Question about Westinghouse L1975NW Monitor
The monitor is on and seems to be running, have visibility prob.
Yes, I just got a Westing house LCD Monitor L1975NW.
I plugged it in and the menu shows up, but I can't differentiate the menu items, as there is barely any light/contrast.
I can just see the outline.
How can I turn the "light" on, on it.
Thank you
George
  • tca5 Oct 08, 2009
    Ok thanks. Yes I got it for free.
    I will trycto do as you say.
    Do you think that the contrast or anything can be adjusted before I start to disassemble it.
  • tca5 Oct 11, 2009
    Back light problem? How can I fix it ?
    Thank you
    George
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 152 Answers
George, I hope you got IT for free!! You too should find out all you can about LCD cold cathode fluorescent lamps and their electronic ballasts circuits which are called "INVERTERS" and obtain their dc voltage from the monitors "switch-mode-power-supply". If you can see an image on the screen even though it looks BLACK then you know that only half the SMPS is in SHUTDOWN mode. Why don't you try visiting YOUTUBE to search for LCD monitor Disassembly videos that are of the 8-12min long versions just FYI. also try vids of LCD repair and see if the symptoms are same as your's! Then get back to fixya and find out your options on what to do next. You may even tell us WHAT you're going to do!!! I'm louie12fix on fixya or lmistyrel @ aol. com hope this helps you out a little. please rate this response at fixya. Bye for now. louie nw of Chicago.
Posted on Oct 07, 2009
  • Lou Ebert Oct 11, 2009
    george, I still think that this is a backlight problem and will not be corrected thru any software controlled ADJUSTMENT of the unit's front panel controls. louie12fix
When i plug up the L1975NW lcd monitor what should show up ?
"no input" means that there is no signal from computer or the monitor cable is unplugged. When you first turn on monitor it usually does a self test and then looks for signal. Not connected to PC will give a no signal. If it is connected but PC is off (not unplugged) then it should go into standby as you vid card will be sending a standby signal to any monitor connected. Sometimes the Plug and Play monitors need to register before it will recognize a standby signal from PC, so plug it up and boot up PC. Then shutdown normally, your monitor should go into standby when the PC shuts down.
Nov 11, 2013 | Westinghouse L1975NW Monitor
Sir/Madam im shiva from chennai , i have acer AL1713B lcd monitor , but my prob is when i connect the power cable the led light is working , but display is not working. how can my solve this prob?
Dear Sivakumar,
please try to remove and plug VGA cable back again to the monitor. and press the menu button in front of monitor if it doesn't giving any message in monitor it means that the control card inside the monitor is faulty.for fixing that you have to contact your local service center.
Thanks
Jun 18, 2011 | Acer AL1713 17" LCD Monitor
Westinghouse 22 lcd monitor. I have a 1 inch black stripe vertically down the left side. The monitor adjustments and resolution settings do not correct the problem, Sort of like an old crt gun being out of...
This is an issue with the Inverter or wire that sends the signal from the inverter to the screen. This is typically a non-service issues and results in a new monitor. May recommend you contact westing house and see if the screen is under warranty.
Oct 19, 2010 | Westinghouse 22" Widescreen LCD Flat Panel...
I just got a westing house 26" hd monitor and i am having nothing but trouble i have a 1 gig ddr5 garghics card and it will not set to the 1900x 1200
Check the firmware version. Version 001 does not seem to support 1920x1200.
I can't find an option to update the TV firmware on the Westinghouse site; check your manual if this is available.
I wish that I could help.
Apr 21, 2010 | Westinghouse 25.5" Widescreen Flat Panel...
Resistors burnt on power supply board on L1975NW lcd monitor looking for that power supply board
This monitor has common problem with caps went bad and it will take out the fure and MOSFET in the inverter circuit. Do you know which resistor is burnt out? I usually only have to replace the caps, MOSFET, and the fuse.
http://www.instructables.com/id/How-to-repair-a-Westinghouse-L1975NW-19quot-LCD-/
Jan 07, 2010 | Computers & Internet
LCD Monitor turns blank after 1-2 seconds
Yes, this is a very common problem. Often times it is the inverter capacitors that wear down (they look like small batteries with a white stripe and are close to the transformers). If you can get in to the circuit boards, these capacitors are often visibly swollen on the tops; they are normally flat with an embossed X.
If you are going to replace the capacitors, pay very close attention to which way the stripe is; if you reverse this, the capacitor may explode.
Mar 21, 2009 | Computers & Internet
Westinhouse L1975NW Monitor
You can check your monitor .Restart your system and press F8 till it appears "safe mode" then select safe mode and press enter if display comes.then run your system on that LCD monitor.When desktop appears right click on desktop blank area then select property option.then press setting tab and select advanced option.Then select monitor tab in next window and select minimum frequency(ex-60 hertz).
Feb 29, 2008 | Westinghouse L1975NW Monitor
Westinghouse L1975NW Monitor Logo
272 people viewed this question
Top Westinghouse Computers & Internet Experts
Matthew Spark
Matthew Spark
Paul Bade
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
