Question about Panasonic PT-50LC13 50" Rear Projection HDTV
Pt-50lc14 OSD message: "Clean Air Filter" but I can't find it...It is not behind lamp housing.Can someone tell me where it is? Thanks
  • Ryno37 Jan 04, 2008
    I am getting error message stating clean air filter and tv shuts off. Red led blinks 5 times then stops.
Unplug the unit! Pull off the access silver panel from the front of the tv. there are 2 sma ll access panels on the front behind the silver panel. The one on the left, allows you to change the bulb, one screw to remove, Just to the right of it there is a second one. This has 2 small screws to remove to access the opening. Once you take this small cover off, you will see the fan compartment. On the top of it on the left side is one small filter, mine was pretty clean. The bear is the one on the bottom, that you can only see the edges, but there is a small opening on the bottom. It looks like it is suspended in mid air. Take a cue tip and clean the underside! I slightly wet my cue tip and it worked fine. I tried to remove the fan compartment, but it would not come out and I did not want to force and break it. Remember to unplug the unit first. After I used the cuetip on the filter, I have a small vacuum and cleaned everything carefully. I had heard to leave it unplugged for about two hours to let it clear after I reassembled the covers. I turned on the set and the message was gone and has never come back. I did not have to reset anythi.ng and worked for me. That was it for mine and it is working fine
Posted on Jan 11, 2008
Does my panasonic hdtv 1080i pt-50LC14 have a lamp
Yes it does! Behind the front bezel under the screen. you can buy it here. http://projectorlamps.com/panasonic-dlp-tv-bulbs-pt-50lc14.html PT 50LC14 Panasonic Genuine High Quality Original Projector Lamps now...
Refer to the manual or the instructions that are shipped with the lamp.
Apr 25, 2015 | Panasonic Televison & Video
Where is the lamp housing for the Panasonic
The lamp housing is located behind the front cover panel.When you open the front panel you can access the lamp unit screw.
thanx
Jul 21, 2010 | Panasonic PT-50LC14 50" Rear Projection...
Lamp reset on a panasonic model pt-50lc14-k
This works for mos Panasonics
Turn on Power
Pres and hold the "vol-" button on the front of unit and the "split" key on the remote together for over 5sec.
Screen should say " Lamp time was reset to 0"
Nov 12, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Picture quality on PT-50LC14
clean out the housing (where the lamp is) the go through your menu and check the tv settings ie...color temp, picture, contrast, ect...try resetting it back to the default and go from there
Nov 09, 2008 | Panasonic PT-50LC14 50" Rear Projection...
OSD Message Panasonic PT-50LC14 Air Filter Needs Cleaning
I had the same problem and the stupid tv would shut off after 1 minute. We opened the silver front panel , took the bulb out cleaned it, took the cover off the grey box to the right and very carefully vaccumed the filter and wiped it off with a microfiber cloth. It works great now!!! Make sure you unplug your tv before messing with it.
Sep 28, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Replace pt-50lc14 lamp
No it is NOT easy.. it really is a "Job for the shop" .... GL
Jul 23, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Air filter
air filter message is ussally generated by a tempsensor getting hot. could indicat falulty sensor.. is the fan running. a stalled fan could cause the problem but usaally when that happens it completley shuts down
Jan 29, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Panasonic PT-50LC13 50" Rear Projection HDTV Logo
386 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
