Question about LG LS-L1210CL Mini Split Air Conditioner
It leaks water at the unit inside the house. How do I fix it?
  • 89 Answers
Check the drain line to make sure it is open
Posted on Oct 08, 2009
  • 9 Answers
SOURCE: My sister was stumped because
If you remove the lower casing of the unit, you will find that it was design in such a way the water followed a certain track. Your problem should be fixed if you align that track with the opening to coils so water should drain in the proper track.
Posted on Aug 21, 2008
  • 534 Answers
SOURCE: water leaking inside house
Your problem is there is debris inside of the casing blocking the drain hole in the back of the unit.. Go outside and look under the unit and you will see several holes throughout. These holes allow the condensation to drain out from the bottom of the unit. The best way to clean the unit is to remove the unit from the sleeve take the unit outside and you can wash out the system with a water house as long as you make sure that you don't wet any of the fan motors. The metal thing you refer to is the evaporator coil. If you go to the home improvement store you can purchase a can of coil cleaner. This cleaner is sprayed into the coil at which time it foams up like shaving cream. Let it sit on the coils as directed on the can. Once the time has elapsed rinse the coils well remembering not to get any electrical parts wet (I suggest purchasing a pump up garden sprayer for this because it is easy to control where the water will go) After this is done let the unit sit until the water has disappated then reinstall into its sleeve. The dust by the fan can be removed with a brush and a vacuum (wet Vac). Good luck on repairs
Dave
Posted on Sep 01, 2009
  • 744 Answers
SOURCE: I have a split system SAP-K181AHA, SAP-K241AHA
Air conditioners wring moisture from the surrounding air that collects in a pan under the cooling coil in the inside unit.
Chances are that the condensate drain is plugged or the drain pan is plugged. Look for a hose that exits the inside unit and runs to a drain. You can follow it back to the drain pan of the A/C unit. If there is water sitting in the pan, then either the hose or pan or both are plugged.
Turn the unit off, get a small bucket and remove the drain tube. Catch the water in the bucket. Blow through the drain line until it's clear. If the thought of doing this is too repulsive, then use an air compressor or even a manual tire pump. Now check the drain pan in the unit for debris and remove as much as possible from the pan and the drain fitting.
Both the pan and drain line should be checked at the beginning of each cooling season.
Reinstall the drain tube and see how it works!
Posted on Jan 08, 2010
  • 13 Answers
SOURCE: samsung split systim leaks water from inside unite
when ambient air goes across your evaporater it causes it to condense check your drain hose it may be clogged up not allowing the water to drain properly
Posted on Feb 07, 2010
  • 215 Answers
SOURCE: Water is leaking inside the house
The drain that should be carrying the condensate water outside is stopped up. Compressed air works well to clear the drain.
Posted on Jun 22, 2010
Why does my split ac unit leak inside the house?
This happens when the drain pipe is too high, or kinked. The pipe must be lower then the drain pan in order for the water to drain. This is a common problem.
Jul 27, 2014 | Sanyo Heating & Cooling
Leaking from inside unit
What is leaking? If it is water, you need to find the drain pipe leading from the inside unit to the outside of the house, and open up the obstruction in it. You could push a wire up through it, or send some compressed air up it. The drain pipe is probably near the ground next to the foundation or in the ceiling of an outside porch.
If this is a window unit leaking water you need to clean the obstruction out of the drain pipe or hole on the outside of the window, probably at the bottom outside rear of the unit.
I wasn't sure from your question if it is leaking water, or leaking refrigerant gas. If it's the gas you probably need to call an A/C repair service.
good luck,
genetuck
Jan 15, 2011 | Carrier Heating & Cooling
Water leaks from unit often
mcdevito75 Here, all A/C units leak water, if your unit is a window unit you"ll have to re-tilt the unit so that it is leaning more toward outside the window and not toward the inside. Contact an A/C shop in your area they come to the house.
Aug 26, 2010 | Heating & Cooling
Drainage occurs near the front of the unit, resulting in pools of water leaking onto my window sill. Unit is installed properly, there is no drain hole to direct water away from the insides of the walls...
The A/C unit should be tilted slightly to the rear and this will allow the water to leak to the outside of the window, you may have to drill a small hole in the case to drain if there is no pre-existing hole.
Aug 15, 2010 | Frigidaire FAC126P1 wall/window Air...
Jun 22, 2010 | Sanyo 18KS52 Air Conditioner
Our carrier reverse cycle airconditioner is leaking inside the house after a hour of use. how can we fix this? we have cleaned the filters in the inside unit and it still leaks,it works fine as a heater...
Did you blow out the drain? If so pull the front off of the air handler unit. Ckean out drain pan. This drain pan had small holes on either side that run from the sode drain clean those out. Also if your coil is dirty it will pull water back and cause it to leak. Try cleaning coil and dain pan plus blow out drain. Rus
Dec 13, 2009 | Air Purifiers
Water leaking inside house
Dave
Sep 01, 2009 | Goldstar M5200R Air Conditioner
My sister was stumped because her window unit a/c keeps leaking water inside her house.She even had her husband drill a small hole in the housing of the a/c, so that it would drain excess water more...
Aug 20, 2008 | Heating & Cooling
LG LS-L1210CL Mini Split Air Conditioner Logo
208 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
