Question about HP Compaq Presario F500 F700 and G6000 Motherboard - 442875-001
I have a compaq laptop with wi-fi built in i cannot get on the internet.i also have a desktop pc amd i am on sky broadband
  • 121 Answers
Make sure your router is set to web key or wap key, make sure it is the same make sure the wireless is enabled on your laptop, make sure your ip adress on both machines are in the same route and the same network name home or workgroup
Posted on Oct 07, 2009
My pc details-amd semprom 3200+,mmx,3DNOW,1.8GHZ. MY INTERNET SEVICE MODEM IS WI-FI ENABAL,BUT MY PC IS NOT WI-FI. HOW ITS WI-FI CAPABLE NOW
You must purchase a Wi-Fi adapter (possibly a USB Wi-Fi adapter) & follow the the adapter's installation instructions followed by inputting the modem's SSID & passphrase (if there is one). The SSID will probably show up in a list of available networks. Just follow the adapter's instructions. Refer to the modem's instructions for logon information (i.e., SSID, encryption type (if any), passphrase (if any), WPS PIN # (if any), etc.).
Apr 11, 2011 | Computers & Internet
CAN I USE INTERNET THRU WIFI WITH COMPAQ ARMADA E500 ?
it seems like your laptop not have inbuilt wi-fi connection, so you can not use the wi-fi but if you buy a USB wireless adapter or wi-fi pcmcia card so you can use the wi-fi in your laptop.
Thank you for using Fixya
Regards
Manish
Jun 13, 2010 | Compaq Armada E500 Notebook
I have a compaq presario F756nr with an Atheros wireless wi-fi card in it. Can I replace the wi-fi card with a Broadcom 802.11 b/g wireless LAN card?
no you cannot replace the built-in wi-fi card...
if you try to change the drivers for atheros wi-fi to Broadcam driver, your wi-fi card will not function anymore.... but you can always install another WI-FI card in your laptop... you can buy a USB Adapter or a Cardbus(PCMCIA) adapter for this purpose...if you want your wi-fi signal strenth and range to be higher, you can opt to buy an adapter which comes under N standard....N standard wi-fi adapters are capable of connecting at a speed of more than 300mbps(practically) to any N standard device like router....
Mar 29, 2010 | HP Compaq Presario F756NR Notebook
I cant log in to my sky email error 500 but can log on with my laptop with wi fi
You can try deleting the cookies and the Temp Files. You can do that going to the internet explorer, Tools- Internet Options.
Nov 07, 2009 | Acer Computers & Internet
Just got bt wireless broadband but computer will not conect via wireless. computer only 4 years old thought it would have had wireless mode built in??
First check in your router your wireless option WI-FI is enabled.
Then check in laptop Wi fi driver are instaler and working properly.
Also make sure your wi fi is enabled in network plces property and wi fi switch on laptop is turned on in laptop.
Aug 07, 2009 | Fujitsu Siemens AMILO Pro V1000 Notebook
Unable to connect to wireless router . its has a built in wi-fi
go to the start menu..
right click on my computer..
go to properties...
look for device manager..
then look for network adapters..
then they might be something with a yellow exclamation point
press it then install...finished
hope i helped you..
take care..
Apr 20, 2009 | Computers & Internet
Hi, I have an old acer laptop and my wife communicates with me on it using broadband and a router with a usb pick up. I have returned home and have a new acer laptop with wireless LAN already installed. It...
Youe broadband router is working ok with the broadband cable.So it is configured with the broadband cable.Now,to work with the wireless internet,you have to configured the wi-fi router to work internet.You can see the wi-fi connection but unless & untill you will configure wi-fi router it must not work or if before it was working with the wi-fi then you can check the wi-fi router setting because it might change by mistake.Surely it will work after configurating wi-fi router.
Jan 03, 2009 | Computers & Internet
Connecting to internet
you connect the internet if your broadband router is wi-fi enable. so if you turn on wi-fi on your laptop and you get the signal. than you can access the internet on the laptop too. But for this your router should be wi-fi enable and DHCP must be set properly with in the router. so if you can access the router from your desktop by opening it in browser e.g. http://192.168.1.1 and default login id and password e.g admin you can check the status inside it. I hope this will help you in solving your problem.
May 10, 2008 | HP Compaq Business Notebook NX9010
About wi-fi
Windows XP has a built in wifi configuration tool, previous versions of windows dont have this feature. But if you were to buy a wireless card it comes with software for wireless to work on all versions of windows from 98 - XP most if not all new laptops have wifi built in & that will be able to share your broadband connection through the netgear router. You can configure the laptop & pc to share files & printer between each other, easy way of doing that is by using the wireless network setup wizard which can be found in Start -> All Prograns -> Accessories -> Communications -> Wireless Network Setup Wizard.
Feb 10, 2008 | Computers & Internet
HP Compaq Presario F500 F700 and G6000 Motherboard - 442875-001  Logo
129 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
