How to set up optimus eq to cd player - Audio Players & Recorders
  • 19,396 Answers
Do the following: 0. With EQ off connect the CD to one of the Audio inputs.
1. Turn the receiver's volume control to its lowest setting. Then, set the receiver's tone controls to their positions.
2. Set the equalizer's slide controls to 0 dB (center positions).
3. Be sure BYPASS is out. If BYPASS is in, press BYPASS to release it.
4. Press POWER to turn on the equalizer's power. The POWER indicator lights. Then turn on the receiver's power.
5. Select the receiver's tape monitoring feature.
6. Turn on the audio source's power. Using the receiver's controls, select the audio source.
7. Be sure both of the equalizer's TAPE MONITOR buttons are out.
8. Start the CD, and adjust the receiver's volume.
9. Adjust the equalizer's slide controls for the desired sound. View the effect of the adjustments on the SPECTRUM DISPLAY.
Posted on Oct 07, 2009
I have a Crest Audio V900, a set of Bose 901, a Gemini EQ-3000. Do I need a PREAMP? Or can I hook up the Crest AMP to the Equalizer?
You could use the EQ but it won;t sound as good as it will with a pre amp and also could make it a bit trickier when adjusting the volume and getting it to sound right.
Mar 10, 2012 | Crest Audio Audio Players & Recorders
I have a GR-470 EQ. I don't think I'm connecting
The proper sequence to eq just your CD player is, CD out to EQ in, EQ out to receiver in.
Jan 16, 2010 | Pioneer GR-470 Home Equalizer
I need a wiring diagram to connect up my kenwood amp, cd player, tuner and graphic equaliser
cd player(tape out)-------equalizer in------equalizer out-----amp line in.
tuner out-----to another line in in amp.
Nov 27, 2009 | Audio Players & Recorders
Having Trouble Accessing Bass and Treble Controls
Only parametric EQ OR Bass/Treble can be active at a time. There is a option to set which one you want, refer to manual. Follow this- Adjusting Sound Setting Mode (long press "sound-mode" button) -> EQ SELECT-> select either P. EQ or B/T
Feb 18, 2009 | Clarion DXZ785USB Car CD/ MP3 Player
Sherwood 460 equalizer hook up
Connect the EQ to the Sherwood as if it were a tape deck: EQ's outs connect to receiver's tape ins (play) and EQ's ins connect to receiver's tape outs (record).
Then you hook the tape deck up to the tape ins and outs on the EQ: Tape deck outs connect to EQ's tape ins (play) and tape deck ins connect to EQ's tape outs (record).
This will put the EQ in your receiver's tape loop.
The CD player should be connected to the receiver though the CD in's and out's (or if your Sherwood doesn't have a CD in/out, then use AUX or TAPE2).
To hear the EQed signal with all receiver sources (like the CD player) you'll need to engage the 'Tape Monitor' button or switch which will route the tape loop to the speakers.
Jan 09, 2008 | Audio Players & Recorders
How to connect eq to audio amp
To EQ all audio sources you'll need to have a receiver/amp with either a tape monitor loop or a pre amp-in/main-out loop. Look for a button on the front labelled 'Tape Mon' or ins and outs on the back labelled pre amp-out/main-in. If you have these you can connect the outs from the amp to the ins on your EQ and then EQ outs go back into the amps ins. If you have a tape deck as well, the EQ's 'tape mon' jacks replace the ones it takes up on the amp, so just plug your tape deck in here.
Just remember that whether you have a tape deck or not, if you hang an EQ off the 'tape mon' loop you'll have to engage the 'tape mon' button/switch for playback with EQ.
If your amp doesn't have these loops you can still use EQ but you may be restriced to one audio component source. So say you wanted to EQ the playback from your CD player, you'd just connect the CD players output into the EQs input, then connect the EQ's output into the amplifiers input (for CD player). Then everything you play through the CD player will be EQ'd.
Jan 01, 2008 | Audio Players & Recorders
Hi. i want to add a graphic eq to my pioneer receiver (home audio).
if the Eq has enough jacks to run every thing, that would go In to Eq an out to receiver, you were told correctly, for example cdplayer out - to Eq In - Eq- out to Receiver in
Nov 29, 2007 | Spectrum Technical Hifi EQ-B5100...
Custom eq problem
Contact Sansa tech support directly to inform
May 23, 2007 | SanDisk Sansa e260 MP3 Player
69 people viewed this question
 Grubhead
Grubhead
