Question about Williams Heating & Cooling
Williams Heater console floor unit
Older Williams Heater has a manual temp setting, natural gas, electric blower unit. Produces heat up to temp setting, blower goes on and does not stop. Blower should shut off a while after the burners shut off, ideas why not?
  • 89 Answers
Is this a floor furnace? If so sounds like the switch for the blower, which is mounted on the side of the fire box is bad. There should be 2 of them, 1 for the blower to start 1 for the blower to stop when the fire box is cooled down. It wouldn't hurt to just replace both of them.
Posted on Oct 08, 2009
Pressure gauge keeps going down when the central heating goes off ,it is fine when it is on the pressure stays high
Is your central heating unit a heatpump w/ electric heat or natural /propane gas ? And what is the water heater, gas or electric ?
Dec 07, 2015 | Water Heaters
Heating is limited
The system has one temp but the heater temp should be turned all the way up outside on the unit as well
Jan 03, 2014 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Pool heater won't heat water
How big a pool? You normally will not notice a temperature rise immediately. On average, swimming pools will see a one degree rise in temperature every 45 - 90 minutes.
Jan 22, 2013 | Jandy Laars LX Pool Heater / 400,000 BTU /...
I have a williams thermostart . It was off yesterday . today when i tried to start its not getting started . Can you please let me know how i can start it manually using ignition . its pretty cold today
Couple of quick questions: Is the pilot lit and the Control Knob turned to the ON position?
If not, turn it to the ON position.
Has the thermostat been set higher than the ambient room temperature?
If not, set the temperature at least 10 degrees higher than the ambient room temp and see it the burner lights?
Have you checked the outside vent, to make sure it's unobstructed?
If all above the above fails to provide a yes answer, then I suspect that the Thermopile has gone bad. The Thermopile generates milli-volts of electricity that opens the gas valve when your thermostat calls for heat. The heat from the pilot flame against the Thermoplie is what generates the milli-volts of electricity.
They are not difficult to replace and only requires a screw driver and an appropriately sized open end wrench to accomplish the task. You can probably order the part directly from Williams. Also, if you have misplaced your Owners Manual, ask them for one of those too. It will be of help to you now and in the future.
Hope this helps solve your problem.
Mar 01, 2011 | Williams 1403622 Gas Compact Heater
How do you get to the thermocoupling unit to replace it? It appears to go into the heat exchange which is all enclosed. It is a Williams wall furnace. It is an older unit in a rent house.
If you have your manual go to pages 9 & 10 what I call a thermocouple they call a generator, and this is in the gas train with the main gas valve. you may be going after the high limit switch here please do not tear in to that. This will be right in with the pilot assembly and the copper line goes back in to the gas valve.
Dec 21, 2010 | Williams 3003622 Ceramic Wall Mounted...
How to convert a natural gas williams wall heater to lp gas
get the model and serial number abd contact a local wholesaler by going to the last page in your yellow pages under heating and air contractors, you will see a list for distributors call them to see if they carry parts for this unit.
Dec 08, 2010 | Williams (5009622) Ceramic Gas Wall...
How do I adjust the temp on a Williams wall heater model # 1043622?
Found this link to a manual for the Williams Wall Heaters...
Model 1043621.05 is LP Gas Model Model 1043622.05 is Natural Gas Model
http://www.hammerwall.com/Download_Manual/3249/
Temperature is set using a thermostat as explained in the above manual.
Use IE Explorer Browser, manual does not display in Google Chrome as a number of other PDF files don't either, must be a bug.
Nov 12, 2010 | Williams Heating & Cooling
Heating & Cooling Logo
157 people viewed this question
Top Williams Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Williams Heating and Cooling Expert? Answer questions, earn points and help others
