Question about Akai MPC-4000 Plus Production Center (w/80 GB Hard Drive&Onboard Sounds)
How can the MPC 500 play the Samples on the Pads in real time?
I`m from Germany and today I bought a MPC 500. The problem is, that I can only here the Sample Sounds after recording, it`s not in realtime when i hit a pad, how can i change it so that i hit a pad and then I directly hear a sound?
Greets
You have to go to the sample edit page and move the start point to the beginning of the wave sample. Right now your start point is before the sample actually starts.
Posted on Dec 16, 2009
Which system do I need to be able to trigger loops/textures/pads from the lower 2 or 3 strings of my guitar (kinda like one finger accompaniment on cheap keyboards), while soloing on the higher strings?
You could hook the output of the GR33 to something like an AKAI MPC (http://www.akaipro.com/mpc) assigning different notes to trigger different samples or sequences.
Sep 19, 2011 | Roland Gr33 Guitar Synthesizer
Im trying to connect my mpc 2500 with pro tools 8. im using an mbox 2 pro as my interface. I can get pro tools and the mpc to sync...but i cant seem to understand why i cant hear any of my samples from the...
Check if the Mbox2 has an echo setting that echos the audio from its input. If you want the audio to loop through the PC then it will have to echo there instead. Check that in "Sound and devices" of the PC are all set to transfer via the MBox for voice and playback instead of the internal PC audio system.
Apr 12, 2011 | Akai Mpc2500 Music Production Center
I am trying to record sounds from my keyboard into my MPC 1000. I have what I think is the proper set-up. MIDI sync...softthru as track...etc. Problem is when I set it up I can play one sound and record...
It is not clear whether you are recording audio or MIDI. If you recorded Audio samples, you will get the same sounds back even if you change the voice on the keyboard.
If you record a MIDI sequence, and then play it back you will STILL get the same sounds UNLESS you also record the MIDI voice or patch changes so the voice is changed as it occured when you recorded it. Usually there are options taht you can enable or disable voice changes.
Feb 11, 2011 | Akai Music
Os update promblems mpc 2500
Try this site:http://www.akaipro.com/mpc2500 Try downloading all the the release notes for ver.1.24 if you haven't already. Download the ver.1.24 which seems to be the newest to your computer first and install from there. It might have gotten corrupted the first time you tried it. You will have to email them using the form for the newest release notes and the installation instructions:http://www.akaipro.com/mpc2500 http://www.akaipro.com/content1924.html and http://www.akaipro.com/mpc2500 are the URLs you need. Hope this helps.
Apr 16, 2010 | Akai Mpc2500 Music Production Center
Mpc 1000 beginner
Here is an excellent source of info:http://www.mpc-forums.com/viewforum.php?f=15 Consider joining and posting any questions you have. Forum members are happy to help and have usually had the same problems at one time or another.
Jan 21, 2010 | Akai Mpc2500 Music Production Center
I think I am quite confused for what I want. So maybe you can help. I am non-professional player of Yamaha PSR 730 with no music knowledge I Play by ear/hearing only. What I Play: Mostly remix old songs...
You sound like you have a good grasp of what you would like to do. There are lots of videos on Youtube of people using some of the gear you mentioned. Also check each manufacturers site for forums on the gear you would like to use. The forums usually consist of members who are all friendly and have good advice and solutions for any problems you may have. Remember that even the most experienced musicians started somewhere and are all still learning and are very willing to share what they know. You might consider using a laptop with an external hard drive. I think the Akai gear is very good and has good support and expandibility. Decide first what main pieces of equipment you would like and contact as many dealers as possible to get the best price. You may be pleasantly surprised and have enough of your budget left over for something you hadn't thought of yet. Good luck and enjoy your playing. Remember to study all your manuals carefully.
Jan 21, 2010 | Music
I can't get my mpc 1000 to play chopped samples on the pads
Have you checked it out from the manual. If you have get in touch with www.akai.com and ask them. they are the manufacturer and YOU ARE THE CUSTOMER.
Good Luck
Jul 05, 2009 | Akai Mpc1000 Sampling Music Production...
Mpc 500
First ensure that you are saving into the right folder, on MPC HD and not into a subfolder, and that files are in correct midi format. Also ensure that connections to MPC are OK.
If connections and saved files are ok, then probably you need to reinstall Mpc 500software onto your computer, using disk provided with your Mpc 500.
Oct 19, 2008 | Akai Mpd16 Midi/USB Mpc-Style Drum Pad...
Akai MPC 4000 Plus
You could set the sample to "one shot" in the trim page or in the Program>KG Mix>Zone page.... it is currently set to "as sample"... i like to use the release to let the sample fade out as long as i like... its a lot diffrent from the old poly mono thing but i like it better overall... hope this is helpfull.
Apr 16, 2008 | Akai MPC-4000 Plus Production Center (w/80...
MPC 500 PROBLEM!!
you need to set your Parameters Params and make sure the you set enough bars for the sample.. if it cuts out you could try hitting the track button and putting the drums on track 2
Mar 15, 2008 | Audio Players & Recorders
Computers & Internet Logo
329 people viewed this question
Top Akai Computers & Internet Experts
Alun Cox
Michael Vincent Cruz
Are you an Akai Computer and Internet Expert? Answer questions, earn points and help others
