Question about HP LaserJet 5500DN Printer
81.0180 EIO 1 error code on a hp laserjet 5500 dn
  • 81 Answers
The printer has encountered a problem with an EIO card device in slot 1. Power off, remove the device from the slot and power on. If it comes up ready then refit the card and try again. if it still fails with the error recommend replacing the EIO device in that slot
Posted on Oct 13, 2009
2 Suggested Answers
KingDWS
  • 1606 Answers
SOURCE: ''HP Laserjet 4600, Error code 81 0180 E10 1 Error''
That indicates that the printer has a network card problem. You can try rebooting/resetting which can clear it but usually means a trip to the hp repair shop.
Posted on Jul 09, 2009
Hp color laserjet 5500 error 59 ck printer error
list of error codes
http://www.printertechs.com/printer-troubleshooting/hp-error-codes/195-numeric-error-codes-50-59-hp-laserjet
HP COLOR LASER PRINTERS 4600, 5500 ERROR 59.3, 59.4 1. A fuser motor error. 2. Replace the fuser drive assembly. 3. Replace the D.C. controller board.
Jan 04, 2017 | HP Office Equipment & Supplies
What does the error message EI0 1 Mean on the 8150dn printer?
EIO is the External Input Output slot that is on the formatter of the printer. the 8150 has 2 EIO slots (EIO 0 or EIO 1). One of the slots is probably the JetDirect card (network card) for the printer. The second slot might be a hard drive but is usually open.
If you are getting a EIO error first try reseating the JetDirect card (power off the printer first). If you are still getting the error pull the card and power up the device with out the card installed. if the error goes away power down the unit and install the card in the other EIO slot. if the card works you have a bad slot on the formatter but you should be good to use the device. If you get another EIO error the card is probably bad.
Mar 10, 2015 | HP LaserJet 8150 Printer
Error code EI0 1
EIO 1 is the port in the back of the printer for a JetDirect Network Card, or for the External Hard drive.
Pull the card out of the slot (turn off the power first) then turn on the printer to see if the error went away. If so, you need to replace the item you removed.
Feb 18, 2014 | HP LaserJet 4600 Printer
Error code 40.0
A connection with the card in EIO
slot X has been abnormally broken.
1. Press to resume printing.
NOTE
A loss of data will occur.
2. Check that all cables are
connected to the EIO ports
and that the EIO board is
seated properly.
3. If possible, print to another
network printer to verify the
network is working properly
Jul 24, 2012 | HP Color LaserJet 5550 Printer
81.0180 EIO 1 error
On the back of the printer where the network cable is plugged in, in your case it is EIO slot 1.
The problem could be the slot(EIO 1) or the JetDirect card that is plugged into that slot.
Power down and loosen the two screws on the JetDirect card and reseat it. Power up and try using the printer. If the error persists, power down and remove the JetDirect and plug it into EIO 2.
There are two screws that hold the EIO cover on. Power up and try the printer. If it works, take the two screws and the cover and use it to cover EIO 1. And you are good to go. If it fails again with a 81.02, the JetDirect may need changing
Nov 01, 2011 | HP LaserJet 5100 Printer
Problem with the HP LaserJet 4050 Printer 82.0180
The 82.XX error represents that the External Card which is located in the formatter of the machine, either is bad or the port in the formatter is bad (This could be a Network Card or a Hard Drive really depends on your machine.)
Recommended Solutions:
Please make sure you turn off the machine before removing the card!
Remove the card from EIO slot 2 and plug it into the EIO Slot 1 is the card still does not work then the card will need to be replaced.
If both the EIO slots do not recognize the card. It's most likely the card, however it could also be the formatter.
Oct 20, 2010 | HP LaserJet 4050 Printer
Hp Laserjet 2300n printer with error 81.0180 EIO 1 ERROR
You have a problem with the device plugged into EIO slot 1. Most likely it's a JetDirect card. Turn power off and reseat the card. Power up, if problem is still there put the card in the other EIO slot. There should be 2 EIO slots. If it still fails you will have to replace the JetDirect
Oct 07, 2010 | HP LaserJet 2300N Printer
Have been getting the following error 83.0180 EIO 3 Error on an HP LaserJet 9000. Don't have the manual so don't know what it is.
this is a network card error. the EIO card in slot 3 is probably faulty. Try swapping the card into slot 1 or 2. If you get the same error then you will need to replace the card.
Nov 06, 2009 | HP LaserJet 9000 Printer
Sysytem Error 009B002 007A046F
System Error: 09xxxx (Non-Continuable)
Problem
Description:
EIO Accessories (EIO Card/Hard Disk Drive) Error.
Corrective Action: Try the following:
n Switch the Printer OFF and ON again and wait for the initialization.
n If the Error code continues to appear, switch the Printer OFF.
Remove the EIO Card (if installed) and make sure that the Hard
Disk Drive is installed correctly by pushing it firmly inwards and
checking that the two installation screws are completely
tightened. Switch the Printer ON again. If the error codes 09Axxx
or 09Bxxx appear then replace the Hard Disk Drive.
n If the Error Code disappeared after removing the EIO Card, then
switch the Printer OFF and reinstall the EIO Card, making sure
that the two installation screws are completely tightened. Switch
the Printer ON again. If the Error Code reappears, then the EIO
Card could be faulty. Replace the EIO Card.
n If Error Code 09Cxxx appears after initialization, then replace the
Electronics Module
n Once the Error Code has been solved, print an Internal Demo
Print to make sure that the Hard Disk Drive is functioning
correctly. If the Error Code reappears, then use the above
information to troubleshoot the problem
Nov 21, 2008 | HP DesignJet 1050c InkJet Printer
Eio device 3 disk not functional
Afraid you'll need to replace the hard disk:0(
Oct 02, 2007 | HP LaserJet 9500n Printer
4,638 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
