Question about Dell Dimension 4600 PC Desktop
My windows update has stopped downloading. I keep getting error messages
  • bigfreezel Oct 07, 2009
    My computer gives me an error message saying windows is unable to connect to windows update.The code # is 8000FFFF and a balloon stating that window can't check for updates. I've contacted mircosoft and the last guidance they gave me was to run the vista disk and do a custom reinstall. Only when I used the disk the custom reinstall was not highlighted only the total reinstall which looks like I will lose all of by files. I tried to back up the computer on my k book which is an external disk drive (160 storage) but the back up keeps failing and I get a message stating that I need to use the fix tool to correct the error. When I do that I get a message saying that the disk cannot be checked while it is in use. I have since emptied the K book completely thinking that would allow me to back up the files but I keep getting the same original messages. I tried to back up the computer to the c drive but was told that I cannot back up on the drive of origin. I then tried to perform a back up on the D drive which is labeled "recovery" but there is not enough space. My computer is fairly new (purchased in 2007) so I think this is a soft ware problem or I have corrupted the files somewhere down the line. If you can tell me how to backup my files I am willing to do the reinstall of Vista.
  • Jarrid Crandlemire
    Jarrid Crandlemire May 11, 2010
    what does the error message say? also check to make sure that your windows clock is set right otherwise it wont let you download updates.
  • 3,940 Answers
Here are a couple microsoft articles to try:
http://support.microsoft.com/kb/555989
http://v4.windowsupdate.microsoft.com/troubleshoot/
Posted on Oct 07, 2009
How do I fix Windows 10 update 0x800705b4 error code?
This error commonly occurs within the operating system at the time of windows updates. If this error is not fixed, it will lead your system slow or even corrupt it.
This error may arise for the following reasons,
1. windows defender update
2.
Damaged system files.
3.
Third-party anti-virus and malware.
Solution for the windows 10 updates 0x800705b4 error code:
Right here are a few solutions for troubleshooting 0x800705b4 error code,
Method 1: Uncheck the "get updates for other Microsoft products when you updates windows" option:
• Open the "Windows Update" and click "Advance Options".
• Uncheck the "get updates for other Microsoft products when you updates Windows" Option if it's marked.
• Now the update process should complete successfully.
• You may run this process continuously until you get the "your device up to date" message.
• Once this message appears, again check/select "get updates for other Microsoft products when you updates Windows" Option.
Method 2: Temporarily disable the "Windows Defender"
• In case, the above solution doesn't work, you can disable the" Windows Defender" for temporarily.
• Type Defender in the search box and open the Windows Defender Desktop app.
• Click "Settings" and turn off the Real-Time Protection and Cloud-Based Protection options.
• Close the setting window and now the windows defender appears in red.
Note: After that do all the steps in solution 1 again, hope the update process will be successful this time. Once this issue is fixed, you can turn on both Real-Time Protection and Cloud-Based Protection.
Method 3: Run the Windows Update in "Clean Boot"
You should login computer as an administrator for performing "Clean Boot".
Method 4: Run the "Microsoft Update Troubleshooter" and Restart the Windows Update:
Still, if you having update issue, download the "Windows Update Troubleshooter" and Run.
After this, restart the "Windows Update Service".
Follow these steps for Windows Update Service restart,
• Open the Command Prompt(CMD)
• Type "net stop wuauserv" then press "enter"
• Wait for the confirmation message.
• Then type "net start wuauserv" then press "enter"
Hope the above solution will fix the update issue.
Jun 12, 2017 | Computers & Internet
Fix error 8024402c
Click Start, and in the Search box on the start menu, type CMD, then press Ctrl+Shift+Enter (this will get you an elevation prompt for an Administrator command prompt)At the command prompt, type net stop wuauserv, then press EnterType rmdir /s %windir%\softwaredistribution\wuredir, then press Enter. Type Y to acknowledge the command.Type net start wuauserv, press EnterUse the Windows Update Web site again to install updates.Hope updates are installed.. If problem still occurs then run a system utility tool like Reginout for an instant fix.
Apr 21, 2012 | Microsoft Windows Vista Ultimate Edition
Code Oxcooooo22
Even when I am using the administrator account I can not download updates
from the windows update site the yellow icon used to appear but no updates,
now no icon appears, these messages come up whenever I've tried to download
updates manually from the windows update site [Error number: 0x8DDD0002] or
something that goes like this OxOOOA46 and there is a link to where one gets
instructions on fixing it. I have done what was suggested which was to go to
tools internet explorer security and make sure user persistence user data was
enabled I've done all this to no avail. I've been told that I need to be an
administrator to download updates but anytime I've tried to download updates
I've been using an account with administrator privileges.
I've had problems accessing the internet for ages but it is only lately that
I can't download updates from the windows update site.
I keep getting these error messages when I switch on my computer using the
limited account. ccApap.exe - Application Error.
The application failed to initialise properly (OxcOOOOO22) click on ok to
terminate the application.
I click on ok and then another message comes up osCheck.exe - Application
Error
The application failed to initialise properly (OxcOOOOO22)click on ok to
terminate the program
Again I click on ok and another message comes up PIFSvc.exe - Application
Error
The application failed to initialise properly(OxcOOOOO22) Click on OK to
I click on ok and windows loads as normal. I can access programs such as
works and windows media player but my anti virus (Norton Internet Security
2007) has disappeared but when I use the Administrator Account Norton seems
to be there and seems to work ok.
My computer is a year old and I have had to get it repaired a couple of
times but I don't want to spend any more on it as they can't seem to fix the
problem. I can do what I want so long as it is offline anything that
involves the internet I have problems with. The computer Operating System is
Windows xp Home Edition with service pack 2. I use Internet Explorer version
7.
Any ideas on why I have problems with the internet and what I can do to
solve them would be much appreciated.
None of those failing modules that you mention are from Microsoft.
I suspect that they may be from your security package(s).
Try enabling the Windows firewall only. Uninstall your other security packages
and then retry getting the updates.
BTW if you are only concerned with getting the updates but don't care how
you could also try using the Windows Update Catalog, download and install
manually from there.
Mar 21, 2011 | Computers & Internet
Error "msi_check: 0x80280002" ,
Error "msi_check: 0x80280002 i tried installing windows live messenger
Feb 17, 2011 | Microsoft Windows Live Messanger
I cannot download the new windows updates-I get an error message 646 and cannot find out what that means
Try the following steps to install the update successfully.
Stop the services pertaining to Windows Update.
1. Click Start, click All Programs, click Accessories, right-click Command Prompt, and select Run as Administrator.
2. If you receive a notification from User Account Control simply click Continue.
3. At the command prompt, type the following commands and then press ENTER after each command.
net stop wuauserv
net stop bits
net stop cryptsvc
4. Please do not close the Command Prompt window.
Rename folders pertaining to Windows Update
At the command prompt, type the following commands and then press Enter after each command:
ren %systemroot%\System32\Catroot2 Catroot2.old
ren %systemroot%\SoftwareDistribution SoftwareDistribution.old
Start services pertaining to Windows Update.
net start wuauserv
net start bits
net start cryptsvc
Close the Command Prompt window.
Download the standalone package file of the update “KB967043”
and install it.
Visit the following link to download the update:
http://www.microsoft.com/downloads/details.aspx?familyid=628280fe-e035-4274-85f2-393d9bad543c&displaylang=en
Restart the computer once the update is installed.
Let me know if this worked.
Oct 15, 2009 | Microsoft Windows Vista Home Premium with...
Cant download update driver for X3580 error message 1001
Try removing the command to startup the lexmark printer monitor from the startup file. Just run "msconfig" and uncheck the command. Then reboot and try the update again.
Jun 20, 2009 | Lexmark Office Equipment & Supplies
HP PSC2355p all in one, cannot use scanner, error messages, cant
Try going to windows update, use administrator options, and download and install windows installer 3.1, and then try re-installing your printer.
Feb 10, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Microsoft office professional edition 2003
check if BITS is running in the Services.msc and/or restart the Windows Automatic Update service.
Jun 25, 2008 | Microsoft Windows XP Home Edition
Windows update isnt working
exact error message please so that we can pin down the issue
Jun 15, 2008 | Microsoft Windows XP Home Edition
Dell Dimension 4600 PC Desktop Logo
157 people viewed this question
Alun Cox
