Question about Xante ScreenWriter (Refurbished) Laser Printer
Shut off printer in the middle of a print job. Pulled paper that was halfway out, out manually. Tried to shut off printer and reboot. Cancelled all print jobs, started a new print job, now its stuck flashing READY/PRINTING and never prints the document
  • carchipley86 Oct 07, 2009
    can you tell me where the sensor is?
    Brigadier General:
  • 3,614 Answers
The unit may have a paper jam or stuck object inside, if you have experience a paper jam error before, check the printer for any object or paper stuck inside, clean roller.
Some error like this can be a problem on the feeder sensor and by this time you may need to replace and repair the unit.
Hope this initial info helps
Posted on Oct 07, 2009
  • micromaster
    micromaster Oct 07, 2009
    it was located always near on the feeder, this part function is to detect if there was a paper on the tray
    Genius:
  • 1,043 Answers
Somewhere in the paper path a switch or sensor has either been damaged. The other possibility is that there is a small piece of paper or other foreign material covering the sensor or leaving the switch closed. The sensors and switches are there to let the printer know that a piece of paper is in the path so that it doesn't try to send out more that one page at a time. If you are familiar enough with the printer you can open up the top and side covers and inspect the path. If you do not see any foreign material in the paper path You can also try and gently blow it out with compressed air. If that fails to resolve your issue you will have to take it to an authorized repair center.
Is there anyone who can help with this?
just follow the set of procedures HP recommends for clearing a paper jam, and it should work again. They have some documentation and videos online, here is one of them
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00441807&lc=en&cc=us&dlc=en&product=441125
Jul 31, 2012 | HP Office Equipment & Supplies
I was printing a document when my printer stopped because it ran out of yellow ink. I cancelled the job, replaced the ink. It has been almost two hours and the job is still showing in the queue as...
windows handles the printer spooler issue really bad with this your going to need to reboot the computer but before you do that you need to go to run (under windows xp) type msconfig and go to services and shut off printer spooler under win 7 n vista just type msconfig in the search box and shut if off. then on the reboot turn it back on and reboot again.
Mar 14, 2011 | Office Equipment & Supplies
I turned the power to the printer off in the middle of a job and then cancelled it. There is a paper halfway through and the error light is flashing. I cannot print a new job. Janice Simpson the model...
Disconnect the "data" cable between the printer and your computer.
Turn the printer on.
If the light still flashes, you have a "paper jam".
If you cannot "clear" it yourself, take the printer to a qualified technician, for servicing.
On your computer:
Click Start
Click Control Panel
Click Printers
Double-click the icon for your printer.
Click on the "suspended" (or "active") print-job, to "select" it.
Right-mouse-click on the print-job, and choose "cancel".
Nov 09, 2009 | Office Equipment & Supplies
Paper feed button flashing
Check your user manual for resetting the printer to factory default settings.
If that doesn't work, unplug your printer from the computer and uninstall your software through Add/Remove Hardware. Shut down your computer and reboot. Reinstall your printer software, following the instructions carefully.
This should clear up your problem.
Let me know if you still are having problems. :)
Oct 08, 2009 | HP DeskJet 9800 InkJet Printer
Power light flashes and won't let me print - HP3650 no paper jam
Go into your control panel, go to your printer, right click it, then choose "Cancel all print jobs". You may also have to uncheck the "Pause Printing" function.
If all else fails, get the cd. remove the printer and reinstall the software after shutting the printer down and start from scratch just like it was new. If neither of those solve it, go to http://www.hp.com and download your owners manual. There you will find a troubleshooting section that will help walk you through what to do. Hope that helps.
Kevin
Sep 12, 2009 | HP DeskJet 3650 InkJet Printer
Printer stopped working after I cancelled a print job
Turn off your printer and completely unplug the USB cable (from both the printer and the computer). Next check if the stopped document or the later documents are in the print spooler queue. If you can cancel all documents from the queue, do so. Otherwise: from Start Run (or the command prompt)
type: net stop spooler [enter]
then type: net start spooler [enter]
This works in XP and older MS Operating Systems but I've never tried it in Vista.
If you only enter the first command, you need to reboot the computer and then take a long coffee break after logging in before trying to print again.
May 06, 2009 | HP Deskjet D1455 InkJet Printer
Hp deskjet f4140 not operating
Goto start>Run>type services.msc>try to stop and then start print spooler service
Dec 24, 2008 | HP DESKJET PRINTER, HP OR COMPATIBLE
Not printing and nothing is paused or on the print list.
First of all you must let canceled print jobs finish deleting before sending new jobs, if the job is taking too long try restarting the computer with the printer on to clear the jobs this usually works if not then after restart open the printers folder and cancel all jobs here. let them finish deleting while the printer is still on (they must remain in communication during deleting jobs. Once all jobs are gone, remove the power brick from the printer for about a minute then reinsert and let the printer start up if it doesn't after a minute or so just turn it on once it finishes then try printing again.
Oct 14, 2008 | Dell 926 All-In-One InkJet Printer
381 Paper Jam Error
I had to remove every toner cartridge and drum. I found the paper under the second to last drum.
Jan 22, 2008 | OKI C5500n Printer
Xante ScreenWriter (Refurbished) Laser Printer Logo
56 people viewed this question
Top Xante Office Equipment & Supplies Experts
Ottoniel
rey francis basa
rey francis basa
Dudeman321
Are you a Xante Office Equipment and Supply Expert? Answer questions, earn points and help others
