When I turn on my laptop it goes on but the screen is black and it seems locked up. Tried control, alt, delete and turning off and on but nothing works.
    Novelist:
  • 225 Answers
Do this:
1. turn off laptop. press and hold on D key then press power button once. check if you will see color display in the whole screen as normal.
2. turn off laptop. press and hold on the Fn key then press power once. Check if no display. if laptop is on for about 3 minutes and still no display just wait for the beeps.
3. Try connecting laptop to an external monitor.
Now, when you tried no. 1 colors was fine then LCD is ok. now, no. 2 when laptop is on and no display but heard beeps means video is the problem. when u tried no. 3 laptop has no display but external monitor has then LCD is the problem.
Posted on Oct 07, 2009
    Scholar:
  • 105 Answers
In stead of alt crtl del try pressing F8 key on keyboard after you turn it on, it will display a few options. go from thee.
in case it does not stars, you may have a faulty memory ram. it needs to be replaced
When I turn on my Samsung laptops sometime s the screen goes black and it says camera ... looks like there s something wrong with your camera and I should trouble shoot it , but it wont go to s
Go to your Control Panel, click System, Device Manager, look for Imaging Device or Camera depending on what Windows you are using click the drop down, click Tab (Driver) then Roll back driver, It will set it to default. Good luck.
Feb 17, 2015 | Samsung NP300E5C-A02US Series 3 15.6"...
Monitor goes blank less than a second after turning on.
Sounds like either there is a bad connection from the computer to the monitor, or the monitor has a faulty power regulator, causing the monitor to overheat prematurely, and shut off.
Feb 21, 2008 | Proview PL926WBi 19" LCD Monitor
I have a Toshiba A505-S6960 laptop. Never have had a problem until today.......when I turn the laptop on it goes through the boot process but only makes it to the Toshiba logo screen with the F2 and F12...
It seems that your computer is not seeing your hard drive. This could either be because of bios settings or more likely because the hard drive has failed. If the unit is under warranty, call Toshiba support and describe the issue to them. If not, places like Best Buy can determine for sure the cause of the issue.
Toshiba Support
May 16, 2011 | Computers & Internet
I turned on my m-675 yesterday and got the gateway green and black screen that just continued to stay there. After 5 minutes I used the control/alt/delete buttons to reboot my computer. Now, my computer...
From the information, that you used control/alt/delete to re-boot, I am assuming that you sensed that the computer finished the booting process. Meaning the tell tale sound (music) of windows booting was there, the hard disk whirling (blinking LED) for a certain period and stopping etc. If that is the case, (meaning you think your computer is capable of booting) probably you have a display failure. If you have a VGA cable connect that cable to the VGA connector (0n your laptop) and connect the other end to Desktop screen (monitor) or a TV screen with a VGA input. Probably you will see a display right away. If not press the Fn key and the key which changes the screen from laptop to external screen. This key will be marked either as CRT/LCD or with a picture( a square with two lines on either side of the square). If you get a display there, you may need to get a technician to change the screen.
Feb 11, 2010 | Gateway M675 Notebook
Qosmio F25-AV205 won't boot. When I turn it on no noise comes out at all, and it goes directly to background screen with no icons. Cursor is present and moves normal, right click brings up refresh menu,...
hit control/alt/delete to bring up task manager. then, click on the "file" tab and select "run". type "explorer" into the "run" box, and you will have opened windows.
then, go back to the "run" command and type "msconfig".  scroll through the "services"  tab to ensure that "explorer" is checked.
Dec 24, 2009 | Computers & Internet
Keyboard suddenly stopped working - can't turn off or Control Alt Delete
  1. Disconnect power supply
  2. Remove battery
  3. Wait 30 second
  4. Reïnsert battery
May 05, 2009 | Computers & Internet
Power Light on but screen black
Try powering up with no battery connected. If that works then the battery may be faulty or too old.
Feb 15, 2009 | Computers & Internet
My Toshiba satellite A205 turns black
seems your OS got stucked so remove your all external devices if they are connected (ex. pen drive, Ipod CDs etc)
and reboot your PC once.
if still does same then you need to repair your PC using recovery or OS disk.
post back if anything changes.
Good luck
Feb 07, 2009 | Toshiba Satellite A205-S4707 Notebook
Computers & Internet Logo
141 people viewed this question
David Payne
David Payne
