Question about Lexmark Office Equipment & Supplies
WHY DO I NEED TO PRESS START BUTTON TO RECIEVE A FAX? FROM AN OUTSIDE FAX.
    President:
  • 1,653 Answers
This happens as you have set the fax to MANUAL RECEIVE. Try setting it to AUTO RECEIVE and then you just leave it unattended.
Posted on Oct 07, 2009
What do i do to recieve fax
Select the receive mode.
(1) Press the FAX button, and press the Menu button.
(2) Use the (-) or (+) button to select Receive mode set. in the Fax settings menu, and press the OK button.
(3) Use the (-) or (+) button to select a receive mode, and press the OK button.
The screen will return to the fax standby screen.
Nov 08, 2013 | Canon PIXMA Office Equipment & Supplies
How do i get a fax confirmation to print out????
Follow the steps below to enable the Fax confirmation report.
Press SETUP button on front panel
Use Right or left arrow till you find Print Report - Press OK
User right of left arrow till you find Fax Confirmation - Press OK
You will find few options like
1. Fax Send Confirmation
2. Fax Recieve Confirmation
3. Fax Send and recieve
Choose the one you want and press OK
* Please rate this solution and write comments
Nov 12, 2010 | HP Officejet 6500 Wireless All-in-One...
Recieve mode
Hi slickkitty
Only one press for each display,
When you press the FAX RECEIVE MODE button, the display should change each time you press. eg: AUTO, FAX ONLY
When you see the FAX ONLY, press the SET button and leave it like that. Don't try to do it when the fax rings. Do it when the fax machine is idle.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} The following instruction is found in your Fax Manual.
Set the fax machine to FAX ONLY mode by
pressing {RECEIVE MODE} until the
following is displayed.
1 The display will show the number of
rings before the fax machine answers a
call in FAX ONLY mode.
2 Press {+} or {-} to change the ring
setting to 2 and press {SET}.
How to receive calls
Just leave it. When the other party sends a fax,
the fax machine will receive it automatically.
Hope this will help, if it helped you, please give a rating.
Good luck
luciana44
Sep 19, 2009 | Panasonic KX-FHD332 Plain Paper Thermal...
Panasonic uf 4000 fax not answering
Sounds as if your Fax is set to Tel Mode.Change to Fax as follows.
Function 7,then no 4.
Will show fax parameters? on screen.Press Start arrow up to recieve mode.Arrow across to change to Fax or Fax Tel.Press start to lock in.Press cancel button to return to raedy screen.
Sep 01, 2009 | Panasonic PanaFax UF-490 All-In-One Laser...
Brother Fax 2820 - The phone rings on it, but the fax come
Check if the machine is set on automatic recieve.
When on manual recieve, you'll have to start recieving manualy by pressing the button.
Jul 13, 2009 | Brother Office Equipment & Supplies
If I pickup another phone and it is a fax, what code do I press for the fax to receive it.?
During the call, press START FAX Black or START FAX Color (whichever you prefer). When prompted, choose Fax Recieve on the the printer. It should then start to recieve the fax.
Mar 19, 2009 | HP J3680 Officejet All In One Printer
I can send but cannot recievefax. Fax is on SLEEP all the time.
The machine is set with the sleep mode as a default. The fax part can be changed to recieve a fax by pressing the fax mode button. Press it until it says Fax only, not F/T. F/T means Fax/Telephone. This mode would make it to where you have to pick up the reciever and press start when a fax comes in. The Fax only mode means it will pick up everytime a fax comes in automatically. Let me know if this was helpful. Please give my helping a rating. Thanks!
Feb 11, 2009 | Brother IntelliFax-4100e Fax
Sending a fax
First make sure that the fax button has been pushed and is llit...
The 2820 should have a handset. In order to use manual transmission (when you get to hear all the beeps and whistles) you will need to load the document then pick up the handset. then dial the number, when you hear the recieving fax tone then hit the start button.
The 2820 should also have a hook hold button pressing this will allow you to hear the dial tone and the numbers you dial along with the receiving fax tone. If you dont hear anything when you press this button then you may want to use the volume buttons to increase the volume.
Also remember that if you have not picked up the handset or pressed he hook/hold button the unit will use automatic mode, which is to say that all you will do is load the document, dial the number, and then press the start button.
May 19, 2008 | Brother IntelliFax-2820 Laser Fax
Not able to recieve fax
Note u will be losing all our faxes stored in memory and contacts...
Disconnect the power cable from the back of the printer.
Hold down the Stop/Clear button.
While keeping the button pressed down, reconnect the power cable. A message on the LCD will display MEMORY CLEARING.
Note: The Fax, Copy and Scan buttons will remain ON until the message disappears. Only the Fax button should be ON when the function is complete.
Select the personal settings you require as follows:
LANGUAGE? Press the right arrow key to select the language you want to use, and then press Select.
COUNTRY CODE: Press the right arrow key to select the country you will be using the printer in, and press Select.
ENTER DATE: Using the date format dd/mm/yy (in the USA, mm/dd/yy), press Select.
ENTER TIME: Using the format hh:mm, press Select.
Select Format: Press the appropriate number to choose between 1=12hr, 2=24hr.
PERSONALIZE FAX: Press Select.
Enter Name: Type in the name and press Select.
Enter Fax Number: Type in the number of the phone line to which the printer will be connected, and then press Select.
Feb 16, 2008 | Lexmark X4270 All-In-One InkJet Printer
21 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
