Question about Alpine CDA-9805 CD Player
Engine noise coming through speakers
Same issue as the previous posting.
    Brigadier General:
  • 4,044 Answers
Make sure you are using resistor plugs, have a proper ground in the system, have good plug wires and are connected to the correct power line.
Posted on Oct 07, 2009
Static coming through the speakers even though the radio is unplugged and the fuse is takin out what worng?
After I read this whole post and the solution by other guy. I came to my own conclusion is that you may have an exposed wiring that causes the static sound out of speakers. Try to look for bare wiring that may have touch each other as well as touching the metal of the vehicle. Try to disconnect the wires at the speaker, and see if it works. If it does works, then you know that you have wiring issue there.
Mar 06, 2014 | 1996 Lincoln Mark VIII
2001 Toyota Corolla engine light is on, speedometer is not working and engine noise coming through radio speakers?
I would first check the computer for trouble codes. The speedo problem could be the speed sensor in the transmission.
Jan 15, 2014 | Toyota Cars & Trucks
My advent notebook has started to make a very loud buzzing noise intermittently, much too loud to be caused by mobile phone interference etc?
If the noise isn't coming from a speaker, you could need to replace the fan on your computer. The bearings for it might be busted, another issue could be the speaker wire isn't fully connected internally, which you could fix by popping off the top power panel area and fastening the speaker wire in it.
I hope this helps, if not I apologize. The question isn't super vague, but it still has holes in it. :) I can to help more if you post more about the issue.
Feb 23, 2013 | Advent Netbook
I just bought a 1996 lincoln mark 8. very good condition well takin care of. the previous owner told s there was something wrong with the stereo when we heard it it just sounded like a blown speaker. we...
It could be a ground wire. I'm curious did the previous owner install the radio? Sometimes people just install a radio to the nearest power,ground and remote wire without any precautions on what they tap in to. Part of what you are hearing is alternator and/or ignition noise. Between the two noises my concern is that the installer might have tapped into a blower motor wire for either power or ground. The noise itself can be fixed with a 20 amp noise filter such as this one http://www.amazon.com/Heavy-Automotive-Noise-Filter-270-055/dp/B000T306DY but I suspect a bigger issue. Either you or someone knowledgeable with car audio installation should pull that radio out and check all the connections and where they are tapped in to and install it properly. The engine noise itself can be fixed with the noise filter. This popping sound I feel is a short from mis installation. I have seen cars get dash fires from this. I never like to worry people but I am also honest. I would tend to this soon. Good luck.
Mar 21, 2011 | Lincoln Mark VIII Cars & Trucks
Just replaced a dead battery with a brand new one. Tried starting it and it makes a high pitch whining sound and wont start. Any suggestions of what the problem is? Does it need to sit to charge the...
The basics, your battery is used to provide power to the starter. Once the engine is running the alternator then provides current to recharge the battery and run all of your electrical components. so I would suspect the starter is not working to start the engine.
Feb 16, 2011 | Chevrolet Classic Cars & Trucks
My Logitech Z523 Speakers make a loud humming noise when plugged into my PC. When i plug it into my phone or laptop there is no humming noise. Sometimes there is a fuzzy crackling sound when it is not...
Mine did the same thing then I found the solution by accident. After reading a post about moving the sub to different positions and making sure connections were tight to the sub , I loosened the right speaker connection screws to the sub and noticed the humming stopped completely . I know it sounds crazy but it worked for me.
Nov 30, 2010 | Logitech Z523 2 Speakers
No sound - computer message says can't locate audio visual. Computer had been previously wiped clean because of a virus. Can I download and reinstall software? Make of speakers VS-2121?
It's not your speakers that are the issue most likely (as long as they are round ends with sort of a point (not sharp just like a .5" length cylinder like .25" thick) instead of a rectangular USB connection. If you post more information about your computer we could probably direct you to the drivers you need to download in order to resolve the issue.
Dec 21, 2009 | Altec Lansing VS2121 Computer Speakers
Sound
i had acer aspire 4220... When i play music there is no sounds from built in speaker but when i used headset it sworking... im ronald please help me this problem.
Mar 02, 2009 | Acer AOpen AW 200 Sound Card
Computer making weird sounds
possibly audio feedback, but don't know why. Try disabling the microphone input (for help, post back) as a test. If now gone, re-enable mic but decrease gain slider (for help, post back).
Nov 17, 2007 | Toshiba Satellite A100-S8111TD Notebook
Speaker issues
This is a duplicate posting, click on the following link to read the active post: http://www.fixya.com/support/t161863-loud_strange_noises
Jul 28, 2007 | Dell 5650 Computer Speakers
Alpine CDA-9805 CD Player Logo
46 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
