Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
KEYPAD ACCEPTS CODE PROGRAMS BUT DOESN'T OPEN GARAGE DOOR.
    President:
  • 3,197 Answers
If your hand remotes work and you have a good battery in the keypad then it has most likely just quit working. A replacement is needed.
Posted on Oct 07, 2009
I am trying to enter a new code on my outside garage door opener keypad, however, it does not have an enter button, what do I do after I already erased the old code. thanks
If your keypad is hardwired do this:
To program the keypad, first unplug the garage door opener from the electrical outlet. Next, remove the nameplate from the console that the keypad plugs into and locate the program/operate switch. Flip the switch to program. Next, enter your desired four-digit PIN number into the keypad. Slide the switch back to operate and plug the garage door opener back in. The keypad should be programmed.
Aug 31, 2011 | Sears Craftsman LiftMaster Chamberlain...
How to reset code for keypad after reattaching wires
Mar 05, 2011 | Sears Craftsman LiftMaster Chamberlain...
How to reset garage door opener pad without old acess number
A Stanley garage door keypad is wall-mounted, battery-operated device that allows you to open your home's garage door electronically without having to manually lift the door or use a pull chain. The keypad uses a four-digit access code that you program after the keypad is initially installed. You can change the code, disable the keypad manually by entering a invalid code and reset the keypad if the device is not working properly. After you reset your Stanley garage door keypad, the device is ready to accept a new access code.
May 29, 2010 | Sears Craftsman LiftMaster Chamberlain...
Hardwired code opener no longer works
Here are the directions to program your hardwired keypad.
First unplug the garage door opener from the electrical outlet. Next remove the nameplate from the console that the keypad plugs into and locate the program/operate switch. Flip the switch to program. Next, enter your desired four-digit PIN number into the keypad. Slide the switch back to operate and plug the garage door opener back in. The keypad should be programmed.
Oct 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door keypad
It doesn't work "enter..code..enter." It works "code..enter."
Aug 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
Can not program both keypad & remote to operate at the same time
One of your units has reverted from "rolling code" to "billion code" and as you have found they will each work but will not work with each other. The problem is finding out which unit reverted. The most common one is the hand remote but that could be wrong.
Aug 09, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have LiftMaster garage door model 41A3039 and Chamberlain wired keypad--how do I change the keypad code to open the garage door
To program the keypad, first unplug the garage door opener from the electrical outlet. Next remove the nameplate from the console that the keypad plugs into and locate the program/operate switch. Flip the switch to program. Next enter your desired four-digit PIN number into the keypad. Slide the switch back to operate and plug the garage door opener back in. The keypad should be programmed.
Jul 13, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door will only close with keypad code it will not open
UNPLUG THE UNIT AND WAIT 5 MIN.
WHEN YOU PLUG IT BACK IN CLAER ALL CODES BY HOLDING DOWN THE PROGRAM BUTTON FOR 20 SECONDS.
NOW TRY TO PROGRAM EACH REMOTE AND KEYPAD - IF THERE IS STILL A PROBLEM CHANGE THE BATTERIES AND REPEAT THIS PROCEDURE.
I HOPE THIS HELPS
Mar 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
