Question about Samsung HLP5085W 50" Rear Projection HDTV-Ready Television
A TRIANGLE WITH AN EXCLAMATION POINT INSIDE APPEARS SOMETIMES WHAT IS IT?
  • callistino May 11, 2010
    Your TV went to standby mode. You need to check if another icon appears under the triangle. There are three possible: 1. a thermometer which could mean your TV is overheating or the thermostat is gone; 2. A fan which indicates the fan is not working; 3. a light bulb which indicates a problem with your bulb. In the last case could also be the ballast is bad and not provifing enough current to the bulb or you have a second grade bulb (not OEM). Hope this helps.
2 Suggested Answers
micromatikal
  • 2777 Answers
SOURCE: Had the triangle with an
That is a bad sign for sure, it sounds like the video board itself could have problems, or the sensor that detects the bulb could have failed... even a mainboard problem can cause that light to light up. There is no way to know for sure unless you can spot physical damage on one of those boards.
Also is this a Samsung HLP5085W ?
Let me know and I can keep helping
Tim
Posted on Oct 06, 2010
Yellow triangle above the eco light on dash
Sounds like the air pressure of your 4 tires is unbalanced, low pressure. Go to Discount tire. they check it for you for free and will reset the light, I hope you have a discount tire in your city.
Dec 18, 2013 | 2014 Kia Sorento Designer Auto Mat Floor...
Triangle exclamation
Your photo database is corrupted. You can right-click on the iPhoto library and explore the contents and extract all the pictures from the library to a separate location. Then you can reimport them into iPhoto and the black triangle's will disappear.
May 04, 2013 | Apple MacBook Pro Laptop Computer with...
What does the triangle with the arrow round it mean and what does the triangle with the exclamation mark in mean please
The triangle with the arrow around it is for the wheel speed sensor. The triangle with the exclamation point is for tire pressure. Low tire pressure would set both of these lights off.
Oct 13, 2012 | Cars & Trucks
My everest 3 CPAP will not turn on. When I press the "on" button the screen lights up but there is no air flow. Then an icon appears on the screen that looks like a capitolized B and a triangle...
hello there
there is probably a problem in your motor inside the body of the machine. Either the pump is not generating air or the device is not properly clean. Do calibrate the device using the Service manual given on the purchase of device.
i guess it would help you
stay blessed
Mar 01, 2011 | Health & Beauty
I have a light on my dash with an exclamation point enclosed in what looks like parenthesis with verticle lines underneath. It's yellow. Do you know what it is?
If it looks like a deflating tire with an exclamation mark inside, its the check your tire pressure light.
If its a triangle with exclamation mark inside its the check engine light.
Oct 03, 2010 | Volkswagen Jetta Cars & Trucks
Wat does the exclamation point in the dashboard mean?
the exclamation point inside a triangle is the VSA activation indicator or Vehicle Stability Assist system indicator. If the indicator stays on, have the VSA checked at the dealer.
Jul 30, 2009 | 2007 Honda Odyssey
Samsung HLP5085W 50" Rear Projection HDTV-Ready Television Logo
463 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
