Hi there, Do you have to instructions of how to use the fellowes Saturn A3 Laminator. I've looked on the Internet and only can find the instructions in Polish, would like them in English please
    President:
  • 1,126 Answers
Posted on Oct 07, 2009
Testimonial: "Thanks for that!!"
Why won't my laminator turn on?
There is a heating unit inside of a hot laminator. Sometimes when you use this machine for too long it can damage some of the internal components because most of those things are full of plastic. You may want to see if Fellows can take it back under warranty. If they can't you are going to have to get a new one.
Feb 05, 2017 | Fellowes Office Equipment & Supplies
Need a gear box for a Fellowes Voyager 125 laminator
Hi, I have a one that the PCB board is gone, the motor and shredder is perfect. You can buy the top with the motor frame from me if you like. It works sometime in reverse, but the safety light does not come on. Alternative sell me your PCB card
Apr 29, 2015 | Fellowes Voyager 125 Laminator
Fellowes laminator
Plz try the "Jam free" lever located on the top LEFT of the laminator. You ca try to feed another film in....hoping it will force the pouch out. Otherwise, you will have to take the cover off and unroll the pouch from the inside rollers. Good luck!
Aug 20, 2014 | Fellowes Saturn2 125 Laminator
. How do i fix my fellowes Mars A3 laminator it has jammed
Let it cool off for a while, then try reversing it. If it won't run it would have to be taken apart to clear the jam - a messy job! Fellowes does not usually consider these to be repairable but I would call them on their Toll-Free number to see what they can offer (800) 955-0959
Jul 01, 2014 | Gbc HeatSeal H425 Laminator
Laminator wont feed
If the motor is running, then the cog that drives the roller system may have failed. Laminators built today are made with plastic (nylon) roller drive cogwheels that crack. Especially if the fed media is too thick. Put the machine into run mode and feed a single piece of card (a playing card will do) into the feed slot. Lightly hold the card and see if you can feel the card moving. To check if the motor is in reverse, feed the card into the output slot.
If you are handy with a screwdriver, then with it disconnected, remove the lid (about six screws underneath) and check the rollers for old lamination sheets that could be stuck to one of them. This would limit the feed gap between the rollers, preventing you from putting your media in.
Nov 23, 2013 | Fellowes Saturn 2 A3 Laminator Laminators
I have a fellowes laminitor and it will not feed
Laminator Jammed! I have a fellowes saturn 125 laminator. there is an item stuck inside that is not sticking out on either side, so cannot be pulled out, even when the reslease lever is pushed. can i...
once you take it apart it voids all warrants if you have any.
if you do not have any warrant parts than that the only way you are going to fix the issue.
here is what some one gave me some tips on disassembly of equipment. draw a picture of the device, mark the area of screw layouts, after separating the 2 parts draw diagram of each part, make foot notes on what you did, screw locations, parts removed, parts cleaned, PUT EVERYTHING IN A LINE IN THE ORDER OF REMOVAL PARTS, than work backwards and put everything back the way you took it apart, you should not have any extra parts and it should work fine. than if it every happens again you have your notes and information on hand to help you. you could try this site.
www.ask.com/
www.manualonline.com/
/mfg.name/make/model#/
www.mfg.name.wow/manuals/service/
www.manuals.wow.com/make/model#/service/repair/
www.disassembly.wow.com/mfg.name/make/model/instructions/
Mar 22, 2012 | Fellowes Saturn SL 125 12.5-Inch Laminator
I'm looking for the manual from the Fellowes Cosmic A3 laminator
I searched a little bit longer and then I found it myself :-)
Jul 22, 2009 | Office Equipment & Supplies
534 people viewed this question
k24674
jasbo
jasbo
