Question about ASUS K8N-E Motherboard
Asus k8n-e when xp strat loading the sytem reboots automaticaly
    President:
  • 2,351 Answers
There are two Asus K8N-E MB models;
http://www.asus.com/Search.aspx?SearchKey=K8N-E
Chances are there was a problem during the installation of windows XP. Or there is an issue with your hard disk drive. During boot up, press the F5 key every 2 seconds. Windows Advanced Option Menu will load. From the list highlight, Safe Mode with Command Prompt & press enter. Type the command, C: space fixmbr & "press enter". Wait a few seconds for fixmbr to run.
Than press ctrl+alt+delete to reboot your system. If windows still restarts you will need to reinstall windows XP. A Fresh install is preferred. Running windows repair can make matters worse. Every hard disk drive manufacture has software to setup their drives. Example: If your hard disk drive is made by Seagate, go to Seagate’s web site & download their setup software. Download SeaTools for DOS now!
http://www.seagate.com/www/en-us/support/downloads/seatools/
Instructions are included on the site.
Here is the link for Samsung; http://www.samsung.com/global/business/hdd/
For Western Digital;
http://support.wdc.com/product/download.asp?lang=en
Use the manufacture’s software to setup your hard disk drive before installing Windows XP.
Cheers!
Mike
Posted on Oct 08, 2009
K8n neon 4 platinum 1 audio drivers
Hello you can download the drivers here:
http://www.msi.com/product/mb/K8N-Neo4-Platinum--PCB-1-0-.html#/?div=Driver&os=XP%2032
By selecting your windows system.
Click on the sound link for download.
The file needs to be unziped, before you install the driver.
Reboot after the install is done.
Here is no drivers for windows 7.
Here are the other models:
http://www.msi.com/service/search/?kw=K8N%20Neo4%20Platinum&type=product
Good luck
Feb 16, 2013 | MSI K8N Neo Platinum Motherboard
I have an Asus K8N-E motherboard which does not seem to support booting from USB. Any suggestions?
You must configure the BIOS prior to booting up from USB. With the USB inserted, go to the BIOS setup and change the boot priority as explained on the official user's guide from ASUS (page 61):
http://dlcdnet.asus.com/pub/ASUS/mb/sock754/K8N-E/e2164_k8n-e.pdf
Jul 10, 2011 | ASUS K8N-E Motherboard
I need vga driver
Hi, try the following site for your vga driver, you need to scroll down the page to pick your operating system:
http://www.easydriverpro.com/driver-update/motherboard/asus/k8n-dl/k8n-dl-windows-7.html
Oct 05, 2010 | ASUS K8N-DL Motherboard
How to downlode driver asus mother board k8n-vm ?
Hi, try this link for your drivers:
http://www.driverstock.com/ASUS-K8N-VM-driver-download/6-9-10112/index.html
Aug 13, 2010 | ASUS K8N-VM Motherboard
ASUS K8N MB On board audio doesn't work. I've verified that correct settings in BIOS but signal is not making it to the plug for Line Out. I just installed SP2 so I'm going after new drivers next. Any...
Check FP_AUDIO pin settings. FP_AUDIO is located just below the CD AUX. See page 1-6, Motherboard layout.
There should be a jumper over pins 9 and 10 and pins 5 and 6. This is the default setting chassis rear MB audio output.
See page 1-22.
Unfortunately the audio chip is soldered to the motherboard. Most newer Asus MBs the audio chip is not soldered and can be replaced by calling Asus.
Asus manual; http://dlsvr04.asus.com/pub/ASUS/mb/sock754/K8N/e1868_k8n.pdf
Link to Asus site, K8N; http://www.asus.com/product.aspx?P_ID=zigzffr75jWJ7j2y&templete=2
A possible work around would be to disiable the AC'97 in the bios and add a PCI audio card.
Cheers'
Mike
Feb 04, 2010 | ASUS K8N Motherboard
Vista Home Premium locks up on a load
How long do you wait before you determine it is locked up? Vista uses minimum graphics to facilitate a faster install. It may seem like nothing is going on when Vista is loading in the background. If it is locking up try a reinstall. Are you upgrading or going a new install?
Dec 30, 2008 | MSI K8N Neo3 Motherboard
K8n neo ms-7030
change the first boot device,
go to the bios option by presing del button
ther select your first boot device like hardisk n second is cdrom the f10 for save configuration and press k and check it
Oct 18, 2008 | MSI K8N Neo-FSR Motherboard
Problems with MSI K8N Neo3 motherboard ethernet adapter
Hi mush187, the SMbus controller is basically your chipset drivers. If for some unseen odd reason it did not install correctly you will not be able to install other drivers. (which seem to be the case). Here is the link to you're board & it's drivers. (click on it).
http://global.msi.com.tw/index.php?func=downloaddetail&type=driver&maincat_no=1&prod_no=170
This is nVIDIA's web site. This is where you need to go in order to download & install the latest chipset drivers.
http://www.nvidia.com/Download/index.aspx?lang=en-us
I understand if you can't get you're network driver installed you can't get to the nVIDIA site. So can you install a PCI network card, (temporarily)? The cool thing about nVIDIA's web site is it will scan your system & suggest the proper updated software.
It's only a suggestion.... In either case the MSI link above will allow you to download the drivers you need.
Good Luck!
If I can be of more service, just ask.
Mike
Apr 06, 2008 | MSI K8N Neo3-F Motherboard
ASUS K8N-VM mother board win98 drives
Try going to the Asus website and look for support for your MB drivers and Operating System.
If there is no longer any Win98 support for your MB then I suggest a fresh computer and more recent software for less hassle!
A ten year old OS indicates to me that you might be stuck until you go with the flow!
Cruel but true.
Hopefully the recent cheap prices for computers pre-installed with Vista or XP will persuade you.
Feb 06, 2008 | ASUS K8N-VM Motherboard
ASUS K8N-E Motherboard Logo
154 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
