Yr, Yb
Plug each pin in same color to get color picture.
Jan 08, 2010 | Proscan 32LA30Q Television
Hooking up Coby Csp-94 Speaker to HDTV "no directions"
The green, black and beige cable is non-standard and proprietary meaning that Coby has defined their purpose which hopefully is described in your user guide. It would be worth a few dollars to buy the properly color-coded cables to uncomplicate your setup. Buy cables (or cable sets) that have the same color coding as your TV jacks along with the cable suggested below.
There are several ways to connect to an HDTV system and these are normally standard as previously described.
The red and white are for right and left channels and it isn't uncommon to see a three cnductor cable with one not connected since one of the methods of connection is to supply audio via two cables, video (composite) via a 3rd which is plugged into a corresponding jack, normally colored yellow. Audio cables aren't really required to carry the mix of much higher frequencies of composite video.
If you have the following connectors, try this:
- S-Video (this does not contain any audio information and requires an S-Video cable) - Right (red) and left (white) audio paths.    The S-Video connection provides a better signal that gives you a noticeably sharper picture. This setup is selected from the TV's input source menu.
Sep 07, 2008 | Coby CSP-94 Speaker
Will not work
Hi, you'll want the 3 colored RCA cable to hook this up to an older TV.  Yellow is for Video Out on player and Video In on TV.  Then, on player, correspond the red and white to their holes for Audio Out, and match them with Audio In on your TV.  You may have 2 spots on your TV that are labeled Audio In.  Try them both - the one that works should very close to you Video In line.
Hope that helps!
Dec 07, 2007 | Protron PD-800 DVD Player
KWorld PC to TV (0872880887527) Video Capture Logo
406 people viewed this question
Top KWorld Televison & Video Experts
kenwal
Level 1 Expert
Oluwadamilola Adu
Oluwadamilola Adu
Are you a KWorld Televison and Video Expert? Answer questions, earn points and help others
