Question about Yard Machines 158cc Push Lawn Mower #11a 034f200
Lawn mover will not start, was flipped over
I fliped over my Yard Machine 20" Self Propeled Lawn Mower with 6.7 HP BS while changing the blade, now it will not start. It makes a clicking noise when I pull the cord.
  • 437 Answers
The clicking noise may be the blade hitting the side of the mower or it was not put on properly. It needs a balance to the aluminum flywheel on top of the engine. The blade adapter and blade provide this balance for the engine to run.
Good Day.
Posted on Oct 07, 2009
My blade keeps coming loose after hitting a rock on lawn mover
is the bolt stripped so it wont tighten?
Is the threaded hole on the Crankshaft of the mower cracked
Jul 26, 2013 | Mtd 22" Yard Machine Push Mower
I have a 46" Yard Man riding mower with 20 hp BS.
Hello, Ask your local Mower shop if they show a Thermal switch for the PTO. You may have to replace it or move it away from the heat.
Aug 14, 2011 | Mtd 46" Dozer Blade, Fits All & Yard -...
Yard Machine 20" push mower
Check to make sure your blade is not bent first take the spark plug out for safety then by turning the mower over on its side. Now turn the blade and determine if the blade is rubbing the deck or if the sound is in the engine if it is in the engine it will probably be a bent crankshaft. If it is the blade bend it back to 180 degrees perpendicular to the crankshaft. If it is the crankshaft. it will be a costly repair that could cost more than the original cost of the mower. Buy a used one at a garage sale,yardsale or other source make sure to test any used product before buying.
Jul 07, 2011 | Mtd 22" Yard Machine Push Mower
How do u change the belt on a self propelled MTD Model #12A-268B352 push mover
Please follow this link to the MTD website which will give you step by step instructions. I hope this works for your model as well. Best of luck to you and "Happy Motoring". James
http://tinyurl.com/3vpwdts
Jun 27, 2011 | Mtd 22" Yard Machine Push Mower
Need manual for Murray 20'' 3.5 hp lawn mower
sounds like its running out of gas. I changed spark plug, still sounds like its about to die
Apr 11, 2010 | Garden
Replace pull rope
Yes, take the shroud off that the recoil is riveted to
Apr 15, 2009 | Mtd 22" Yard Machine Push Mower
Toro 20073 self propeled, walk behind mower-how to replace belt ?
Wait until the mower cools off
1. Remove the drive belt cover from the top of the mower
2. Tip the mower up, being careful to not go too far or the oil and fuels may spill out
3. Remove the mower blade - as I recall the bolt is 5/8" (could be 9/16") You will have to hold the blade from turning (if you have impact tools, this will be much easier)
4. Remove the blade
5. Pull the pulley out or off and remove the belt - be careful to not lose the crankshaft "woodruff" key - it's the little piece of half/moon shaped metal that keeps the pulley from spinning on the crankshaft.
6. Reverse the steps to reinstall
You MUST make sure the blade is tight when you reinstall it. Also, the blade usually fits over a couple of pins - make sure they are lined up properly and the blade is installed right-side up.
Mar 16, 2009 | Toro Lawn Mower With Toro Power Tools
Yard Machines 158cc Push Lawn Mower #11a 034f200 Logo
522 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
