Question about Motorola Mobility RAZR V3
Razor 3 speaker littl crackling sound how do i fix my self
  • sixty8frbrd May 06, 2008
    while playing music or any type of sound through the spaeker phone speaker there is a horrible crackling noise if i have to replace the speaker where can i get it done or where can i get a new speaker to do it myself.....i
  • 3Dog Jun 02, 2008
    My Razor's speaker is fuzzy at any volume. Very hard to understand the caller
    Brigadier General:
  • 7,752 Answers
Get the speaker replaced.
If you know how to do it you can replace it yourself
Posted on Dec 25, 2007
Why hp laptop speakers crackle?
goto your control panel and click on the speaker icon and see if its all set right.
May 26, 2014 | HP Pavilion 11t-n000 x360 - ENERGY STAR...
Dell xps 15 L501x sub woofer giving crackling sound
hi you can detached or disconnected the subwoofer cable, for temporary or permanent fix, as the speaker sound also produced good quality sound..
here how i disconected the subwoofer cable, it easy to find at the bootoom, see also utube video inside the link given below
Aug 09, 2013 | Dell Xps 15 L502x Subwoofer Speaker Pn57g
I have a Marantz 2275 receiver hooked to some JBL speakers. I noticed one of the speakers crackling. I swithched the speaker wires around and now the other speaker crackles so I'm guessing it is
Doesn't sound like it's a speaker - more likely a fried chip or transistor causing harmonic distortion.
It's usually more cost effective to replace modern audio components than to fix them.
Nov 21, 2017 | Audio Players & Recorders
My mackie thump amp will start to have a loud cracking sound. The cracking goes away if I have the input line unplugged from the speaker but with it plugged in it has the cracking sound and it does not...
Crackling is usally one or two things my guess would be bad grounding of the amp or bad connection with the jacks or plug it self try to make it crackle on purpose by jiggling the jacks see if it has any effect on the crackling try to narrow your possibilitys
May 04, 2011 | Mackie TH-15A Active DJ Powered THUMP...
My radio speakers crackle & distort very badly--I've never played them loudly but can bearly stand to listen to radio?? Is there a fix w/o replacement?? Thanks
Blown speakers in a 2006 should not be an issue, especially in a quality vehicle. You may just have a loose connection at the stereo causing the crackling sound. If you are not the cars first owner the previous owner may have been enjoying the bass a little too much and caused damage to the speakers, but I would check the connections first.
Dec 14, 2010 | 2006 Mercedes-Benz E-Class
Sound fluxuates,crackling sound samsungTX-R3079WH sound goes up and down automaticly
If the sound FLUCTUATES up & down, try turning off the AutoVolume in the sound menu. You didn't say if it's one or all speakers crackling. Crackling is either a speaker or circuitry issue. Adjust the balance away from the speaker that crackles, if it stops, that speaker is probably "fried". If it still crackles, I'd turn off the speakers and run the sound thru a stereo for the quick, cheap fix. My Samsung (10+ years old to be fair) crackles due to a circuit issue but if I SMACK the left side speaker (behind which is the sound board and side panel connectors) it stops for a while. Maddening. I think I broke it squeezing it into the furniture it's in, pressing on the protruding RCA plugs. Dumb design.
Aug 15, 2009 | Samsung SlimFit TX-S2783 TV
Crackling and popping sounds in surround sound speakers
Could be your head unit or the connection to the speaker may be bad. Also if the wire to the speakers in your ceiling is bare and touching any ground it would interfere. Start by checking connections by playing something and messing with wires. Listen for a difference. Next check by putting the wires that power those speakers in a known working output and listen for different quality
Apr 04, 2017 | SpeakerCraft 8" 150W In-Ceiling Speaker...
Crackling Speakers
That because maybe due to your itunes player which the installation got error..please try another player other than Itune or play it in windows media player or some other player which you think good player.
Or try reinstall your player or update it.
if this not resolve the issue, then verify the connection of your sound card maybe got grounded to other components making the sound crackle..Or you may try attached a grounding wire from your stuff directed to the ground or attached in any metal that is connected to the ground to eliminate noise.
please tell me what ever result for further analysis
Feb 10, 2009 | HP Computers & Internet
SoundDock produces only harsh crackling sound
Yeah i had that same problem. You know the chord? The cord you plug in from outlet. The square cord you plug into your speakers.. yeah the "DC outlet" is supposed to be UP. if you have it the wrong way in there it wont work and will make a crackling sound.
Apr 30, 2008 | Bose SoundDock Digital Music System for...
Speakers Crackling and system keeps going to standby.
It sounds like you may have a problem with the sound pc board. If the system shuts down or goes into a stand by mode, then it means the system is detecting an internal problem and is shutting itself down to avoid any further damage. You may need to have it serviced but that could be a little expensive. You can always buy a used replacement receiver if the speakers and sub is still working good.
Hope that helps.
Dec 31, 2007 | Sony DAV-BC150 System
Motorola Mobility RAZR V3 Logo
141 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
