Question about Nokia 6233 Cellular Phone
6233 cannot start
My nokia 6233 starts only for 10 secs.
Ok, this happened once again when I was changing a theme, it simply blocked and turned off. After that I kept turning it on and on but it was bugged : like it looks ok, then the screen becomes white with lines and then it turns off. I fixed it by taking out the memory card and putting it back again
But now the same thing happened probably because I turned off my phone by removing the battery instead of turning it off with the button. I mean come on, how sensitive is this fucking phone!? Isn't there a way I can reset it or something. The trick with the memory card doesn't work anymore. This phone is so buggy.
note that i have tried this *#7780# but doesnt worked but i m able to see my imei
  • 70 Answers
Re: 6233 cannot start - Nokia 6233 Cellular Phone Cell Phones
U have to flash ur phone
Posted on Jan 13, 2008
    Brigadier General:
  • 7,752 Answers
What you need to do is have the firmware reflash on the can do that with a nokia updater software or you can take the phone to a professional mobile repair shop and have them refalsh it for you to correct the issue ith the phone.
SOURCE: nokia 6233 restarts
sorry, i dont have a solution either but am searching the net for one since my 6233 did eaxactly the same last ight on christmas when i hot swapped the micro sd card. it boots into a white screen with just the battery indicator, then either does nothing or just swithes off. If im lucky ill ge the signal inidicator and time displayed but for only a second or so before reverting back to the white screen or switching off. Ive tried the *#7780# but displays result unknown. Ive tried the firmware version display code but that shows nothing also. Also nothing on the IMEI code.
Ive also tried the other methods described above of taking the abttery out and sim out and micro sd out and the combinations of that but still nothing.
Any other suggestions?
Posted on Dec 26, 2007
0 characters
3 Points
My Nokia 6233 Hangs & Then Shuts Down.
check the side button PTT
and make full reset
May 11, 2010 | Nokia 6233 Cellular Phone
Mobile phone problem
there is no wallpaper as such for Nokia 1209, but still some good patterns you can change to under themes in display settings and once you go to themes you can select a theme and edit its wallpapers but only in-built once!
reply and rate please! and ask for any more support!
Feb 14, 2009 | Nokia 6233 Cellular Phone
Nokia 6233 slow start up and problem in SWF themes
You have to check your firmware version using this code *#0000# if the version is older than 05.60 .you have to update thru nokia pc suit.sure it works.
Jan 27, 2009 | Nokia 6233 Cellular Phone
Cannot change theme in Nokia 6233
For changing themes in 6233 phone memory equla to size of theme should be free. For ex. - if theme size is 215kb then phone memory should also have 215 kb free space . Free some space in phone memory and then try. thank you
Oct 30, 2008 | Nokia 6233 Cellular Phone
Nokia 6233
try flashing the mobile phone firmware that should correct the 10 sec boot up
Dec 25, 2007 | Nokia 6233 Cellular Phone
Nokia 6233 restarts
if your phone Built with Symbian operating system. Use *#7370# to Format the phone memory. if your phone could not even Boot up. Use 3 key trick Hard formating technique. before switching on your phone. Hold 3 & * & green dial button & on/off button simultaneously. Just make it a try. if fails Contact authorised service centre.
Dec 23, 2007 | Nokia 6233 Cellular Phone
Nokia 6233 most wanted solution
remove the memory card then turn on and then reset.
remove the sim card and then reset.
Restarting problem
restore facrory settings by dialing *7780# or *7370# . remove newly installed java applictions also. also check ur phone memory wheher its ful
Dec 22, 2007 | Nokia 6233 Cellular Phone
6233 turns on for 10 secs and then turns off
I think you have a screen prob more than anything else
or even software problems.
Unfortunatelly ou will need to have a tech look at it.
OH try a master reset first if you can get it to stay on long enough that is.
Nov 07, 2007 | Nokia 6233 Cellular Phone
Nokia 6233 Cellular Phone Logo
127 people viewed this question
Top Nokia Cell Phones Experts
IT Solution
IT Solution
