Question about Ricoh Aficio 1027 All-In-One Laser Printer
Ricoh 1027 what is the scan option part number?
  • 903 Answers
The Printer/Scanner Controller Type 1027 part number is 411000 (product code B453), but I'm pretty sure that it's obsolete. Contact Ricoh customer service to find out if you can still order it.
Posted on May 29, 2010
How do you clean/service a Ricoh Aficio 1027?
you had to have the ricoh 1027 manual & can be download from any technical ricoh forum esp from copytech.net if you lucky, you can download for free
Sep 12, 2013 | Ricoh Aficio 1027 All-In-One Laser Printer
Is it possible to setup scan to folder on my afficio 1027
cannot set up the scan to folder because that machine cannot put a hard disk that used for scan to folder just only can use the network twain
Feb 18, 2012 | Ricoh Aficio 1027 All-In-One Laser Printer
I have a ricoh aficio 1027 with fax option and i want change the recieve function to auto answer with 5 rings
1. Download driver from http://support.ricoh.com/bb/pub_e/dr_ut_e/0001153/0001153018/V3100/r29694en.exe
2.If that doesn't fix the issue immediately try http://support.ricoh.com/bb/pub_e/dr_ut_e/0001154/0001154861/V861/r30275en.exe
Sep 11, 2010 | Ricoh Aficio 1027 All-In-One Laser Printer
Did ricoh can scan anything
The 1027 can be equipped as a scanner, but there is a special module the copier needs to have installed. A quick way to check if it's been installed is to look at the function keys to the left of the touch screen. There should be a key for Copy, and maybe one for Document Server as well. If you see keys for Printer and Scanner, then you have the ability to scan and you just need to configure the settings. Otherwise, you'll have to purchase the print/scan kit in order to be able to scan.
Aug 04, 2010 | Ricoh Aficio 1027 All-In-One Laser Printer
Ricoh Aficio 1027 network connection problem with vista x86
It will not work to directly connect a network cable directly from the network port of the printer directly to your computer. You will have to use a cross-over cable and configure your TCP/IP settings manually. However, to utilize network printing and have internet access, you will want to get a router and connect your modem to the ethernet port of the router, then a network cable from pc to switch port on router, and a network cable from printer to a differnt switch port on router. Most consumer routers have a built in 4-port switch, so that should allow enough connections. You may want to consult a local IT company or Ricoh dealer for the rest of the setup. This will allow the framework for network printing and/or scanning.
Jul 28, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
Ricoh 1027
There are two possible options:
Printer Module (B461)
This requires the 64MB memory option (G579).
Printer/Scanner module
This requires the 64MB memory option (G579) and the NIB (G574).
Good luck and please rate me, thanks.
Nov 04, 2008 | Ricoh Aficio 1027 All-In-One Laser Printer
Re: SCANNING ON RICOH
You need the scan router lite utility. You can download it from:
http://support.ricoh.com/html_gen/util/SR/SR_R.html
Feb 22, 2008 | Ricoh Aficio 1027 All-In-One Laser Printer
Ricoh Aficio 1027 All-In-One Laser Printer Logo
169 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
