Question about Ortofon Concorde Pro Spherical Cartridge Silver Turntable
New Ortofon needles arent working w/Serato
Just bought Ortofon needles and they do not work with Serato. It makes Serato flip out. When on relative mode, it plays backwards then randomly switches to internal mode. When switched to internal mode it changes a bunch of the setting like the tempo and messes with the loops. Any idea why these needles arent working? when i go to the settings it shows the signal line as going straight accross
4 Suggested Answers
SOURCE: Playing songs backwards wit serato scrach live
I got it partially fixed. The black wire from the tone arm was broken so that been solder back on place nd the rca also the song is playing foward on channel 1 only, thats a start! New problem accuring now! Can't use that table to scarch now caus every time i do so the song goes foward only??? No back and forth in the sound??? I'll get a new tone arm and it should get everything better!
Posted on Dec 10, 2008
SOURCE: Concorde Ortofon Electro Stylus not getting a stereo signal
Soak a q-tip with rubbing alcohol and stick it into the contact area of your tonearms. Rub the contacts thoroughly. The contacts themselves are spring loaded, so make sure all four are all the way out for full contact. Clean the stylus connections with alcohol as well, and you should be good to go. I also use Ortofon Concorde stylii on my 1200s and have never had a problem.
Posted on Dec 31, 2009
TJBeta
  • 67 Answers
SOURCE: Song playing backward but table going foward with serato.
The RCAs seem to have been wired backwards... Meaning that the control vinyl is sending a reversed signal to the serato box... which means serato things it is going in reverse.... switch the RCAs from your deck to the serato box, regardless of their color.
Posted on Dec 09, 2010
Tonearm not emitting signal into Serato
there is a switch that cuts off the signal when the tone arm docks.check the wiring is not broken inside and that the switch is ok.typically,red green white black red and white are plus and left ground is green and right ground is black.the collar that screws on to the head unit has 4 pins.make sure the contacts are clean.measure the wires one at a time from the tone arm to the rca plugs on the back.the green and black go to the outside collars,and the red and white go to the center pin of the rca plugs
May 26, 2009 | Technics SL-1200 Turntable
What is tracking force and arm weight for Dual 505-2 deck?
http://ortofon.de/ should give you the weight. It should also give you the range of tracking force. To get the right weight you can use a stylus balance. The electronic ones are expensive but good. The mechanical ones are not great but better than nothing. I set my turntable up with an Ortofon-branded mechanical balance for weight, and a test record for tracking force.
Apr 09, 2009 | Audio Players & Recorders
Poor sound output
One of the wires from the stylus had a poor connection through the pin connector.
I recrimped the pin lug reconnected and all is now working as it should.
Jan 01, 2009 | Ortofon Stylus DJE Turntable
hi... swap the left and right rca cable.the one who said it works good on the deck but on the screen goes back ward....see what hapen..u
Dec 09, 2008 | Panasonic Technics SL-1200MK2 Turntable
Turntable skips during playback
The only thing I can say is to make sure you set up your cartridges correctly - click HERE FOR INSTRUCTIONS on BALANCING YOUR TONEARM properly.
If, you've balanced your tonearm, and set up your cartridges correctly, then you should not have any problems. Unless, your tonearms are damaged. But this is highly unlikely. I just think you need to balance properly.
Another note, Ortofon Concorde have a design flaw, in that they don't connect very well to the Technics tonearm. The Concorde's, have short and stubby connections on the rear, making for poor connections to the tonearm. Ortofon has addressed this issue by releasing the Ortofon OM series cartridges, and mount them to standard Technics Headshell.
If you still can't figure this out, feel free to give our techs a call 24/7 @ 1.866.668.1596 ext 1 - they can walk you through setting up, and properly testing your tonearm to see if it's damaged or not.
- DJ PRO LAB
www.DJPROLAB.com
May 12, 2008 | Technics SL-1200MK2 Turntable
Problem
Make sure your ground wire is connected. I know Serato does not work properly if your ground wire is connected.
Also, make sure your running the connection from the Line Out of the Serato box into the LINE IN on your mixer. You can use the Phono Input also, but I generally tell people to use the line input to avoid any issues. Regardless of which input you use, make sure that your Serato software is either set to LINE or PHONO, otherwise it wont run properly.
- DJPROLAB
Feb 14, 2008 | Technics SL-1210 Turntable
Technics sl 1210 turntable
What sort of problem are you having with the cords?
Sep 04, 2007 | Technics SL-1210 Turntable
Ortofon Concorde Pro Spherical Cartridge Silver Turntable Logo
193 people viewed this question
Top Ortofon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Ortofon Audio Player and Recorder Expert? Answer questions, earn points and help others
