Where do I buy adhesive clips to attatch cable to roof of camper van please?
    President:
  • 1,653 Answers
You should be able to buy them at most electronic component and hobby stores.
Posted on Oct 07, 2009
I want to install an air conditioning unit on the roof of a 1995 ford econoline van. How do you do it?
The air conditioners on RVs are 110 volt AC. They do not run on 12 volts and should not be run on inverters. You would need at least a 2000 watt generator, preferably 3000.
If you have the power, it requires cutting a 14 inch square hole in the roof. The air conditioner is clamped down by 4 bolts from the inside, part of the internal control package. You would need what is called a "non-ducted" inside unit which would have the thermostat and control knobs.
Mar 14, 2015 | Heating & Cooling
How do I shift the radio antenna off the roof of my Mazda BT50 onto the bullbar?
remove the roof antenna ( unscrew off the mount) buy an aerial for the bumper. run the coaxial cable back to the radio and pull the existing cable out and after fitting a connector on to the end of the new cable plug it into the back of the radio. It will be a lot of trouble to remove the existing cable and roof mount and you will need it at a later date.
Mar 11, 2014 | Mazda Cars & Trucks
What kind of glue can i use to glue .030 4 ft by 8 ft aluminum sheets to plywood for exterior use ie camper
You can use Loctite PL Premium 10 fl. oz. Advanced Polyurethane Construction Adhesive or liquid nails adhesive. The PL may be available in a pail. It will permanently glue aluminum and plywood together.
Jan 31, 2014 | Adhesives, Coatings & Sealants
Starter motor cable coming adrift
I'm sure it is the solenoid connection. Replace the push on connector.
Oct 10, 2012 | Cars & Trucks
Was given a roof top ac for a popup camper need help
Make and model of unit should be on base of roof assy, please reply with that so we can be sure we have right wiring info for you. Although they are pretty common, let's be sure.
Jul 30, 2010 | Dometic Rooftop RV Air Conditioner
Replacing the ''wood'' in the top(ceiling) of a pop up camper. Cant seem to find a correct listing for this in the menu.-----------but this is for a Tracker pop-up camper. It started leaking around the...
i would suggest getting a price on the entire roof assembly from a dealer depending on age these roofs can be lminated togehter ang removing the skin car cause strustural damage to the camper roof it is common practice to stop the leak remove most of the wet wood and overlay what is left standing sounds bad but only way to fix cosmetcally if you need to soarce parts do a search for all right manufacuring they supply celing and metal for most camper manufacures
Jun 22, 2009 | Rv Motorhome Dual Co & Lp Gas Alarm...
Cable broken
Depends where it is broken but you can buy cable splicing kits that enable you to join two broken ends together , any good caravan supplier would stock them , hope this helps smirf617
Jun 02, 2009 | Sport & Outdoor - Others
Delaminated TOP on Coleman Camper
If you have to fix it yourself out of warranty i suggest this ,
REGLUE ALL THE BITS THAT ARE COMING AWAY , THEN FIND A GLUE THAT IS SPREADABLE LIKE A THIN PAINT AND COAT THE ENTIRE ROOF MAKING SURE THAT IT GETS INTO ALL THE CRACKS , LET IT DRY .
THEN PAINT THE ROOF WITH A THERMAL MEMBRANE COATING . This will insulate the camper from the sun and keep heat in during colder times , the thermal paints are not cheap but they do work . Hope this will help you
May 05, 2009 | Tools & Hardware - Others
Broken cables to lift roof
http://www.customcylindersintinc.com/camper_trailer_roof_lift_system.htm
This should help, Pictorial and instructions. Also parts available.
Thanks for using Fixya
Jerry
Mar 24, 2009 | Sport & Outdoor - Others
Cylinder seal
for most dryers,
Go buy HiTemperature silicone adhesive (tube)
tools required couple pairs locking pliers/visegrips screwdrivers
Unplug dryer
remove the front cover, either
  • couple screws at the bottom and spring clips to pop off with a screw driver OR
  • couple of spring clips to hold the top lid on, then screws top and bottom of both sides
    examine the case to find the exact mounting
unclip cables from door switch
set front panel aside
unhook drive belt from tensioner pulley
pull drum forward and out
remove old felt
scrape off old adhesive
put adhesive per instructions (some 2 surfaces some 1) on drum/felt
clip felt in place on drum with visegrip at 1 point
stretch felt around drum, gluing and clipping in place with vicegrips as you go
allow glue to set
reassemble in reverse order
wow took longer to type than it actually takes to do it
Jun 04, 2008 | Maytag Dryers
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Electro Med Services...
