Question about OKI MICROLINE 320 Turbo Matrix Printer
Windows xp printer driver for Oki 320 - OKI MICROLINE 320 Turbo Matrix Printer
    Scholar:
  • 105 Answers
Install an IBM Proprinter III driver. This driver is built into your Windows system and can be found in the Add Printer Wizard.
the computer will install that driver and it will make this unit compatible with windows xp
Posted on Oct 07, 2009
5 Suggested Answers
omerboo
  • 424 Answers
SOURCE: OKI printer drivers
Alternative driver download link: Oki B4100 Printer Driver
Posted on Jan 24, 2010
flopez
  • 161 Answers
SOURCE: oki microline 320 turbo
Your Oki model does not need drivers, for they are already contained since Windows 98 and up. However, if it still doesn't work, check that the printer emulation is set to IBM and then install a new printer using the IBM Proprinter II/III driver, also contained in Windows.
Be blessed.
Posted on Nov 07, 2008
  • 40 Answers
SOURCE: OKI DATA MICROLINE 320 TURBO PRINTER PROBLEM
Hi Charles,
Use the IBM proprinter driver for this printer and select IBM in the menu of the printer.
Hope this helps.
Dezzi
Posted on Nov 29, 2008
Sphynkter
  • 221 Answers
SOURCE: Oki ML 320 Turbo/D IBM - JetDirect 170x Print Server prolems
I just had this exact same problem - same printer, same Jetdirect model. Mine turned out to be the parallel printer mode setting inside the JetDirect. I connected to the configuraiton page by IP, then changed the Parallel mode from "AUTO" to "Centronics", tested it, and it worked fine after that. Hope it helps.
Posted on May 11, 2009
Printer will not print in windows xp
This is form OkiData's support site; The link will take to where I found this information.
Support Okidata
Hope this helps and GOOD LUCK!
  • Description: ecblank.gif ecblank.gif ecblank.gif
    ecblank.gif The most current driver for this product is already included in the Windows XP Operating System. Currently there are no updated drivers available. Follow the instructions below to correctly install your printer.
    NOTES:
    Select "Oki Data ML 320 Turbo/D (IBM)" from the XP CD.
    The ML390/1 Turbo Printers are not on the current XP CD. Please use the IBM Proprinter or Epson LQ driver for these models.
    The driver should automatically install once the printer is connected to the computer and powered on. If it does not automatically install, then do the following:
    1. Click Start, then Control Panel.
    2. Click Printers and Other Hardware or Printers and Faxes.
    3. Verify that the printer icon is not already installed
    4. Click Start, Turn Off Computer, then Turn Off to shut down the computer.
    5. Connect the data cable either USB or parallel. If it is not then continue to step 5.
    6. Turn on the printer.
    7. Turn on the computer.
    8. The printer will now be automatically detected
Nov 07, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
I want oki ml 320 turbo driver.. eny body can help me on that..?? pls,,,,,
the oki data ml 320 driver should be bundle with the operating system. If not you can download it from okidata website.
http://okidata.com/mkt/html/nf/Drivers.html
Try it and let me know if this helps.
Thank you.
Mar 04, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
Custom size...
you are not installing the correct drivers thats the reason you cannot see the list of paper options
Jan 08, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
Oki microline 320 turbo
Be blessed.
Oct 02, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Hi Charles,
Hope this helps.
Dezzi
Sep 10, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Page comes up blank !!!
check your rribbon.
also cjeck your head.
try to tast page from printer properties.
also try to print from dos .
check your printer datga cable.change it
Mar 25, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
OKI Microline 320 Problem...
I think you maybe using the wrong driver.Printout the menu if you are set for IBM than choose the "IBM Proprinter" driver in windows.Hope this helps.
Dezzi
Feb 26, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Only printing tasks from some computers
Print the Menu Setting out on printer and menu setting out on pc. Match sure emulation matcheds on both sides. If using serial make sure serial settings match on both sides. If parallel, check the bois on the PC, change parallel port type to EPP instead of ECP or SPP.
Feb 13, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Check the receive buffer on the Oki. I usually set it to the highest (88k or 128k). You might also check the print head gap if you are printing multi part invoices. If the print head is too close it may overheat and stop printing. If you have a different printer, swap it out and see if it prints correctly. It may be a problem with the JetDirect 170x, not the printer.
Nov 08, 2007 | OKI MICROLINE 320 Turbo Matrix Printer
OKI MICROLINE 320 Turbo Matrix Printer Logo
1,151 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
