Question about Fujitsu Siemens SCALEO 600 (FSP:83C005617) PC Desktop
What is the correct cmos battery - Fujitsu Siemens SCALEO 600 (FSP:83C005617) PC Desktop
  • 2,229 Answers
Most modern desktops take a battery with the number CR2032
Doesn't matter who makes it.
The battery is round and about the size of a US nickel
Posted on Oct 07, 2009
    New Friend:
  • 161 Answers
Usually the motherboard batteries are just button batteries (#2032)
Is my CMOS battery the problem to the time and date not automatically correcting itself, or is it something else?
The CMOS battery is the main cause of your time resetting. Although it usually resets further back. Double check your time setting in the operating system itself. If everything is correct then the source of the problem is more then likely the CMOS battery. Batteries are pretty cheap so not hard to replace. If it is a desktop computer (if you're comfortable with it) open up you computer and what looks similar to a watch battery and that is what you will need to replace.
Note* IF it is the CMOS/ BIOS battery it will only reset the time when you lose power to the computer or turn it off.
Oct 04, 2012 | Computers & Internet
Start-up and shut down problems, When starting up it says, press f1 to continue, f2 to run set-up.... F1 works but I am getting tired of doing this. Now when the computer starts, it stops at...
Hi names Rui,
For your problem the computer may display a prompt to press F1/F2 or any other key to enter setup each time the computer boots as a reminder on how to enter CMOS. However, if the computer asks to press F1/F2 (or another key) to enter setup and does not continue, this may be caused by any of the below reasons.
  1. New hardware has been recently installed.
  2. Error or confliction with settings in CMOS.
  3. CMOS battery is bad or failing.
Solution:
If new hardware has been recently installed into the computer, it is likely that you are receiving the prompt "Press F1 or F2 to enter setup" because CMOS needs to verify that the new detected hardware is properly being setup in CMOS. Enter CMOS setup and save the settings and exit. If you continue to get errors continue to the next step.
If no new hardware has been added or you continue to get this prompt verify no error or conflictions exist in CMOS. Press the key to enter setup and verify that all settings are correct.
If your time and date are not set correctly, your battery is more than likely bad. Try setting the correct time and date, save the settings and then reboot. If after turning off the computer the time and date get reset again replace the battery.
If the time and date are correct and everything else appears to be correct try resetting the CMOS values to the defaults.
If you continue to receive the prompt to enter setup each time the computer boots up and you have attempted to follow the above suggestions, your CMOS battery is bad. We recommended that the CMOS battery be replaced.
hope this will help you.
Jul 20, 2011 | Dell Dimension 2400 PC Desktop
Replacing cmos battery
When replacing the CMOS battery just get the correct battery.. I believe most CMOS use CR2032. adracamas_0.jpgLooks like this.
Real simple. Press the metal tab on the right away from the battery and it should pop right out. Replacing it is usually as simple as placing the new battery in the opposite side of the metal tab (to get it under the lip) and pressing it into place. You may have to push the tab out of the way in some models.
Mar 29, 2011 | Computers & Internet
How to know if the battery of the motherboard is empty
use multitester to check the battery of the cmos..
set the multitester to DCV 10..
and watch out for the pollarity of the battery..
Mar 18, 2010 | EliteGroup ECS GF6100-M754 Motherboard -...
''Firmware has detected cmos battery failure''
CMOS battery in the motherboard much measured .3 volt which is a Lithium coin cell battery.check whether the battery gives the correct measurement (recomend to use branded battery like from sony).
if the measurement is correct then reset your BIOS setting by removing all the jumper in the motherboard for about 60 secs.and place it again and start your pc;set yr BIOS to default setting,
let me know if it comes handy to you
Dec 04, 2009 | Intel Computers & Internet
MY LAPTOP(hp compaq presario v2000)BEEPS TWICE AND DISPLAYS PRESS F1 TO RESUME OR F2 TO SETUP!pls help
Hi, and welcome to FixYa
The computer may display a prompt to press F1/F2 or any other key to enter setup each time the computer boots as a reminder on how to enter CMOS. However, if the computer asks to press F1/F2 (or another key) to enter setup and does not continue, this issue can be caused by any of the below possibilities.
Solution:
If no new hardware has been added to the computer or the new hardware has been removed and you continue to receive the error, it is likely that there is an error or confliction with the CMOS. Press the key requested to enter setup and verify that all settings are correct. If everything appears to be correct try resetting the CMOS values to the defaults and/or Reset Configuration Data. Additional information about how to do this can be found on document CH000976.
If all settings appear to be correct, save changes and exit CMOS setup. If the error continues to appear, enter setup again and restore all CMOS values to default.
· See our CMOS page for additional help and information with the CMOS.
· Additional information about getting into the CMOS / BIOS setup can be found on document CH000192.
If you continue to receive the prompt to enter setup each time the computer boots up and you have attempted to follow the above suggestions, it is also possible that the CMOS battery may be bad or failing. Generally; when this occurs, the computer is not holding the time or date correctly. If this is occurring it is recommended that the CMOS battery be replaced.
regards
/Teis the Wiz - -> Vote "FixYa" :-)
Dec 05, 2008 | Computers & Internet
Always f2
If I understand correctly your saying when you exit the cmos, id doesn't save your changes. Make sure when you exit you select the option to save and exit. If that doesn't work, your cmos battery is dead. Look in the mobo manual to find out what replacement battery you need.
Harris
May 01, 2008 | Asrock P4I45GV R5 Motherboard
Cmos batt replacment
First is the battery is working with 3V lithium battery or not with a digital multi meter if it is working correctly
take a sharp blade and sightly lift the pins in the cmos battery slot and try again
Apr 16, 2008 | Computers & Internet
SONY VAIO CMOS BATTERY LOCATION
Correction...
The CMOS battery is located under the system board, and is not accessible from under the keyboard.
The keyboard has to be removed in order to change the CMOS batter, (another reason why I don't like Sony laptops.)
Oct 24, 2007 | Sony VAIO FX150K Notebook
Fujitsu Siemens SCALEO 600 (FSP:83C005617) PC Desktop Logo
380 people viewed this question
Top Fujitsu Computers & Internet Experts
Computer Links
Tony
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
