Question about Brother Sewing Machines
I have a brother ce5000prw and not sure if I am threading it correctly. I've read and reread the instructions and when I start to sew it jams up on me. HELP
  • 323 Answers
SOURCE: industrial brother sewing machine, older
Check the hook for burrs, nicks or rough spots.If you find any, they need to be removed with a sharpening stone or emery stick. Buff it with a fine emery cloth until it is smooth .
Check the needle. The long grove goes to the left.
sewman7
Posted on Jul 10, 2008
  • 9 Answers
SOURCE: NEEDLE KEEPS COMING UNTHREADED WILL NOT CATCH IN FABRIC
Make sure you are threading the machine correctly and it has the proper tension. Also check the bobbin the thread has to go thru the little lash
Posted on Jun 14, 2009
SOURCE: Very inexperienced sewer! How do I thread it?
The way I solved this problem was to take a break! When I resumed I was more patient and found that I wasn't doing the bobbin right. I took my time and got it right this time....hooray!
Posted on Aug 25, 2009
  • 22 Answers
SOURCE: Jammed spool pin on a Brother CE5000 PRW sewing machine
Try a little oil and let it set befor pulling.
Posted on Nov 10, 2009
Testimonial: "Awesome solution- thanks so much!"
  • 300 Answers
SOURCE: I have a Brother PC-420, 6 months old, originally
It needs some adjustments that are covered by the warranty. Bring it to the pros.
If you try to fix it yourself, the warranty will be void.
Posted on Feb 12, 2010
I have a brother xl 5500 it keeps breaking the top thread no matter what i do
Go back to your instruction manual, some available online. to Re-thread the machine completely and make sure you are threading correctly. If that's not it, you may have thread jammed in a mechanism and it needs a technician's tools to get at it properly.
Cheers,
Kelly
Embroidery Services
San Diego, CA
Feb 25, 2015 | Brother XL-5500 Mechanical Sewing Machine
I've a Brother XL 3500 sewing machine and when I
try these suggestions
Try these suggestions
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case, & make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
Apr 11, 2013 | Sewing Machines
Brother 700e
1. Change needle
3. Take the bobbin out --make sure it is inserted correctly into the bobbin
Case, & make sure the bobbin is turned the correct way
Aug 16, 2012 | Brother SE-270D Computerized Sewing...
I have a brother model 385 1551600 serial 03024885 I have not used it in about 3years. My problem is when i start to sew it will stich maybe a inch then the thread jam up in the bobbin area i'm th
change the needle
clean under the needle plate area & in bobbin area for loose threads & lint
make sure the thread isn't coming off the thread take up lever
since the machne has not been used in about 3 years it may need to be serviced
Mar 17, 2012 | Brother Sewing Machines
The thread keeps jamming under the feed dogs. The machine takes about 2 stiches and then it won't move any more, but it keeps sewing making a terrible mess under plate. What can I do to fix this...
I had the same problem and tried everything you did: rewinding the bobbin, checking to be sure I had the bobbin in correctly, checking the upper threading, readjusting the tension. When nothing I tried helped, I bit the bullet and took it to the shop where I had bought it. The timing was off; there were burrs on the bobbin case; the hook was not performing correctly;there were threads caught between the tension disks. It cost about $65 but when I brought it home, it purred like a kitten! I suggest you take it in for a check up! Especially if you've tried all the usual tests and none of them worked.
I'm sorry I couldn't give you a do-it-yourself answer but sometimes they've just gone beyond what we can do for them.
Jul 24, 2011 | Brother SE350 Mechanical Sewing Machine
Nov 03, 2009 | Yamata FY101-1A
I have read and reread the instructions and have followed it to a t and I can't get the bobbin thread to come up to loop
Make sure you pull the bobbin thread out and hold the end while cycling the machine at the start. You need to have a goodly length or it will just not be pulled out.
Jul 25, 2009 | Singer 7444 Mechanical Sewing Machine
May 27, 2009 | Brother LS-2125 Mechanical Sewing Machine
Code E6 on Brother CE5000PRW sewing maching
I fought with this machine so much, then felt like a fool. It wasn't threaded properly, and I needed to re-set the tension.
Thanks for being there - if only to vent......
Nov 22, 2008 | Brother Sewing Machines
Brother PE 400 D threading bobbin problems
im going to help you as much as i can,,,,try using a bobbin that is already threaded and make sure bobbin is in bobbin case correctly, make sure machine is threaded to instructions in book,,,if this is all done exactly u should not have a problem unless something is jammed
Jan 20, 2008 | Brother Disney PE-400D Computerized Sewing...
Sewing Machines Logo
131 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
