Question about Epson Stylus Photo R200 InkJet Printer
Pages will not print. The correct number print,
Pages will not print. The correct number of pages go through the printer, but even though the machine is charged with fresh ink, the pages come out blank.
  • 95 Answers
IT MEANS that the nozzles might be clogged, perform a cleaning cycle for about 3 to 5 times to clear the dried up inks blocking your nozzles.
Posted on Oct 07, 2009
How do I Print double side on wireless printer
unless you a specific printer that can print double sided in one run
you have to set the printer manually
to do this when you go to the print command , it will show up as print all, print pages etc
click on print pages then type in 1,3,5,7 each number has to be followed by a comma until you get to the last page or click on print odd pages only
then print what you want
when finished pick up all of the printed pages and put them back in the tray upside down with the top facing in the right feed direction
then go back to print all pages 2,4,6 etc or print all even pages then print
if you are not familiar with that procedure , practice on a couple of sheets until you get the way the pages face correct
practice by opening a new document and just typing a few words on the page 1 and 2
then print it out
Apr 02, 2017 | PRINTER Office Equipment & Supplies
How many pages in a pdf download for Necchi Instruction manual for Necchi Model 3101 FA?
when the down load opens up on the screen, in a small tool bar at the top of the pdf section there are areas that show page numbers , zoom in / out expand size etc the number of pages will be there shown as 1 /24, or 50,or 600 etc ( 1 / of the number of pages in the down load )
if you click on the scroll bar on the right of the page proper and scroll down , as you pass each page break it shows the next page number
if you scroll down the page you will come to a contents list and that will also show the number of sections in the manual and that will indicate how many pages you can expect
to reduce paper wastage from a normal house hold printer when you print from the printer logo in the bottom right of the page you get the printer up and where it says print all , change that to print odd pages ( or even pages ) or or print pages and this is where you put in the pages that you want printed -such as 1,3 5, 7 etc
when the print run is finished put the whole lot of printed pages turned around and back in the printer then print the page numbers that you missed on the first print run this will result in a booklet with printing on both sides of the page and reduce the number of sheets used in printing
Nov 07, 2015 | Necchi Sewing Machines
I want to print on both sides of the paper
The Brother HL-2040 machine does not have and cannot be fitted with a duplexer to print both sides of the page automatically. You can only duplex manually, that is - you turn the page over and put it back in the machine to print on the other side. Some settings will allow to print double sided manually, where the printer prints all the odd numbered pages then instructs the user to place ALL the printed stock back in the paper tray to then print all the even numbered pages.
Mar 09, 2014 | Brother HL-2040 Laser Printer
My printer prints multiple pages even though number of copies in setting shows 1
Try looking here: open your printers fax folder. Your printer should be listed here, right click on it and select properties. Now click on the advance tab. There should be a printer defaults button, click on it. Make sure your copies number is set to 1. Then click ok on each window and close.
Hope this helps
Feb 13, 2012 | Dell 1320c Laser Printer
I have printed all odd # pages from a document, but my HP Laserjet 4 won't feed these pages back through to print on the blank side with even # pages. I've tried to keep the front (feeding edge) of papers...
You need to try a thicker paper, Heavier stock to double print the page. Slightly more expensive. Recycled paper typically will not work for this type of function. I had this same problem and found this was the only solution.
Oct 31, 2009 | HP LaserJet 4 plus Printer
Double sided printing Pixma MP520
here's how:
print double sided pages
1. Set your computer software for double sided printing if you have a printer that is compatible. Double sided printers are generally professional style machines, and most offices, schools and libraries will have them. On a PC, go to the drop down "File" menu and select "Double Sided Printing" under the "Preferences" or "Properties" window and print. If you have a MAC, click "Copies and Pages" under the "File" menu, select "Layout" and then click on "Long-Edged Binding" and print.
2.Print double sided with your standard home printer, again, by setting your PC writing software. When you are ready to print, click on the drop down "File" menu and select "Print." From the "Print" window select "odd pages only," or "even pages only."
3.Set your odd and even pages a bit differently if you are working with MAC writing software. Select "Print" from the drop down "File" menu and click on the arrow to drop the "Copies & Pages" menu. Under the "Copies & Pages" menu, select "Paper Handling" and then click on "Odd Numbered Pages" or "Even Numbered Pages."
4.Select "Odd Pages Only" or "Odd Numbered Pages" and then print as usual. It is a good idea to mark the top of your first page with a pencil so that you know the direction and side of the page your printer prints. Use the mark to determine how to turn your pages and place them back in the printer. Select "Even Pages Only" or "Even Numbered Pages" and print again. $('.Article .Steps .Image').each(function(i,e){ e = $(e); e.find('img').error(function(){ $(this).unbind(); e.remove(); }); });
Sep 16, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Printer won't print more than one page
try by reinstilling the printer drivers
Apr 03, 2008 | Office Equipment & Supplies
Blank pages
Even though I changed my black and colored ink cartridges twice, the printer still prints blank pages. What should I do?
Dec 21, 2007 | Epson Stylus CX3200 All-In-One InkJet...
Epson Stylus Photo R200 InkJet Printer Logo
309 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
