CD WILL LOAD ,SHOW WHATS ON THE FILE AND THEN NOTHING PLEASR COULD YOU HELP MRS J WATERS
  • 6,487 Answers
This can be a problem with the CD, what you can do here is to take the CD out from the drive and then wipe it with a soft and clean cotton and check also for any scratches on the CD that might be causing the problem...
Posted on Oct 09, 2009
    Brigadier General:
  • 3,614 Answers
The CD could not be completely finalized that why you got trouble playing it.. First try to test or check the disc on a different unit.. If the problem was still there, the disc is damaged..
Hope this helps.
Posted on Oct 07, 2009
HP pavilion ze4600 XP operating system safe mode etc. will not load CD restore does not work either? help
Firstly hdd's shouldn't click. Purchase a new hdd set your BIOS to boot from CD drive, install XP from your disc.
Dec 05, 2014 | HP Computers & Internet
Getting stuck on rinse light and beeps second by second
Mrs Vargas, if you wash on 'warm' you're using both hot and cold water mixed together. If the cold inlet valve is faulty (not uncommon) the machine will fill with hot water alone. When the machine gets to rinse, it can't advance because F&P machines rinse only with cold water. If the valve is faulty it can't fill. So it stops!...Not a big job for a tech....Good luck....Nomess
May 13, 2010 | Fisher and Paykel GWL11 Top Load Washer
I connect sansae260 to PC, Nothing apears on Sansa's Screen
You may need to now reset the player, that may have been a bit much for it.
To reset your Sansa Mp3 player.
  1. Slide and hold the Power switch up for approximately 20 seconds.
  2. Release the Power switch.
  3. To turn the player on, slide the Power switch up then release instantly.
If that does not get your player working again, try and Format to clear any corrupt files that may be present.
http://www.fixya.com/support/r3962743-sansa_mp3_player_frozen_reset_format
Mar 15, 2010 | SanDisk Sansa e260 MP3 Player
I put in the dvd and nothing popped up.
does the cd show up " ICON if not down load this nd run it - it will reset the cd rom in the registry and 99% of the times fixes it after you run this file reboot PC
download this as open it run it reboot :()
http://www.dougknox.com/xp/utils/XP_CD-DVD-Fix.zip
Dec 30, 2009 | Punch Home and Landscape Design Suite for...
Fills water goes through program drum dose not
Remove the motor, and check the brushes in the motor, if o/k, then could be a board prob, or something as simple as a broken or bad connection.
Pleasre rate my solution.
Thanks.
Oct 10, 2009 | Hotpoint WMA46 Front Load Washer
My Toshiba L300 satellite pro wont load up
USE A BOOT CD AND RECOVER THE FILE AND MAKE SCAN VIRUS
rapidshare.com/files/51117041/ERD-2007.rar
IF YOU HAVE SATA DISK DISABILITATE SATA IN BIOS... TRY....
May 08, 2009 | Toshiba Satellite Pro L300 Notebook
My washing machine
Clean the drain filter out. Then while the filter is out, take a flashlight and look into the filter hole. We had this problem and discovered a metal bottle top lodged in the hole which goes to the pump. Removed the bottle top easily and the machine works fine.
Nov 14, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Cd drive Acer Extensa 4420
After inserting the cd into the drive click on "My computer" and then click on the leeter of the cd drive. this will show files on the cd.
There should be a file called setup. Just double click it to start installation.(double clicking is clicking on something twice quickly in succession).
Oct 11, 2008 | Acer ASPIRE 3680-2022 Notebook
I have a Sony Vaio desktop with Windows Home Premium and my CD/DVD drive does not work anymore. There is an error message which says "Windows cannot load the device driver for this hardware. The...
Your DVD/CD Drive laser reader head is not working as it will show this message when ever you insert a cd/dvd disc - Try to replace it with a new one even head assembly can be also replaced
Aug 12, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
