Question about RCA R52WH73 Projection Television
Rca no longer offers part
Looking for part #259880. ribbon cable
  • RCA Master
  • 8,617 Answers
You can get them at www.tvrepairworld.com just leave them a email and they respond quickly
Posted on Oct 08, 2009
RCA LCD TV INVERTER BOARD
I have a new power/inverter board for a L32HD32D RCA 32" flat screen LCD TV. Make offer, 1-907-225-2337 I'll ship it USPS in the box it came in.
LS2HD32 CEG379B CAJAID, CAJA4465 1114363 are some numbers on the package it came in. You might try LPS#1 on the ribbon cables & their video board connection for the LCD by opening the back 4x5" pannel in the middle & clean reinstall them ? That's what fixed my TV, maybe. So I don't need the board now. It's only about a 5 minute job to clean the 2 ribbon cables.
Sincerely Bitdog
Feb 05, 2010 | RCA L32HD32D 32 in. LCD HDTV
RCA cable
Looking at the Target website, they offer an RCA cable that will connect your TV to either a Playstation or XBOX.
The cable is made by Monster Cable, and is called a Universal S-Video/Composite Cable for Xbox and Playstation 2. Target charges $20.79 +tax.
All of the Playstations, except the PSP, can use the same connector.
On the Target website, search for 10853408. That is the catalog number.
Other stores like Walmart, Best Buy, etc. may also offer this cable or one similar.
Nov 21, 2009 | Sony Playstation 3 (PS3) Console
I have a RCA model no; cdrw121 2 disc recorder.after 1 or 2 songs recorded in the record tray, the player recover light comes on whitch means that the disc is no longer useiable.
Hardware problem. Replace the flat cable of the recording optical pick-up, if that doesn't work replace the unit. A replacement recording pick-up isn't available commercialy.
Oct 28, 2009 | RCA CDRW121 2-Disc CD Recorder
RCA tv model D52W14
That is an ITC222 chassis and likely the HOT has shorted, 2sc5588 Rca Part # 259899
You might also check Cp150 2200uf/16v in the 6 volt line, a common failure. Always replace Cp120 330uf/35v & Cp150 2200uf/16v and always resolder Cl031 & Cl032...
There is also a tech bulletin Tv-06003 Dated 12/8/2006 which states:
Replace deformed ribbon cable plastic connector BP005 on the flyback board. This connector is warping or bowing (May Not Even Look Like It) and causing poor connections to the ribbon cable. Replace Rca P/N # 258686.
Try putting pressure on the BP005 connector and turn the set on, you may find the set will now work fine. Replace connector and you may wish to replace the ribbon as well while you are doing the repair!
This set is notorious for failures like this and it is not uncommon to find multiple problems.
Hope this helps!
Bill
Aug 08, 2008 | Televison & Video
Have a RCA D52W15 w/ ITC222 board. TV will turn on and stay on for about 20mins and then it will shut off. I have been trying to play an Xbox hooked up through component cables. I even tried not connecting...
Take a good look at the power/deflection board. The one on the left as you are looking the back. You will find 2 ribbon cables that connect the power/deflection board to the small signal board (the one on the right). Look at the connector that the ribbon cables plug into. If they are black in color that is good. If they are white, that is bad. These connectors do cause intermittant power problems ( or a dead set). They need to be replaced. If they are black, take it to a repair shop.
Jun 06, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA VHS-C screen for sculpture
The resistance of hte wire is not the major problem. While it will degrade the signal somewhat, the main problem will be outside interference. You would be better off trying to hide the camera closer to where the screen must reside and usinga ribbon cable only a few inches longer. You will need to find a service manual for that model to get the pinout of the cable.
Good luck.
Dan
Jun 06, 2008 | RCA CC6374 VHS-C Analog Camcorder
Does Pioneer still offer FREE replacement screen ribbon cables??
Yes they will replace the ribbon cable for free for only one time. but if you did the bypass mod they will unmod it and charge you $200 for doing it. In that case you better of send it to that guy Rich with Same Day Audio Service on Ebay, he will fix it with his company manufactured milspec ribbon cable for I think $85. His cables are much higher quality than Pioneer's and come with a free lifetime warrantee if you have it perform by him or you can purchase the cable from him and put it in by yourself but he won't guarantee it if you do. It not very hard to do if you are a little bit technical incline. I bought a few cables and replaced them myself with the Ribbon Cable Exhausted Tutor Guide on AVIC411.com, but I have figured out a much easier way to do it. Let me know if you need help. Goodluck to you.
Mar 04, 2008 | Pioneer AVIC-N2 Car DVD Player
RCA P56930BL strange text
The Gemstar board is most likely at fault. The part number is 241271 but, is no longer available. The Gemstar board is a small metal box with usually two white ribbon cables going to it. Alot of times the ribbon cables are not seated correctly or dusty. With no power to the TV disconnect the ribbon cales one at a time and used compressed canned air and blow ow the sockets on the Gemstar board and the main board. Make sure you reinsert the cables correctly as they only have conductors on one side.
Jan 25, 2007 | RCA P56930BL 56" Rear Projection...
RCA R52WH73 Projection Television Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
