Question about Bosch Axxis WFL 2060 Front Load Washer
Clicking noise when trying to drain will not drain at all on dishwasher
    Genius:
  • Bosch Master
  • 1,474 Answers
Could be filter blockage/ or Glass in pump blades...Jamming. Good luck
Posted on Oct 07, 2009
My GE Triton dishwasher won't drain. How do I de-clog it?
Remove the dishwasher drain line from the under sink connection. Direct that end to a bucket and run the drain option on the dishwasher.
1. Does water drains to the bucket. Then your under sink hook up to the dishwasher is clogged. Clean it with a screw driver.
2. No drain water comes to the bucket then
2.1 When on drain do you hear a humming noise. If yes then your drain motor working. That means mostly your dishwasher drain line clogged.
2.2 If humming noise is like a fan (impeller) running then drain line clogged.
2.3 If humming noise is like a small struggling to run. Then something stuck in the drain motor impeller.
Apr 24, 2015 | GE Tritonr XL GSD6260JCC Dishwasher
Troubleshoot my kenmore dishwasher won't drain
Check that the drain hose isn't kinked or blocked. Check that the pump inlet in the bottom of the dishwasher isn't full of gunk.
Oct 13, 2014 | Kenmore Dishwashers
Dishwasher noise
FIRST STEP IS TO CLEAN YOUR SUMP AND DRAIN FILTER AND PUMP CHECK FOR NPOISE AFTER CLEANING
Dec 09, 2013 | Amana Dishwashers
Dishwasher won't drain, makes a funny clicking/scraping noise when it is supposed to be draining.
Water does not drain from the dishwasher:
  • Check sink drain and drain hose for restrictions
  • Unjam the motor
  • Unjam the pump
  • Check the drain valve
  • Check the drive belt
  • Test the timer motor
  • If you have a brand new dishwasher or garbage disposer, check the knock out plug on the garbage disposer.
Apr 01, 2010 | Dishwashers
The dishwashers fills but does not wash the dishes then drains out.It makes clicking noise but nothing happens.
SOUNDS LIKE THE SOLENOID THAT CONTROLS THE WASH AND DRAIN IS STUCK IN DRAIN AND TRYING TO GO TO WASH POSITION.
Mar 08, 2010 | Kenmore Dishwashers
I have a GE Model GLD 4260L dishwasher. It is noisy in wash cycl
Hey Roy, the main pump/motor mechanism that supplies water through the washarms is a seperate pump from the drain pump.
Try this since it sounds like your handy, I bet this diagram will help you.
Go to www.geappliances.com scroll down while looking over on the left side of the site and click on the quick link of parts and accessories, then scroll down and click on the picture of the dishwasher, scroll down to the box where you enter your dishwasher model number, click on either of the models that pop up( both are the same) then click on the little arrow next to the red go button,to drop down your choices, click on motor-pump mechanism,then click GO,then click on the red letters that say "click here to view diagram of motor-pump mechanism" and then an exploded view of your dishwashers pump and other units will appear,study the diagram and this should help.
Wow that was a long road, but hey I hope this helps you solve your problem. Good luck !
Jan 10, 2010 | GE Dishwashers
Wont drain hear clicking noise
Hi
If the water doesn't drain from your dishwasher, check these:
Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Belt One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Motor If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced.
Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced.
Timer Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Jul 03, 2009 | Electrolux Kenmore 24 in. Built-In...
Water not draining from GE Monogram
hi, check your waste pipe is clear, check that the filters in the bottom of the machine are clear, try it again on rinse cycle, if it does not empty select rinse again and gently turn selector click by click ,see if empties now? if it does it may be your progamme timer fault if not it may be your pump
Feb 05, 2009 | GE 24 in. ZBD0710KSS Stainless Steel...
Bosch Axxis WFL 2060 Front Load Washer Logo
164 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
