Question about Honeywell Heating & Cooling
Satronic control box flash fualt code please can you tell me the flash code sequence control box for an oil fired boilers
    Problem Solver:
  • 7 Answers
Thanks, went on a boiler parts site for spec of item.
Posted on Oct 09, 2009
Boiler ok for hot water but no heating
What boiler do you have and is the controller a radio controlled thermostsat
Dec 14, 2014 | Water Water Heaters
Boiler ries to fire on heating or hot water but then shuts down after 10 seconds to F1 with the flashing red light, any ideas. clearly same principle as any boiler but I'm looking for someone who has...
that would indicate that the boiler is not firing up
If oil fired, been there done that
it is out of oil
the oil filter is clogged
the nozzle could be clogged/burned
the igniter wires need adj/replacement
if gas fired - similar issues but no experience
Dec 08, 2014 | Water Water Heaters
What does it mean when PO8 and H7 are flashing on worcester boiler dial
Either on the inside of the door or in your manual will have a list of all the codes. You could try turning the unit off, not while its in operation, and turn back on in 20 seconds. But first find the meaning of the codes, or faults. They will be listed. Unless the code is stupid simple, contact a pro. CO and fires kill if you don't know what you're doing
May 12, 2014 | Heating & Cooling
Fan control printed circuit board
Printed Circuit Boards are the 'brain' of the boiler. They control every action and can be found in most appliances from boilers to warm air units and fires. They are often referred to as a PCB, control box, mother board, driver board, sequence board, ignition board or power board. For more info you can visit at http://dferrantielectronics.co.uk/
Contract Electronic Assembly Manufacturer
Dec 24, 2013 | Stoves Ovens
Unit will not lite
Look on the circuit board, is ther a flashing diagnostic code?
tell me this code sequence.
Typically an induced draft motor will be the first thing to run, is this running? is the pressure switch for the induced draft operating, it its tubing and the tubings ports clear?
is the condensate line clear?
is the flame sensor clean? use 0000 steel wool to wipe it off.
Jan 22, 2013 | Rinnai E75CN Condensing Boiler
Boiler heating -loose connector on satronic control box
TUFF ONE, WHEN I HAVE COME ACROSS THIS I TAKE A GOOD FLASH LIGHT AND A PAIR OF READING GLASSES AND LOOK FOR THE PIN THAT IT GOES TO, IF YOU LOOK AT THE SURFACE THAT THE CONNECTOR GOES TO YOU WILL SEE A SCATCH, TRY TO TAKE ONE CONNECTOR OFF THEN YOU CAN SEE THE MARK IT LEAVE AND LOOK FOR THAT MARK ON THE OTHER PINS, ALSO MOST WIRES COME OFF IN THE GENERAL AREA OF THE PIN, OM TYHE END OF THE CONNECTOR SQUEEZE IT WITH PLIERS TO TIGHTEN UP WHEN YOU PUT BACK ON, GOOD LUCK!!!!!!
Jan 23, 2010 | Heating & Cooling
Fault light flashing 1 flash per second
Prior to writing the above fault I had asked the owner to turn the boiler temp controller , for the heating side, down just a fraction . I was phoned this morning to tell me that the boiler had stayed on allnight with no fault light . After consulting with the plumber who fitted the system it appears that there might not be a room stat ,
Nov 30, 2008 | Bosch Water Heaters
Riello oil burner RDB with red plastic cover at the front wont ignite. I've tried bleeding the valve. The motor seems to make an electrical humming noise for about 12 secs, then the system attempts to...
The motor should spin when the boiler is switched on. One end of the motor spins the fan the other end works the pump. The control box then starts the transformer that starts a spark. The control box then opens up the oil. The boiler should then light if any of the above or the boiler does not light, the boiler will go to lockout.
From what you say the motor is not spinning, thus it could be the motor or more like the pump.
YOU SHOULD NOT PLAY WITHE THE PUMP
If the wrong setting is made it could 1 burn out the back of your boiler 2 go to soot and the boilers in an hour would be filled up and become a fire risk. 3 not start at all if the setting is too low it is a fine line to get it to work and needs the right tools.
regards
oil eng.
Oct 26, 2008 | Heating & Cooling
Oil fired boiler
Check how all three "on/off" sequences are programmed firsrt, then all other programmable options. Make sure sliders are in the sliders are in the correct possition. If it becomes more complicated than launching a space shuttle, reset it. Unless your house is a mansion keep it simple with just day and night modes. the money you save wont even cover the cost to fix the hole you punch in the wall trying to do fancy programming ;-D
Nov 24, 2017 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
333 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
