Question about Pro-Fit Pro.Fit Dg 91 96 Dodge/Plym/Chry Caravan/Voya/T&C 96 00
I have a 96 dodge 1500 no spark
I have a 96 dodge that has a 318 i change the pickup and it didnt help i changed the coil twice it ran for a little while and died the last one was new i tested it was fine plus my cluster dont work except the oil pressure gauge
    New Friend:
  • 161 Answers
Sounds like a bad ground somewhere.....check all the major ground connections.
Posted on Oct 07, 2009
It mayI have no fire going to the coil or from the coil to the plugs
Have you checked the wiring, the spark @ plug, Power to the coil???
Engine Won't Start No Spark - Auto Diagnosis Repair Help
aa1car.com/library/no_spark.htm
If your engine cranks normally but will not start because it has no spark, or it ... If an engine has a coil-on-plug ignition system with no plug wires, remove one of ...
No-start, No-Spark diagnosing simulated - YouTube
? 5:13
https://www.youtube.com/watch?v=XSWN1M8Hoqo
May 19, 2010 - Uploaded by FrankHurtAuto
Simulation of no start with no spark diagnosing, ... Ignition coiland module test with test light (ScannerDanner Premium lecture) - Duration: ...
getting fire from coil but not to plugs - CarGurus
www.cargurus.com > Questions > Dodge > Ram 1500
CarGurusJun 12, 2013 - 2000 dodge ram 1500 4x4 not getting fire changed distributor cap, coil, pickup ignition, rotor, plugs, plug wires 2 answers. ... 1994 dodge 5.9 just shut off and wont start back up there is no spark or fire from coil or plugs. ... 94 dodge van 318 eng will not start new plugs new crank ...
Ignition Coil Troubleshooting: (No) Fire in the Hole
www.secondchancegarage.com/public/coil-troubleshooting.cfm
Jan 27, 2016 | Cars & Trucks
How do i change the spark plugs on my 2009 dodge ram hemi? 5.7 litre, 1500 series
if problems with hard start check heating coil in the intake side left on engine no spark plugs please dont even go to autozone n ask u look like a fool
Apr 16, 2011 | 2009 Dodge Ram Pickup 1500
1999 Dodge Ram 1500 318 engine no spark no signal to coil i changed cam positioner sensor and crank positioner sensor still no spark could it be a bad wire (ground)somewere
Check the ASD relay in the fuse box. Swap it with the starting relay. If the engine fails to roll over. Thats your problem. If not, check and see if your fuel injector connectors have voltage to them if not its a bad PCM. Hope this helps.
Jun 05, 2010 | 2000 Dodge Ram 1500 Truck
Will Not Start
Check the distributor for cracks and check the rotor inside the distributor, it may be worn out.
Sep 10, 2009 | 1985 Dodge Pickup 4WD
Dodge trans
they should match up perfect but measure the holes to make sure
Jan 31, 2009 | 1997 Dodge Ram 1500 Club Cab
1998 dodge ram 318 motor wont start
have you checked the crankshaft sensor?
Jan 04, 2009 | 1998 Dodge Ram 1500 4WD
97 318 1500 dodge no spark
HAVE YOU TESTED THE CRANSHAFT POSITION SENSOR ON THE FRONT OF THE ENGINE?
Nov 30, 2008 | 1997 Dodge Ram 1500 Club Cab
Idle problem
most engins have a part called an idle air control valve this is where i would start
Oct 12, 2008 | 1997 Dodge Ram 1500 Club Cab
Pro-Fit Pro.Fit Dg 91 96 Dodge/Plym/Chry Caravan/Voya/T&C 96 00 Logo
118 people viewed this question
Top Pro-Fit Car Audio & Video Experts
greg benton
Craig Butler
Craig Butler
Are you a Pro-Fit Car Audio and Video Expert? Answer questions, earn points and help others
