Not my solution but a copy from another problem. Rate me =]
"The problem is with the signal board. Basically, it is not allowing the power signal to go from the on button from the set or the remote to the TV. I am having the exact same problem with my 42" LCD Regza. Currently, if you are under warranty, Toshiba does not have these in stock. They will not have them available to send until early January. My TV has been at the repair shop since December 4th. I am very upset as I won't be able to watch the bowl games in HD. If your set is still under warranty then call Toshiba help line at 800-575-5469. You will need the model number of yout TV that is listed on the front of the owner's manual. They are:
27HL67
32HL67
32HL67U
37HL67
42HL67
The first number will be the giveaway as to which model you have. It is the size of your set. They will ask you to try a hard reset. (Hold pwer button down for 5 seconds until you see the yellow light go solid and go off.) This will most likely not work. If it does, you are lucky. I found that if you unplug the TV for an extened period of time, ie overnight, ity may come back on. It will eventually give out completely though. Better to get the problem addressed with the manufacturer. If you are not under warranty then I do not know what to tell you. Right now I am searching the internet to see if I can find this part to maybe purchase myself. Only if it is not too costly. If I find anything I will post here for all. If you have any questions, feel free to email me a
[email protected] and I might be able to give you more details on your problem. Good Luck.
WJ"
Quoted From
http://www.fixya.com/support/t1070173-yellow_light_blinking_blank_screen_turn
Nick
