Question about Home
The water continuously runs very little. The gasket comes loose from the bottom that covers the hole. It needs to stay on the part that goes back down to hold water.
  • 85 Answers
Replace that flapper!
Posted on Oct 16, 2009
I have transmission fluid leaking out of hole in clutch cover where the pull start rope goes in. Is that normal on a Polaris sportsman 500 ho.
Gasket or a bolt is loose. Dont use til u fix. Get a manual by clymer etc for repair details...utube is helpful
Oct 21, 2015 | Polaris ATV
What would make a rocker arm a little loose
rain water will not get into the oil unless you had the rocker cover off and working on the engine outside in the rain.
water in the oil is coolant getting into the oil either from a head gasket problem or corrosion holes behind the water pump impeller. If there are loose rockers when running then there may be a blockage in the hydraulic followers for those rockers or there is wear in the rocker bushes and on the rocker shaft.
Dec 15, 2014 | Cars & Trucks
Water leaks at bottom of fridge
The same thing happened to me then I noticed ice had formed at the bottom of our fridge. It was covering a drain hole so water was leaking out the front of fridge instead of going to the drain pan or wherever the hole goes. After I chipped out the ice and cleared the hole with warm water the leak stopped. I also fixed another leak coming from bottom of fridge caused by a loose brass connection on water line going to the door.
May 25, 2014 | Hotpoint HSS25GFP Side by Side...
LG Dishwasher leaks!! New E1 Code just fixed an HE Code, gasket not broke, one of the electrical connections underneath had come loose so I just clipped it back on. I have not hooked everything up again...
http://lgdishwasher.yolasite.com/ MINE JUST STARTED AGAIN TODAY. SWOLLEN BOTTOM DOOR GASKET LOOKS LIKE HILLS UP AND DOWN. ALLOWING WATER TO OVER FLOW DOOR BOTTOM. GETS TRAPPED BEHIND GASKET. PAN HAS LITTLE WATER WHEN YOU OPEN DOOR. BUT CAN SEE RUN OUT OVER EDGE WHEN RUNNING WITHOUT OUTER DOOR SKIN, ALSO LEAKS AT TOP CORNERS DUE TO DEFORMED CORNER GASKET. THEY SHOULD HAVE MADE THE GASKET ROUND IN CORNERS TO KEEP IT SEALING, HAD TO MAKE C METAL CLIPS 4 INCHES LONG TO HOLD BOTTOM GASKET TIGHT TO BOTTOM PAN, USED 4 CLIPS AND TWO SMALLER AT ENDS
Oct 18, 2013 | LG LDF6810ST Stainless Steel Built-in...
Car wont stay running and i thought it was feul pump or fuel filter. i replaced both and it still wont run. it will crank sometimes but cuts right off like its not getting fuel, at least thats what i was...
not value cover gasket leak out around spark plug not to inside piston. but cut right off how hot? no water in oil? or filled up piston? maybe head crack. fuel pump pumping? crack line not went eng hot. ture key on look or someone look 10lb of pressure comeing out fast.water no. antifreeze yes.
Sep 24, 2011 | 1996 Saturn SC
I have oil on tip of plug wire on only 1 of my spark plugs,all others have a little oil on spark plug itself.I just had the timing belt done ,water pump all sealas and head gasket,new wires do i need to...
You need a new Valve Cover Gasket. The rubber seals around the spark plug holes on the Valve Cover are leaking. A new Valve Cover Gasket will come with the round gaskets that seal the spark plug hole.
Jul 30, 2011 | 1995 Honda Accord
How to change a water pump
First drain the coolant if possible (you will find a drain **** on the bottom drivers side of rad). Loosen the water pump pulley bolts while serpentine belt still attached (10mm X 4). Remove the serpentine belt, and plastic diagram bracket just above the waterpump. Remove the (8mm bolts X 5) holding the water pump to front engine housing. Note the little arrow or triangle at the top of waterpump when removing, it will help you to install new water pump in same location. Scrape off most of the old gasket material, use fine sand paper to clean engine surface as best as possible. Install new gasket to water pump, and align the holes (it only goes on one way, and maybe upside down if they don't line up). Locate arrow and reinstall, torque 5 bolts to 89 in/lbs tight but not too tight. Reinstall pulley, serpentine belt and bracket. Tighten the pulley bolts, refill coolant (close drain ****). Just above the waterpump there is a coolant hose with a little 7mm screw for a bleeder. Open the bleeder (engine off). Continue to fill rad with coolant until it comes out bleeder. Close bleeder and test run. Recheck the coolant level later when cooled.
Jan 26, 2011 | 1999 Chevrolet Venture
I have noticed a little bit of water pooling on the floor under the washer. It appears it is running down the inside of the front cover. There are a couple small tears on the door gasket on my front...
I have patched the holes until the new parts came in and customers have said it hasn't leaked. I used clear 100% silicone. This has lasted for several weeks on some occassions. Clean it good then let it dry for at least 24 hours. If you need to replace it here is a link that should help http://appliancehelponline.com/washerdoorseal.html
Sep 11, 2010 | Frigidaire ATF6000ES Front Load Washer
Drain in the freezer keeps freezing up and causes water to freeze up in the bottom of the freezer
If this is anything but a GE fridge then you can take a regular electrical wire and strip it of the plastic shielding. Next twist one end around the heater that runs under the evaporator above the drain hole. Make sure you have enough wire to extend it about 1-2in into the drain hole.
Now when it goes through a defrost cycle the heat traveling down the wire will keep the hole defrosted.
Nov 05, 2008 | Refrigerators
Bissel powersteamer clearview will not spray water
Did the gasket on the bottom of the water tank come off and is either missing or sitting in the hole where the tank sits? It needs to be on the tank.
Does water squirt out of the hose nozzle, if it does, then check the heater inside the handle asm. Make sure that where the tubes hook up to it are not clogged. If water doesn't squirt, check for the seal at the bottom of the tank, it needs to be on the tank, not in the hole, this is for the soap bottle also, there is a seal on the bottom of it as well. The flow indictor cap is leaking air or maybe is too tight. If you had the top cover off, make sure that the tubes are routed right so as not to get pinched when the cover is put back on, the smart mix knob should be in the water setting and that the piston is on the bottom of the smart mix knob. Pump is bad. Try running a mix of vinegar and water to see if that unclogs the lines. Is the top cover and the base tight together in the back, sometimes the top breaks loose and it will raise up and it can't spray, just re-fasten it down.
Jun 19, 2008 | Bissell 1699 ProHeat Clear View Upright...
Home Logo
229 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
