Question about Belle Foret BF-NBBS2-CP Junior Basket Strainer by BFNBBS2CP BFNBBS2-60
Sink Basket leaks and cant be removed cause of silicon adhesive
I followed your instructions on installing a sink basket in my new stainless steel sink using silicone for a sealant under between the basin and the basket as per your instructions. Unfortunately it leaks and I am unable to remove the basket because of the strong seal it made. How do I remove the basket without damaging my new $300 sink?
  • 61 Answers
Steady pressure from under the underside of the sink should cause the silicone to flex and eventually release.
You might also try some caulking remover available ot hardware stores. It's a product that comes in a tube and eases the removal of caulking products.
Be sure to look at the label for cautions and materials that it is safe to use it on.
Posted on Oct 27, 2009
Need to remove the bottom ring from the sink assembly.
This is done with a sink basket wrench from hardware store.
Google search and it will display images.
http://www.amazon.com/gp/product/B000BQMKA6
While at hardware store, go look at new sink basket and see how wrench attaches to nut on bottom of sink basket. A hammer and screwdriver are usually not enough, but might loosen the large nut if lucky, but not best plan.
How to: Lay on back under sink, and position mouth and eyes directly beneath sink basket so stuff can fall on face. Then crawl out from under sink and get glasses and flashlight to help see stuff falling in face. Then crawl out from under sink and call neighbor to come over and hold sink basket from top using two screwdrivers down the hole while you twist wrench only to discover you are twisting wrong direction. Have neighbor install 2 new batteries in flashlight while you lay under sink thinking about chiropractor bill. Then while laying on back and facing nut from below, turn sink basket nut counterclockwise and it will come off quickly.
Copy following link for removing garbage disposal sink basket with tips for re-installing tubular drain lines.:
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html#install
Gene
h
Aug 18, 2013 | Electrical Supplies
There are no instructions with the product. 1. Do I need Plumbers Putty to get a good seal on the sink drain hole? 2. There are 3 washers: 1 thick rubber washer; 1 thin rubber washer; and 1...
If you want to use the washers you place the thin rubber one on the top under the basket... then place the thick rubber one on the bottom first and then the paper washer...then turn tight...
If prefer either plumbers putty or clear silicone instead of the thin rubber one on the top...
heatman101
Jan 11, 2011 | Moen 22036 Stone Stainless Steel Sink...
My badger 5 is leaking from the bottom around what seems to be the electrical cord opening. any suggestions
Your disposal is rusted out and needs replacement.
Garbage disposal mechanism cannot be disassembled for repairs.
Here are basic disposal parts:
1) Sink basket that connects to sink and is held with 3 screws from below.
2) Disposal body which connects to sink basket using metal ring.
3) Rubber washer between disposal and sink basket.
4) Dishwasher connects to upper part of disposal with a hose.
5) Electric wire coming from disposal switch connects to disposal near red reset button.
6) Tubular drain pipe connects to side of disposal
You might be able to buy time filling hole with epoxy or silicone caulk and let dry for 2 days.
10-year old garbage disposal had a good run.
Disposal will need to be replaced at some point.
When I worked apartment maintenance, we replaced disposal with same size and brand disposal.
That way we didn't have to change out sink basket or move pipes around under the sink.
How to: Disconnect 2 nuts on p-trap and trap falls loose.
Using hammer and screwdriver, rotate steel connector disk that holds disposal to sink basket, and disposal comes off.
Before installing new disposal.
Attach electric wire to new disposal, black wire to black and white to white, and push in red reset button.
Attach dishwasher tube to new disposal. Knock out plug inside dishwasher opening.
Lift new disposal up into place, and attach to old sink basket.
There is a rubber washer between disposal and sink basket, Use new washer.
Connector ring catches at three points, all three have to connect.
You can use bottle jack to lift disposal if you have problem.
Re-assemble tubular pipe.
Image shows direction for connecting new disposal.
If this is your home, you want new sink basket that comes with new disposal because it looks shiny and new.
Buy a tub of plumbers putty also.
Remove 3 screws that hold sink basket, remove basket and clean sink opening.
Put finger-size roll of plumbers putty around sink opening, and then push new strainer basket into plumbers putty.
Tighten basket from below, wipe away excess putty around sink opening.
Install new disposal as described above.
Tips for tubular pipes:
When taking apart tubular pipes, start at p-trap and take apart as few pieces as needed to do job.
On image above, loosen both upper and lower nuts, trap falls loose, and then work on disposal.
Any tubular drain pipe that gets moved while working under sink needs to be disassembled, cleaned and re-assembled.
Metal pipes have rubber washer >> always use new rubber washers.
Plastic pipes have plastic washers > plastic washers can be cleaned and re-used.
Plastic washers have flat side that goes toward nut, tapered side away from nut.
When reassembling tubular pipe, we use rectorseal on washers and joints.
Slap a good amount on washer just before pushing washer in place and attaching nut.
Rectorseal will ensure tubular drain pipes won't leak.
Add a comment for more free help.
Also take advantage of fixyas phone service.
For a price, fixya expert speaks with you over phone while you work on disposal, or any do-it-yourself project.
Jan 11, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Making a metal grinding sound when turns on but dont feel any forks or spoons in it
Garbage disposals can get noisy and sound like they're eating spoons instead of banana peel.
You can put vacuum hose in sink opening and see if something is in there.
As long as disposal disk rotates freely, and disposal is not shaking around and causing pipes to leak, then you can use it until it dies.
Otherwise, the bearing is probably rusted, or something is loose. Disposals rust out and eventually freeze, or the motor slows down and overheats, or they rust a hole and water leaks under sink.
I wrote tips for replacing disposals that you can use when disposal gives out.
When I worked apartment maintenance, we replaced disposal with same brand and size disposal.
Rotate steel connector disk that holds disposal to sink basket, and disposal comes off.
Attach electric wire to new disposal, and push in reset button.
Attachment ring catches at three points, all three have to connect.
Remove old sink basket and clean sink opening.
For a price, fixya expert speaks with you over phone while you work on disposal.
Jan 08, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Two rubber gaskets and a fiber gasket came with new strainer. do i use all the gaskets? what about plumbers putty
You are attaching sink strainer to sink opening.
1) Use plumber's putty. Finger-size roll of plumbers putty is applied around opening from top, or applied to the bottom of strainer basket. (Some sinks require silicone. Do not use silicone unless required by the sink manufacturer.)
2) Sink strainer is pushed into the sink opening, making sure it is centered and level.
3) From below, the rubber gasket is applied first, and then the paper gasket is second, and then the basket locknut.
4) Tighten locknut very firmly.
5) Wipe away excess putty on bottom.
6) Push down stainer from top again, and tighten nut some more.
7) Wipe away excess putty around bottom and top.
8) The cardboard washer lets the locknut rotate easily.
Dec 18, 2010 | Moen 22036 Stone Stainless Steel Sink...
There is water leaking down the electric wire at the bottom of the unit. What could cause this? the unit works just fine.
Once disposal rusts out, it needs replacement.
Usually if sink basket seal is broken or if dishwasher attachment is leaking, you can feel water near top of disposal.
Use paper towel at top to see if that area is wet.
If top area is dry, then water is coming from inside disposal, and disposal is rusted out.
If sink seal is still good, we used to buy same brand disposal and re-attach to same sink basket. That's the quick fix.
If this is inside your home, you probably want to install new sink basket that comes with disposal.
To install new disposal, also buy container of plumber's putty to seal sink basket.
Remove disposal.
Clean off old putty on sink. It will chip off easily.
Apply finger-thick amount of plumbers putty to sink opening.
Set disposal sink basket into putty and push down.
Tighten screws on bottom of sink basket.
Wipe away excess plumber's putty from sink so it looks nice and smooth.
Before lifting disposal into place, attach electric wires and attach dishwasher hose to disposal.
Use hammer and screwdriver to remove steel blocker located inside dishwasher stem ... the blocker is left in place if no dishwasher hose is attached.
Disposals can be different: But here's the usual sequence:
Lift disposal with one hand and hold level. Push up strong while rotating attachment ring until ring grabs bottom of sink basket.
If you cannot lift disposal with one hand while rotating attachment ring with other hand, use small bottle jack from auto-parts store. And put piece of wood between bottle jack and aluminum disposal so disposal doesn't break.
Here's how to handle tubular pipes below sink:
Any tubular pipe joint that moved while removing or installing disposal, has to be taken apart, cleaned and re-attached.
If washers are plastic, then clean and re-use.
If washers are rubber, then replace each washer with new rubber washer.
When reattaching tubular pipes, apply generous amount of rectorseal over each plastic or rubber washer for first-time seal of tubular pipes.
Nov 19, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I have a kohler cast iron enamel sink. The
ALL BASKET STRAINERS ARE PRETTY MUCH THE SAME. PLUMBERS PUTTY WORKS FINE. I BELIEVE ITS THE ORDER OF INSTALL THAT IS CAUSING THE LEAKS. STRAINER AND RUBBER GASKET GOES IN FROM THE TOP. IF NO RUBBER GASKET IS PROVIDED, THEN PLUMBERS PUTTY WILL SUFFICE. UNDERNEATH, ANOTHER RUBBER GASKET AND/OR PAPER GASKET, THEN THREAD ON THE NUT. TIGHTEN IT SNUGLY.
Dec 25, 2009 | Plumbing
We purchased a franke double sink at lowes for $108.00. we cannot get the basket to stop leaking, we've used plumbers putty as suggested but its not working and the sink still leaks. what can we do
Take it back out and clean all of the plumbers putty off. make sure that the bottom of the sink and the basket is clean and dry. Take a good quality silicone caulk and make a 1/4" bead all the way around the basket where it meets the sink. Tighten the basket nut till it gets nice a snug but not os that you spin the basket much. Then let the caulk setup over night. Trim away the excess with a sharp knife from the top and hook up the drain. This will seal a basket everytime. I never use plumbers putty anymore.
Nov 14, 2009 | Franke VNX-120-45 Vision Double Bowl...
I need a new franke sink basket strainer for my franke sink model PRX11021 - stainless steel. What is the model number that will fit this sink and can I order it online or go to a local store?
You should purchase a complete basket strainer assembly. Home Depot or Lowes have some very nice ones. They are a standard size.
Tell them it's for your kitchen sink.
Jan 28, 2009 | Plumbing
How to Install Stainless Sink Baskets?
The stainless steel basin had a pair of big holes in the bottom, suitable for attaching strainer baskets or a garbage disposal. The basket comes with a black rubber gasket that seals underneath the basin, a thick paper washer, and a die-cast metal lock nut to clamp the basket onto the basin. There is also a smaller lock nut that connects the sink tail-piece (the first part of the drain system) to the basket. You should apply a bead of clear silicone to the rim of the opening. Also apply a small bead of silicone to the underside of the edge of the basket. olding the basket by the center, set it in the hole and gave it a slight turn to spread the silicone slightly. Down Under: apply a thin layer of pipe thread compound (a.k.a. pipe dope) to the larger diameter threads. Few plumbers use thread compound here, but I believe in lubricating threads whenever possible. There have been so many times that I needed to remove a basin lock nut, but was unable to because of the slight corrosion that inevitably forms there. Thread compound would prevent this problem. The metal lock nut, the rubber gasket and the paper washer were installed, turning by hand most of the way. The only practical way to tighten these huge lock nuts is to use a pair of 18" jumbo Channel-Lock pliers. To hold the basket from turning, use a pair of screwdrivers placed in an X-formation in the little holes. The lock nut must not be over-tightened, or the rubber gasket can be squeezed out of place, which could cause a leak.
Aug 27, 2008 | Belle Foret BF-NBBS2-CP Junior Basket...
Belle Foret BF-NBBS2-CP Junior Basket Strainer by  BFNBBS2CP BFNBBS2-60 Logo
314 people viewed this question
Top Belle Foret Plumbing Experts
Donni Steen
Tom Chichester
Are you a Belle Foret Plumbing Expert? Answer questions, earn points and help others
