Question about IBM ThinkPad T30 2366 Notebook
Boot Problem Tries to start ,on pressing start button it starts to go thru sequence with indicating Led's flashing on but does not bring up screen just shuts straight down This is with battery power & mains power.Have removed HDD ,Battery, & replaced RAM,anyone any ideas???
  • marbuk Dec 24, 2007
    battery HDD removed cannot even get into screen to accesss setup
    Problem Solver:
  • 10 Answers
Hai,
  1. Please check wether the backlight of the panel being lightes up or not
  2. Are u able to see the bootup screen ?
  3. If the back lights are ok then may be the mother board is faulty
Posted on Dec 24, 2007
    Problem Solver:
  • 11 Answers
Try to insert the battery charger into the laptop without the battery.
Laptop hp cq62 not start, black screen. after pluging ac cord he start itself, and after that, it is impossible turn it of.
You can generally only flash a bios if you can get the machine to boot up into some operating system. Do you get ANY on-screen logos or messages when you apply power to the laptop? Can you get into the bios when you power up the laptop and press Esc (or F2 depending on your model)? Do you hear any sequence of 'beeps' when you power up the laptop? A series of short/long beeps when powering up indicates some kind of error detected by the Power On Self Test (POST) routine. Do you have the HP recovery CD for your laptop? Have you put it in your CD Rom drive and tried to boot up? Check the manual at HP Support for a hard reset procedure- you could have a bad power button board or other hardware problem-it is not usually a BIOS problem.
Jan 28, 2015 | HP Computers & Internet
Cd start server primergy b210 fujitsu siemens
In order to change the boot drive you have to change the boot settings in BIOS, or sometimes you can get a separate boot menu which allows you to change this setting on a one-off basis. During the boot sequence you need to press the "F12" button during the POST testing to bring up the boot menu if one is available, otherwise you need to press the "Del" or "F2" button during the POST process to bring up the Bios screens. Navigate to the BOOT option and alter the boot sequence, save the settings, exit BIOS and reboot.
Feb 18, 2014 | HP Compaq ProLiant ML110 G4 Server
How to program spare Chamberlain 953CD remote
  • 1Enter your garage with your remote, and press and release the "Smart" button on the side of your garage motor unit. This button is located near the antenna wire and light lens.
  • 2Wait for the LED light on the motor to start flashing, and press and hold the button you would like to program on your remote opener.
  • 3Hold the button for up to 30 seconds until the main light on the motor unit flashes twice.
  • 4Release the button on your remote and wait 30 seconds for the LED light to stop flashing, which indicates the end of the programming sequence.
  • Nov 07, 2012 | liftmaster 371 Remote Transmitter
    Does not boot up, fans start, internet plugs light, clicks on and off.....seems this is a common problem for these machines, what is the fix?
    Instructions
    1. When you press the Power button to start the boot process, the LED lights glow while the computer verifies that there is sufficient electrical power to activate the hardware.
      Effect & Solution: When you press the power button, the LED lights on the computer do not glow or the LEDs blink briefly and then stop. There is no sound of the fan or hard drive spinning, and the screen remains blank. The computer will not start if there is insufficient battery or AC adapter power.
    2. The BIOS queries various hardware components used for the startup boot process.
      Effect & Solution: When you press the power button, the LEDs glow but there is no fan or hard drive sound. The LEDs may glow briefly and then go out.
      Or
      The LED lights blink, stop, and then blink a second or third time, but there is no sound from the computer and the screen remains blank. The sequence of the blinking lights indicates a specific error code.
      Or
      A series of beeping tones is heard. The sequence of beeping tones indicate a specific error code.
      If a hardware component has recently been replaced, or if the PC has been jarred or shaken, there may be a loose connection to the memory chips or hard drive which prevents the computer from starting.
    3. The BIOS loads the basic input (keyboard) and output (advanced LEDs / display screen / boot drives) devices into memory.
      Effect & Solution: When you press the power button, the LEDs glow, the fan or hard drive sounds, are heard, but then the boot process stops and a black screen - with an error message - displays.
      The boot check has detected a communication error or conflict with a hardware component that must be corrected.
    4. The BIOS loads the Windows operating system and starts the services that allow low-level control of all of the background operations.
      Effect & Solution: When you press the power button, the LEDs glow, the fan or hard drive sounds, are heard, the HP or Compaq Logo displays on a black screen, but then the boot process stops and a blue screen - with an error message - displays.
      The boot check has detected a hardware driver error or a software conflict that must be corrected.
    5. Control is transferred to the Windows loader to initiate the display of the advanced settings in the Windows environment.
      The Windows logo displays during this step.
      Effect & Solution: When you press the power button, the computer performs all the steps in the boot process, but after the Windows Logo displays, the moving Windows progress bar or the rotating cursor stops moving and the boot process stops.
      An error message may display on a screen with the Windows logo. In some instances, there is no specific error message.
      Or
      A black screen appears and the computer attempts to restart.
      The Windows self-check has detected a software conflict that must be corrected.
    Jan 09, 2011 | Gateway GT4016 Desktop PC
    Zanussi ZWF580- after the wash cycle I press the red button to rinse & spin but it just tumbles & rinses again, then the red button comes on again. This could go on all day. I find that to finish...
    If the START / PAUSE button lights up red, the washing machine detects a malfunction. Now you should count how many times the START / PAUSE button lights up red and tell to us what kind of malfunction is being done.
    Try to rapid reading of alarm codes when the appliance is in normal operating mode (e.g. during the execution of the washing
    programme):
    Press and hold down START/PAUSE and the nearest option button for at least two seconds: the LEDs initially switch off, and then display the flashing sequence indicating the last alarm.
    LED indicator START / PAUSE with red light = indicates the first digit of the alarm code (family)
    • LED indicator START / PAUSE with green light = indicates the second digit of the alarm code (internal number of the family)
    Dado
    Jan 21, 2018 | Zanussi FS1155W Front Load Washer
    My Sharp LC-42-D62U won't power up. The power light blinks twice, then the power light and the OPC light blink together once. any fix to this problem?
    Ur Tuner signal board have problems or dead.Ur power LED light indicator stable for a few mins before the power LED light,and the OPC LED light indicators flashes?After the POWER light and OPC light indicators flashes,just push the power button again for the power recycles again.Probally have to pushes the power button 3 or 4 for power light and opc light indicators flashes,the LCD backlght will lght up and work.Sharp tv have this problems alot,very common in Sharp LCD tvs.
    Apr 17, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
    My Dell 8200 Desktop just stopped working. It turns on but doesn't boot; nothing appears on the screen. I was told this is the motherboard. Does that sound right?
    two things
    1. What does the power LED on the tower indicate? Solid Amber? Flashing Amber? Solid Green?
    2. On the back of the Tower are 4 diagnostic LEDs, what do they indicate? Normally they flash thru several sequences and stop ABCD all Green. If the stop in another pattern, post the pattern.
    Feb 13, 2010 | Computers & Internet
    My acer travelmate will not boot up, please help
    hard disk error, insert operating system disks and run a repair or a complete clean installation.
    Mar 02, 2009 | Acer Aspire 4315 Notebook
    HP Media Vault - Power on / fan on / front panel indicators off
    I read a bunch of material found on the web. Primarily this led me to believe that the Lynix flash OS has some issues (to say the least). After carefully testing out the mom board voltages I decided that there was probably a software boot issue.
    I read this at k0lee.com/mediavault/
    "The MV1 has a hard reset which severs the tie to the startup.sh script that calls any of the installed software." The material on this site also indicated that the stored files would not be affected by a hard reset. So what the heck... nothing to lose. I unplugged the power, pressed the reset button and then applied power. Held the reset button for > 5 seconds. Held my breath for 30 seconds and the disk light started to flash on the front indicator panel. After a minute or two of that, the OK light came on. I pressed the power button on the front panel and the it responded. Another miracle? Hmmm. The MV shut down. I connected to the LAN and powered back on. Every thing worked fine.
    I guess... there was a space issue / startup parameter corruption / enemy electron in the mix that was passed over with the hard reset at start up. Since there is on access to the OS boot process, (or source code) this is pure speculation. Although, it is reasonable speculation. Chao!
    Nov 29, 2008 | HP StorageWorks Media Vault Pro mv2040...
    Boot fails while Flashing LCD Mail indicator
    I think u will need to go for the system Reset, This is easily available at every Samsung Service Center
    Aug 19, 2007 | Samsung T10 XVC Notebook
    IBM ThinkPad T30 2366 Notebook Logo
    105 people viewed this question
    Top IBM Computers & Internet Experts
    Alun Cox
    Steve Allison
    Steve Allison
    Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
