Question about Garden
PRESSURE WASHER WON'T PUT OUT FULL PRESSURE WHEN SQUEEZING TRIGGER, THIS HAPPENED A OF A SUDDEN. USUALLY WHEN THE TRIGGER IN THE HANDLE IS SQUEEZED THE ENGINE NOTE CHANGES & THE PRESSURE GOES UP. NOW THE ENGINE SPEED STAYS THE SAME & PRESSURE GOES UP SLIGHTLY, NOT ALL THE WAY.
  • papatech Oct 07, 2009
    HELLO , I DO NOT THINK IT'S A BAD PUMP , BECAUSE IT FAILED SO SUDDENLY, LIKE ONE TIME PRESSURE FELL & THEN CAME BACK , BUT NOW IT'S GONE , PRESSURE WON'T COME BACK UP NOW.
  • 5655 Answers
SOURCE: I HAVE A BRAND NEW TROY-BUILT 2600PSI pressure
Sounds like the governor is stuck. My pressure washer speeds up when it has to pump. Don't know if yours uses vacuum to trigger governor or direct linkage. Good Luck.
Posted on Jul 04, 2009
  • 5603 Answers
SOURCE: sometimes when I squeeze the trigger I will have high pressure
The bypass valve is sticking.
Posted on Sep 23, 2009
  • 174 Answers
SOURCE: when I squeez the handle the pressure surges.
Hi:
The first thing i would do is be sure there is not a partial blockage in the nozzle.
Posted on Sep 24, 2009
  • 4 Answers
SOURCE: Power washer loses pressure. Engine runs fine.
Your bypass valve is jamming. All you do is take it out, put a smear of o ring grease around the o rings then put back in, make sure you push it all the way in and should fix the problem.
Posted on Sep 30, 2009
SOURCE: EXCELL VR2500 power washer runs and then stops
I had the very same problem and nobody could help me until I was talking with a co-worker. Its a very easy fix. I couldn't believe it. I did this yesterday and it ran like a charm. You can either replace the head gasket or just by a good sealer to use on your existing gasket or replace it. I use Indian head gasket sealer on mine. The bolts on the bottom were lose causing a loss of compression. If you need more info you can email me (for free) and I will tell you exactly how to do it. Agr8flson@aol.com
Posted on May 31, 2010
No pressure once trigger is squeezed
We will have to just guess what this trigger is on :>)
AR Blue Clean - Spray Gun Trigger Squeezed, No Water Pressure
https://www.arblueclean.com/.../ar-blue-clean-spray-gun-trigger-squeezed-no-water-p...
When the spray gun trigger is squeezed, water comes out but there is no pressure. ... The RED color must stay in the window once the button is released.
pressure washer won't start unless trigger is depressed - Shop Your Way
https://www.shopyourway.com/questions/1151701 Jan 11, 2012 - pressure washer won't start unless trigger is depressed ... Thank you for your question on the pressure not starting unless you have the trigger pulled. ... After about 4 or 5 pulls the pump has built up enough pressure to make it ...
Pressure Washer Troubleshooting In-depth Beginner's Guide
pressurewashr.com/pressure-washer-troubleshooting/ Jul 5, 2017 - After holding the trigger to keep the water running through the machine ... (but not water supply) and release pressure by squeezing trigger gun.
Nov 21, 2017 | Garden
Why does it build pressure, but when I squeeze the trigger the engine stays at idle?
POSSIBLE this look picture hose coupling with water stop put on the tap side or lime in valves after long time or a nozzle with dirt close beaten
clogged nozzle on the lance
Bypass not working (lyme)
if you disconnect the lance and the handle grip is giving enough water and water comes out then the nozzle clean it with a little paperclip.25944841-me02dbjx1ofpduv3i0g3gg4u-5-0.jpg
Nov 06, 2015 | Garden
The engine cuts off when i squeeze the handle on the sprayer, what is causing this to happen?
Sounds like a bad unloader valve. Do a search on "pressure washer unloader valve symptoms". When they are faulty there will either be little pressure or it will stop an engine abruptly. The engine will not just die down as it you were turning it off. It would stop cold.
May 28, 2015 | Homelite Pressure Washer. 2700 psi 2.3 GPM...
Why is my unloader valve opening and closing when I'm not squeezing the trigger\
thats exaclty what a unloader valve does it unloads the pump when the trigger on wand is not depressed , it should however reseat and close off when trigger is pressed giving full presure to wand tip
May 11, 2014 | Northstar Professional Series Pressure...
Craftsman 580 767101 when i squeeze the handle pressure it loses pressure. If i squeeze i get a burst of pressure, it then fades out. Relese the handle and squezze i get another burst
Sounds like the inlet water source may be blocked. When you hold the trigger open, water should flow freely. If this is not the problem, it may be that the pump seals are going bad.
Jan 21, 2014 | Craftsman Garden
The trigger on the wand of my Karcher model K 368 M will not re-engage for several minutes after the trigger is released. If I repeatedly squeeze the trigger for a few minutes, eventually the switch will...
it sounds like a flow switch that is installed in the inlet of pump can get stuck at times if you have a soap nozzle select it usually more flow moves the flow switch try and clean the flow switch if possible.
Aug 10, 2013 | Karcher K3.68MR Electric Pressure Washer
When I squeez the handle the pressure surges.
Hi:
Sep 24, 2009 | Karcher 2500 PSI Pressure Washer
Garden Logo
131 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
