Scanning from Photoshop it send me directly to the troubleshooting message. I've detected that my...
(More)
Scanning from Photoshop it send me directly to the troubleshooting message. I've detected that my scanner is not starting up, I mean, the light is not on and it does not even make the typical noise when is turned on (completely frozen!!) It is probably the 1st or 2nd time I've used it since new (8 months ago) but is refurbished from Epson website. Any advice or how to fixed? It was never beaten or anything. thanks
Scanner dose not work, LED comes on but it dose not power up. It has not had a lot of use, only the...
(More)
Scanner dose not work, LED comes on but it dose not power up. It has not had a lot of use, only the occasional scan. When I used to turn it on it would light up and the scanning head would return to the start position, now only the green LED on the ON button lights up. Any Ideas would be appreciated.
When I click on Scanner to start my V200 Scanner, I get the message that it cannot be started. I...
(More)
When I click on Scanner to start my V200 Scanner, I get the message that it cannot be started. I have updated the driver with no results. When I go to Control Panel and Scanners, nothing shows up.
How do you clean the table glass on the inside of the Epson V200? can you take the glass off and...
(More)
How do you clean the table glass on the inside of the Epson V200? can you take the glass off and clean in?
