Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RCA D52W20 52 in. Rear Projection -HELP!!!!
My RCA goes on & off, scans though the menu changes setting on its own. volume goes up and down also
  • 4,234 Answers
As stated by TVtechlady, it is possible for the buttons to be stuck. With the set unplugged, try pushing each of the buttons one at a time. You should be able to feel the button engage. If one of them does not, then that is the likely bad one. Also, if there is some dirt caught between the button and the hole, it can create enough friction to prevent the button from returning to the "OFF" position on its own. Spray some compresed air around the buttons and work them a few times by hand. Plug hte set back in and try again,
It is also possible that the 5V supply inside the set is having a problem and is comfusing the set. Try working the buttons first and update this with the results.
Dan
Posted on Oct 07, 2009
Testimonial: "Thank you for the response, I will try it out and get back Thanks again"
  • 556 Answers
THE FRONT BUTTONS ON YOUR TV ARE EITHER STUCK OR SHORTED THEY NEED TO BE REPLACED
Testimonial: "Thanks sounds good, I will try it out, thanks again!"
My tv starts scrolling through video modes,and the menu screen constantly flashes on and off and i turn up the volume and it goes back down by itself,any thoughts how to stop this would be very helpful...
Thats caused by the Small signal board. which is the green board on the right side with all the inputs on it. Thats a very famous issue for RCA rear projection models.
Nov 07, 2012 | RCA HD52W140 52" Rear Projection...
Small signal board for RCA HD52W59
Thats caused by the small signal board located on the right side of the set ( Green board with the RCA plug inputs on it. Very common issue with that chassis. The board will have a barcode sticker with an as222 number. You can get replacement boards and any part needed for that model from www.tvrepairworld.com
Jan 28, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
The volume on my tv goes up and down and the menu pops up on its on and it randomly changes the channels
The small signal board needs replacement.nVery common problem. You can get a small signal board from www.tvrepairworld.com
Aug 07, 2010 | RCA HD52W56 52" Rear Projection HDTV
RCA D52W23 tv
Front Panel Board needs cleaning or replacing Call Encompass Parts 1-800-638-3328 and for just contact switches Call Mats 1-800-628-1118
Jan 18, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
MENU SCREEN POPS UP, TV CHANGES CHANNELS, TURNS SOUND DOWN
Yes. Its probably a stuck button on the TV's front panel. Try pushing or wiggling each button on the panel. It could be the channel up/down buttons or volume up/down, menu, etc.
When there is a button that is making slight contact, it keeps the microprocessor busy attending to the command its erroneously receiving from the offending button and may not allow other functions to work when this occurs.
It doesn't matter which button is stuck, any of the symptoms you describe can happen.
michtech
Feb 17, 2009 | RCA P52926 52" Rear Projection Television
Access Service menu
Hey there!
Its really easy to do, but write down any settings before you go changing them..
1. Turn off tv.
(use buttons on tv for this)
2. Push volume down and channel down both at the same time, and hold them for about 10 seconds, or until the tv turns on.
Jan 23, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
TROUBLESHOOTING VOLUME ON PROJECTION HDTV , RCA
did you go in to you menu and set you audio setting.
Feb 15, 2008 | RCA 32F531T 32" TV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
180 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
