Question about ASUS P4B533-E (P4B533-E/L/1394) Motherboard
My SB light on my ASUS motherboard comes on when i plug in the power cord. when i turn it on, it show nothing.
  • 121 Answers
Make sure the ram, cpu, and graphics card is set correctly, otherwise, remove the battery, put the jumpers on clr cmos, then push the power button, while the power is still the in keep do ing it on and of, the remove the power again posh the on button, to make sure all the left over power streams has left the light should die, the put back the battery the replace the jumpers, then the power cord then try again
Posted on Oct 07, 2009
I have a Asus laptop that stopped charging and now all it does with or without the battery is flash a blue light continuously the orange light will come on and go off for charging the battery there is...
Try a hard reset. Remove the battery and power cord, then push and hold the power button for about 30-45 sec then plug just the power cord in, Also the battery could be shot but that is hard to tell how to check over chat. Good Luck
Jun 24, 2014 | Computers & Internet
What means sb pwr
'SB' stands for StandBy. When the motherboard is connected to the power supply but not turned on the SB voltages are supplied to different parts of the motherboard. In some motherboards you are able to charge devices like Phone without powering on the computer, that's because of the SB.
The SB in turn triggers other voltages used for the motherboard.
Oct 13, 2013 | ASUS M2N-VM DVI - Motherboard - micro ATX...
ASUS laptop will not charge and now will not turn on even with plug in as charging light does not come on.
If charger is ok, problem with power jack or motherboard. probably the charging circuit in the motherboard. contact a good chiplevel service technician. hope it helps
Dec 01, 2012 | ASUS Computers & Internet
When i plug up my monitor it want come on
Hi ' does power indicator light show when you switched on the power. if not '' try to insert power cords properly and electrical outlets and still not working , you cab ask for a repairmna\\an to check your monitor.
Aug 04, 2012 | ASUS A7V8X-MX SE Motherboard
I have a asus p4p800-vm motherboard I have everthing hooked up right the front panel wires power from the processor and power supply led lights hdd reset everthing but when I plug the computer up nothing...
Hi, maybe you should download a manual.
From here:
http://www.asus.com/Motherboards/Intel_Socket_478/P4P800VM/#download
Just to check you have connected everything right.
First select your operating system.
Select manual and click on global for download.
The file has to be unziped before you can read it.
Have you installed the ram module and cpu correct ??
If you have installed a wrong type of ram it will not boot at all.
Does it makes any beep sound ??
Is the powersupply ok ??
If you are useing the onboard graphic check for loose connections.
Check with the manual that all connections are in order.
Aug 28, 2011 | ASUS P4P800-VM Motherboard
When I plug my computer up nothing comes on but the green light on the motherboard but when I plug the power supply to the motherboard half way in the processor and the power supply comes on but its like...
This is really poor practice and an excellent way to destroy a motherboard.
You should always have the board connectors plugged in before turning on the power supply, otherwise you may be blowing ICs left and right. It's perfectly OK to plug the supply into the wall or turn on its power switch with the board connectors in place. Also, nearly all modern boards have a set of pins that go to the front panel 'power' switch which does not switch AC but sends a logic signal to the power supply to turn the rest of the voltages on. Those pins have a 5V potential on them that is typically grounded to tell the supply to turn on.
If you're lucky, you still have an undamaged motherboard.
Aug 28, 2011 | ASUS P4P800-VM MB, 865G/ 800FSB/ SATA/...
I have my rest and power hooked up in the right plugs but nothing is happening only thing comes on is the light to the motherboard when plugging the power from the computer case to the motherboard the...
Hello
You may have the reboot or restart wires backwards.Or on the wrong pins on the motherboard.
Here is a link to your mobo. Shows correct hook up.
Also be sure your memory sticks are in proper slots.If you have 2 they need to be seperated.
One in one channel the other in the second channel slot.Usually the slots are color coded.
http://dlcdnet.asus.com/pub/ASUS/mb/sock478/p4p800-vm/e1338_p4p800-vm.pdf
Aug 09, 2011 | ASUS P4P800-VM Motherboard
ASUS p4s533 will not start
Your motherboard is bad and will need to be replaced.
Thanks and please take a moment to rate as fixya. Thank you.
Jul 08, 2008 | ASUS P4S533 Motherboard
ASUS P4B533-E (P4B533-E/L/1394) Motherboard Logo
392 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
