Question about Radio Communications
YAESU VHF AM Transceiver VXA-100 battery doesn't
Http://media.mtvnservices.com/mgid:cms:mvideo:cmt.com:40319
http://media.mtvnservices.com/mgid:cms:mvideo:cmt.com:40319
YAESU transceiver VXA-100
battery doesn't charge...How do I know if it is battery or charger malfunction?
  • Jerry Willis May 11, 2010
    I take it it is in the aircraft band. Does the charger have a light? Is the battery new? Try another battery if you have one . Try another power supply if you have one. If not you will have to use a volt meter and check the power supply voltage and check the battery contact on the charger and on the battery. A good dead battery will still show some voltage on it.
  • 21 Answers
If this charger is one that plugs into the radio then you will have to take a volt meter and check the voltage on the plug. It should be close or slightly higher in voltage than the label on the power supply.
It most likely be that the transformer or the contacts in the plug are bad.
You could try and turn on the radio with the battery on and see if the radio comes on.
Posted on Oct 11, 2009
How to reset yaesu vx300 vhf radio transceiver
While turning on the device,at the same time push another button.One of the other buttons should re set the Yaesu.
Oct 10, 2014 | Yaesu Radio Communications
How ti unlock transceiver radio Yaesu FT 1900R to transmit beetwen 136 to 174 Mhz
Here is a link to a forum that has instructions for how to make the modification: http://www.worldwidedx.com/threads/expanded-tx-mod-for-ft-1900r.37171/
Aug 19, 2014 | Yaesu Ft 1900r Vhf Mobile 55 W Two Way...
I need a pdf of the manual, where can I get it?
www.manualslib.com > Brands > YAESU Manuals > Transceiver > VX-8DR I found one at the above site.
Jul 19, 2014 | Yaesu Quad-Band VX-8DR Submersible VHF/UHF...
VHF/UHF RF Power falls to Zero when the Auto ATU tunr logo is on the display. When the tunr logo is off the VHF/UHF RF power is only 10 watts on 2M and 3 watts on 70cms. The Yaesu FT 857 D should have no...
Check for open or shorted Veractor diodes and steering diodes there may be no direct interaction as you say but if a diode is open or shorted the RF circuits might still be selected for the higher bands and the lower output power on your vhf/uhf is an indication of this.
If you do not have a service manual you can get one hear, you will likely kneed one
http://www.tradebit.com/filedetail.php/127575994-vertex-yaesu-ft-857-ft-857d-2005-service-repair
Good Luck Best regarsds Falco
Nov 04, 2013 | Yaesu FT-857D transceiver
Software Menu Aligment yaesu FT-857
http://www.hampedia.net/yaesu/ft-857-second-menu.php this link lists the settings to put back to factory abc together when switching on to access
Apr 10, 2013 | Yaesu FT-857D HF/VHF/UHF Mobile...
I'am having some problems with vxa-100 getting verry hot
The walkie talkie is the heat sink. So on extended talk times, it will get hot. So will the battery. If you run full power, it is only worse. That said, some batteries will become abnormally hot with use. Usually OEM batteries are higher quality cells and seem to get a little less hot. Never buy the cheapest battery for a handheld radio. Some are pure junk.
Mar 25, 2013 | Vertex FNB-33, YAESU,FT-11R,FT-41R,FT-51R,...
I need an operator manual for Aviator Pilot
The VXA-210 manual is available for free at the Yaesu.com web site.
Feb 13, 2013 | Yaesu Ft-270r Vhf Ft 270r Ft 270 R
Yaesu ft 50r
The FT-50R is an extended receive, but dual band (UHF & VHF) amateur transceiver. It is capable of transmitting between approximately 144Mhz - 148Mhz VHF and 430Mhz - 450Mhz UHF.
Typically, the radio will provide an audible warning whenever attempting to operate outside of its intended range(s). The manual has a section on maximizing battery life, and can be downloaded below:
http://www.radioamateur.eu/schemi/FT50_user.pdf
May 25, 2008 | Yaesu NABC NABC LMR NICD BATTERY FNB-V47...
Radio Communications Logo
252 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
